Despues de varias pruebas acabo de encontrar el fallo,pero no soy capaz de digereir porke falla.Esta señalizado en el final de la #INT_RDA:
#include <16f876.h>
#device adc=10 // Conversión con 10 bits
#use delay(clock=8000000)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
#fuses HS,NOWDT,NOPROTECT
#priority rtcc,rda,ad,timer1,timer2
#byte PORTA = 0x05
#byte PORTB = 0x06
#byte PORTC = 0x07
#byte RCREG = 0x1A
#byte RCSTA = 0x18
#bit RCSTA_1 = RCSTA.1
#bit RCSTA_2 = RCSTA.2
#bit RCSTA_4 = RCSTA.4
///// VARIABLES ////////////////////////////////////////////////////////
#bit LED_ROJO = PORTC.5
#bit IMPACTO_IZKIERDA = PORTB.6
#bit IMPACTO_TRASERO = PORTC.3
#bit IMPACTO_FRONTAL = PORTC.4
#bit IMPACTO_DERECHA = PORTB.5
#bit SERVOMOTOR = PORTC.2
#bit MOTOR_MOTRIZ_AVANCE = PORTB.4
#bit MOTOR_MOTRIZ_RETROCESO = PORTB.3
int MARCAS;
#bit M_0 = MARCAS.0
#bit M_1 = MARCAS.1
#bit M_2 = MARCAS.2
#bit M_3 = MARCAS.3
#bit M_4 = MARCAS.4
#bit m_5 = MARCAS.5
#bit M_6 = MARCAS.6
#bit M_7 = MARCAS.7
int MARCAS_2;
#bit MS_5 = MARCAS_2.0
#bit MS_10 = MARCAS_2.1
#bit ADELANTE = MARCAS_2.2
#bit ATRAS = MARCAS_2.3
#bit OBS_FR_IZ_AUX = MARCAS_2.4
#bit OBS_FR_DE_AUX = MARCAS_2.5
#bit OBS_FR_T = MARCAS_2.6
#bit SET_IZKIERDA = MARCAS_2.7
int MARCAS2;
#bit SET_GIRO_DE = MARCAS2.0
#bit SET_GIRO_IZ = MARCAS2.1
#bit M2_2 = MARCAS2.2
#bit VEL_REDU = MARCAS2.3
#bit OBS_TOTAL = MARCAS2.4
#bit OBS_FRON_DE = MARCAS2.5
#bit OBS_FRON_IZ = MARCAS2.6
#bit CONF_ADELANTE = MARCAS2.7
int FILTROS;
#bit FILTRADO_DERECHA = FILTROS.0
#bit FILTRADO_IZKIERDA = FILTROS.1
#bit FILTRADO_FRONTAL = FILTROS.2
#bit FILTRADO_TRASERO = FILTROS.3
#bit OBSTACULO_DERECHA = FILTROS.4
#bit OBSTACULO_IZKIERDA = FILTROS.5
#bit OBSTACULO_FRONTAL = FILTROS.6
#bit OBSTACULO_TRASERO = FILTROS.7
int MARCAS3;
#bit INI_DERECHA = MARCAS3.0
#bit INI_IZKIERDA = MARCAS3.1
#bit CENTESIMAS = MARCAS3.2
#bit DECIMAS = MARCAS3.3
#bit UNIDADES = MARCAS3.4
#bit M3_3 = MARCAS3.5
#bit alarma = MARCAS3.6
#bit variable_ana = MARCAS3.7
int TIME_SERVO;
int I ;
int CONT_M_1_2;
int VALOR_TIMER;
int VARIABLE_V_T;
int VALOR_TIMER_2;
int VARIABLE_V_T_2;
int CONTADOR_TIEMPO;
int CONTADOR_LED;
int SEGUNDOS;
int TMR1H_AUX;
int TMR1L_AUX ;
int CONTADOR_USAR;
int CONTADOR_MENSAGE;
int PROGRAM;
long int GIRO;
long int CICLO;
long int TIEMPO_MINIMO;
long int GIRO_DERECHA;
long int GIRO_IZKIERDA;
long int RECTO;
int consigna_temp;
static int MENSAGE[10];
VOID MANIOBRA_EVASION(VOID);
void MAIN(void) {
SET_TRIS_A (0b001111);
SET_TRIS_B (0b11100100);
SET_TRIS_C (0b10011000);
setup_adc_ports(all_ANALOG);
setup_timer_0 (RTCC_DIV_256);
setup_timer_1 ( T1_INTERNAL | T1_DIV_BY_8 );
set_timer1(60000);
setup_timer_2 ( T2_DIV_BY_16, 125, 10);
