Aqui esta esta en ensamblador...
; Binary To BCD Conversion Routine
; This routine converts a 16 Bit binary Number to a 5 Digit
; BCD Number. This routine is useful since PIC16C55 & PIC16C57
; have two 8 bit ports and one 4 bit port ( total of 5 BCD digits)
; The 16 bit binary number is input in locations H_byte and
; L_byte with the high byte in H_byte.
; The 5 digit BCD number is returned in R0, R1 and R2 with R0
; containing the MSD in its right most nibble.
; Performance :
; Program Memory : 35
; Clock Cycles : 885
; Program: B16TOBCD.ASM
; Revision Date:
; 1-13-97 Compatibility with MPASMWIN 1.40
count equ 16
temp equ 17
H_byte equ 10
L_byte equ 11
R0 equ 12 ; RAM Assignments
R1 equ 13
R2 equ 14
include "p16c5x.inc"
B2_BCD bcf STATUS,0 ; clear the carry bit
movlw .16
movwf count
clrf R0
clrf R1
clrf R2
loop16 rlf L_byte, F
rlf H_byte, F
rlf R2, F
rlf R1, F
rlf R0, F
decfsz count, F
goto adjDEC
RETLW 0
adjDEC movlw R2
movwf FSR
call adjBCD
movlw R1
movwf FSR
call adjBCD
movlw R0
movwf FSR
call adjBCD
goto loop16
adjBCD movlw 3
addwf 0,W
movwf temp
btfsc temp,3 ; test if result > 7
movwf 0
movlw 30
addwf 0,W
movwf temp
btfsc temp,7 ; test if result > 7
movwf 0 ; save as MSD
RETLW 0
; Test Program
main movlw 0FF
movwf H_byte
movwf L_byte ; The 16 bit binary number = FFFF
call B2_BCD ; After conversion the Decimal Number
; ; in R0,R1,R2 = 06,55,35
self goto self
org 1FF
goto main
END
No pude cargar el archivo porque dice no hay espacio SIEMPRE ME PASA ESO POR FAVOR EL ADMIN DEL FORO el archivo es de solo 2 KB.
