Que podría hacer entonces para poder tener control desde el numero 0 hasta el 255 ? Tendría que mapear en el pic para conseguir estos valores ? Gracias por sus consejos
Lo que yo uso en visual es esto:
Chr Function
Returns aString containing the character associated with the specifiedcharacter code.
Syntax
Chr(charcode)
The required charcodeargument is aLong that identifies a character.
Remarks
Numbers from 0 – 31 are the same as standard, nonprintableASCII codes. For example, Chr(10) returns a linefeed character. The normal range for charcode is 0 – 255. However, onDBCS systems, the actual range for charcode is -32768 to 65535.
Note The ChrB function is used with byte data contained in a String. Instead of returning a character, which may be one or two bytes, ChrB always returns a single byte. The ChrW function returns a String containing theUnicode character except on platforms where Unicode is not supported, in which case, the behavior is identical to the Chr function.
Entonces segun yo pues le mando al pic el ascii de los valores entre 0 y 255 y entonces el pic me los interpreta como enteros tambien de 0 a 255