/* TMR1H = 253 TMR1L = 17 ----- para 3 ms
para temporizacion de X ms (la máxima posible es de 26ms) 11111101 10001
10ms ; TMR1H = 246 TMR1L = 59 ----para 10 ms
VC = ---------------- = 2500 (Se carga en Ca2 65535 - 2500)--> 53035 *BINARIO = 11110110 111011
4 * 0.125uS * 8
MARCAS = 0;
MARCAS_2 = 0;
MARCAS2 = 0;
FILTROS = 0;
CICLO = 20000;
TIEMPO_MINIMO = 1000;
GIRO = 1200;
CONT_M_1_2 = 0;
CONTADOR_TIEMPO = 0;
CONTADOR_MENSAGE = 0;
MARCAS3 = 0;
FILTROS = 0;
GIRO_DERECHA = 1550;
GIRO_IZKIERDA = 1100;
RECTO = 1400;
OBS_TOTAL = FALSE;
OBS_FRON_DE = FALSE;
OBS_FRON_IZ = FALSE;
SEGUNDOS = 0;
ADELANTE = FALSE;
ATRAS = FALSE;
ENABLE_INTERRUPTS(GLOBAL);
ENABLE_INTERRUPTS(INT_RTCC);
enable_INTERRUPTS(INT_TIMER1);
enable_INTERRUPTS(INT_TIMER2);
enable_INTERRUPTS(INT_RDA);
enable_INTERRUPTS(INT_AD);
DISABLE_INTERRUPTS(INT_EXT);
DISABLE_INTERRUPTS(INT_RB);
DISABLE_INTERRUPTS(INT_EEPROM);
DISABLE_INTERRUPTS(INT_CCP1);
DISABLE_INTERRUPTS(INT_CCP2);
DISABLE_INTERRUPTS(INT_SSP);
DISABLE_INTERRUPTS(INT_TBE);
PROGRAM = 0;
variable_ana = false;
consigna_temp = 40;
alarma = false;
//////////////// PROGRAMA PRINCIPAL //////////////////////////////////////////
START:
// PULSO :
valor_timer = giro/128;
variable_v_t = 255 - valor_timer;
// FRECUENCIA :
ciclo = ciclo - giro;
valor_timer_2 = ciclo/128;
variable_v_t_2 = 255 - valor_timer_2;
//output_high(servomotor);
servomotor = true;
set_timer0(variable_v_t);
M_6 = true;
INICIO:
//SI NO DETECTA NADA DE FRENTE AVANZA:
while (TRUE){
if (!obstaculo_derecha && !obstaculo_frontal && !obstaculo_izkierda){
giro = recto;
delay_ms (20);
adelante = true;
atras = false;
M_0 = false;
// SI DETECTA OBSTACULO A LA DERECHA GIRA A LA IZKIERDA SOLO PARA ESKIVARLO:
IF ((obstaculo_derecha && !obstaculo_izkierda && !obstaculo_frontal)||(obs_fr_de_aux && obstaculo_derecha)){
adelante = true;
atras = false;
giro = giro_izkierda;
delay_ms(20);
ELSE
ini_derecha = false;
// SI DETECTA OBSTACULO A LA IZKIERDA GIRA A LA DEREXA SOLO PARA ESKIVARLO:
IF ((obstaculo_izkierda && !obstaculo_derecha && !obstaculo_frontal)||(obs_fr_iz_aux && obstaculo_izkierda)){
adelante = true;
atras = false;
giro = giro_derecha;
delay_ms(20);
ELSE
ini_izkierda = false;
// FIN SEÑALES AUXILIARES DE GIRO FORZADO
IF ((obs_fr_iz_aux || obs_fr_de_aux)&& !obstaculo_trasero){
delay_ms(50);
obs_fr_iz_aux = false;
obs_fr_de_aux = false;
//SI DETECTA OBSTACULO GRANDE A LA IZKIERDA PARA E INTENTA SALVARLO:
IF (obstaculo_frontal && obstaculo_izkierda && !obstaculo_derecha && !set_giro_de){
set_giro_iz = true;
MANIOBRA_EVASION();
ELSE{
set_giro_iz = false;
//SI DETECTA OBSTACULO GRANDE A LA DERECHA PARA E INTENTA SALVARLO:
IF (obstaculo_frontal && obstaculo_derecha && !obstaculo_izkierda && !set_giro_iz) {
set_giro_de = true;
MANIOBRA_EVASION();
ELSE{
set_giro_de = false;
// DETECCION DE OBSTACULO TOTAL
IF ((obstaculo_frontal && obstaculo_derecha && obstaculo_izkierda && !obstaculo_trasero) && (!set_giro_de && !set_giro_iz)) {
adelante = false;
atras = true;
FOR (I=0;I<=30;++I){
IF (!Obstaculo_trasero && !M_0)
delay_ms(20);
ELSE
M_0 = true;
ELSE{
M_0 = false;
IF(M_0 && (obstaculo_frontal && obstaculo_derecha && obstaculo_izkierda)){
atras = false;
DELAY_MS(20);
DELAY_MS(1500);
atras = true;
DELAY_MS(1700);
M_0 = false;
/* CONTROL RADIO
while(program == 1){
if (obstaculo_derecha || obstaculo_izkierda || obstaculo_frontal)
motor_motriz_avance = false;
if (obstaculo_trasero)
motor_motriz_retroceso = false;
////////////// SUBRUTINAS /////////////////////////////////////////////////
void MANIOBRA_EVASION(void) {
IF (!OBSTACULO_TRASERO){
ADELANTE = FALSE;
ATRAS = TRUE; // RETROCESO
IF (SET_GIRO_IZ)GIRO = GIRO_IZKIERDA;
IF (SET_GIRO_DE)GIRO = GIRO_DERECHA; //COMPRUEBA HACIA KE LADO TIENE KE GIRAR
FOR(i=0;i<=15;++I){
IF(!OBSTACULO_TRASERO){
DELAY_MS(50);
ELSE{
OBS_FR_IZ_AUX = FALSE;
OBS_FR_DE_AUX = FALSE;
RETURN;
ELSE{
IF (SET_GIRO_IZ){
OBS_FR_IZ_AUX = TRUE;
IF (SET_GIRO_DE){
OBS_FR_DE_AUX = TRUE;
ATRAS = FALSE;
////////////////// INTERRUPCIONES /////////////////////////////////////////////////
#INT_RTCC
TIMER_0(){
int contador_analogico;
// PULSO :
VALOR_TIMER = GIRO/128;
VARIABLE_V_T = 255 - VALOR_TIMER;
// FRECUENCIA :
CICLO = CICLO - GIRO;
VALOR_TIMER_2 = CICLO/128;
VARIABLE_V_T_2 = 255 - VALOR_TIMER_2;
// DURACION PULSO:
IF (M_6){
SERVOMOTOR = FALSE;
M_6 = FALSE;
M_7 = TRUE;
set_timer0(VARIABLE_V_T_2);
RETURN;
// DURACION FRECUENCIA (20 MS)
IF (!M_6){
SERVOMOTOR = TRUE;
M_6 = TRUE;
set_timer0(VARIABLE_V_T);
++ CONTADOR_LED;
IF (CONTADOR_LED == 10){
IF (LED_ROJO && !alarma){
LED_ROJO = FALSE;
CONTADOR_LED = 0;
ELSE{
LED_ROJO = TRUE;
CONTADOR_LED = 0;
++contador_analogico;
if (contador_analogico == 50){
set_adc_channel(0);
read_adc(ADC_START_ONLY);
variable_ana = true;
if (contador_analogico == 100){
set_adc_channel(1);
contador_analogico = 0;
#int_TIMER1
TIMER_1(){
IF (MS_10){
IF (ADELANTE && !alarma){
MOTOR_MOTRIZ_AVANCE = TRUE;
ELSE{
MOTOR_MOTRIZ_AVANCE = FALSE; //MOTOR ON
IF (ATRAS && !alarma){
MOTOR_MOTRIZ_RETROCESO = TRUE;
ELSE{
MOTOR_MOTRIZ_RETROCESO = FALSE;
IF ((GIRO != RECTO) || OBSTACULO_FRONTAL){ //VELOCIDAD MODERADA
set_timer1(60000);
ELSE{
IF (ATRAS && (SEGUNDOS<2)){ //VELOCIDAD DE ARRANKE
set_timer1(1000);
ELSE{ //VELOCIDAD NORMAL
set_timer1(9000);
MS_10 = FALSE;
ELSE{
MOTOR_MOTRIZ_AVANCE = FALSE; //MOTOR OFF
MOTOR_MOTRIZ_RETROCESO = FALSE; //;TIEMPO DE DESCANSO MOTOR
set_timer1(62000);
MS_10 = TRUE;
#INT_TIMER2
TIMER_2(){
//;*********** INICIO DE FILTRADO ENTRADAS
IF (FILTRADO_DERECHA && !IMPACTO_DERECHA){
OBSTACULO_DERECHA = TRUE;
ELSE{
OBSTACULO_DERECHA = FALSE;
FILTRADO_DERECHA = FALSE;
IF (FILTRADO_IZKIERDA && !IMPACTO_IZKIERDA){
OBSTACULO_IZKIERDA = TRUE;
ELSE{
OBSTACULO_IZKIERDA = FALSE;
FILTRADO_IZKIERDA = FALSE;
IF (FILTRADO_FRONTAL && !IMPACTO_FRONTAL){
OBSTACULO_FRONTAL = TRUE;
ELSE{
OBSTACULO_FRONTAL = FALSE;
FILTRADO_FRONTAL = FALSE;
IF (FILTRADO_TRASERO && !IMPACTO_TRASERO){
OBSTACULO_TRASERO = TRUE;
ELSE{
OBSTACULO_TRASERO = FALSE;
FILTRADO_TRASERO = FALSE;
if (!IMPACTO_DERECHA)
FILTRADO_DERECHA = TRUE;
IF (!IMPACTO_IZKIERDA)
FILTRADO_IZKIERDA = TRUE;
IF(!IMPACTO_FRONTAL)
FILTRADO_FRONTAL = TRUE;
IF (!IMPACTO_TRASERO)
FILTRADO_TRASERO = TRUE;
// ******* FIN DE FILTRADO_ENTRADAS
#INT_RDA
RECEPCION(){
IF (RCSTA_1 || RCSTA_2){
RCSTA_4 = FALSE;
IF (RCREG != 0){
RCREG = 0;
RCSTA_4 = TRUE;
RETURN;
MENSAGE[CONTADOR_MENSAGE]=GETCHAR();
++CONTADOR_MENSAGE;
IF ((MENSAGE[0]=="1")){
GOTO CONTINUAR;
ELSE{
CONTADOR_MENSAGE=0;
RETURN;
CONTINUAR:
if (contador_mensage>=6){
IF(MENSAGE[1]=="P"){
if (MENSAGE[2]=="X"){
PROGRAM = 1;
if (MENSAGE[2]=="B"){
program = 0;
if (MENSAGE[2]=="T"){
consigna_temp = ((mensage[3]-48)*100)+((mensage[4]-48)*10)+(mensage[4]-48);
PRINtF("consiga temperatura =%du ºC
",consigna_temp);
IF(MENSAGE[1]=="G"){
GIRO = ((MENSAGE[2]-48)*1000)+((MENSAGE[3]-48)*100)+((MENSAGE[4]-48)*10)+(MENSAGE[5]-48);
IF (MENSAGE[1]=="A"){
ADELANTE = TRUE;
ATRAS = FALSE;
IF (MENSAGE[1]=="R"){
ATRAS = TRUE;
ADELANTE=FALSE;
IF (MENSAGE[1]=="S"){
ADELANTE = FALSE;
ATRAS = FALSE;
disable_interrupts(INT_RDA);///aki esta el fallo,si habilito
delay_ms(60); ///este trozo de codigo,todos los
enable_interrupts(INT_RDA);///temporizadores se he ralentizan
*/////////////////////////////////// y se me va el programa a fer la mar
#INT_AD
Analog(){
float resultado_ana;
long int grados;
int grados_motor;
resultado_ana = read_adc();
resultado_ana = (resultado_ana*150);
grados = resultado_ana/1023;
if (variable_ana)
PRINtF("temperatura ambiente =%lu ºC
",GRADOS);
else{
grados_motor = grados;
PRINtF("grados motor =%d ºC
",grados_motor);
if(grados_motor>=consigna_temp)
alarma = true;
else{
if(grados_motor<(consigna_temp - 5))
alarma = false;
perdonar ke os suelte todo este rollo pero eske si no lo veo no lo creo....Vale,puedo entender ke al hacer un retraso de 60ms. dentro de un ainterrupcion,el resto de temporizadores no puedan actuar,pero....CON LA INTERRUPCION DESHABILITADA¡???Si ese codigo "en teoria" no debe de ejecutarlo!Aparte,ke tampoco le he transmitido nada!!
Saludos!!!
