Nada... probe el programita q usó toni0 tb con un 18f452 y nada... tampoco funciona.
He probado el de oshow y el de toni0 (q son practicamente iguales) pero mi lcd se niega a escribir nada y no sé xq puede ser
Lo unico q me funciona es la libreria q viene con la picdem en leguaje de compilador, la he comparado con las otras y no veo nada raro, no se!!!!!!
A ver si alguien le echa un vistazo y se le ocurre algo
#define LCD_D4 PORTD, 0 ; LCD data bits
#define LCD_D5 PORTD, 1
#define LCD_D6 PORTD, 2
#define LCD_D7 PORTD, 3
#define LCD_D4_DIR TRISD, 0 ; LCD data bits
#define LCD_D5_DIR TRISD, 1
#define LCD_D6_DIR TRISD, 2
#define LCD_D7_DIR TRISD, 3
#define LCD_E PORTA, 1 ; LCD E clock
#define LCD_RW PORTA, 2 ; LCD read/write line
#define LCD_RS PORTA, 3 ; LCD register select line
#define LCD_E_DIR TRISA, 1
#define LCD_RW_DIR TRISA, 2
#define LCD_RS_DIR TRISA, 3
#define LCD_INS 0
#define LCD_DATA 1
D_LCD_DATA UDATA 0x20
COUNTER res 1
delay res 1
temp_wr res 1
temp_rd res 1
GLOBAL temp_wr
PROG1 CODE
LCDLine_1
banksel temp_wr
movlw 0x80
movwf temp_wr
call i_write
return
GLOBAL LCDLine_1
LCDLine_2
banksel temp_wr
movlw 0xC0
movwf temp_wr
call i_write
return
GLOBAL LCDLine_2
d_write ;write data
call LCDBusy
bsf STATUS, C
call LCDWrite
banksel TXREG ;move data into TXREG
movwf TXREG
banksel TXSTA
btfss TXSTA,TRMT ;wait for data TX
goto $-1
banksel PORTA
return
GLOBAL d_write
i_write ;write instruction
call LCDBusy
bcf STATUS, C
call LCDWrite
return
GLOBAL i_write
rlcd macro MYREGISTER
IF MYREGISTER == 1
bsf STATUS, C
call LCDRead
ELSE
bcf STATUS, C
call LCDRead
ENDIF
endm
LCDInit
clrf PORTA
banksel TRISA ;configure control lines
bcf LCD_E_DIR
bcf LCD_RW_DIR
bcf LCD_RS_DIR
movlw b"00001110"
banksel ADCON1
movwf ADCON1
movlw 0xff ; Wait ~15ms @ 20 MHz
banksel COUNTER
movwf COUNTER
movlw 0xFF
banksel delay
movwf delay
call DelayXCycles
decfsz COUNTER, F
goto $-3
movlw b"00110000" ;#1 Send control sequence
movwf temp_wr
bcf STATUS,C
call LCDWriteNibble
movlw 0xff ;Wait ~4ms @ 20 MHz
movwf COUNTER
movlw 0xFF
movwf delay
call DelayXCycles
decfsz COUNTER, F
goto $-3
movlw b"00110000" ;#2 Send control sequence
movwf temp_wr
bcf STATUS,C
call LCDWriteNibble
movlw 0xFF ;Wait ~100us @ 20 MHz
movwf delay
call DelayXCycles
movlw b"0011000" ;#3 Send control sequence
movwf temp_wr
bcf STATUS,C
call LCDWriteNibble
;test delay
movwf delay
call DelayXCycles
movlw b"00100000" ;#4 set 4-bit
movwf temp_wr
bcf STATUS,C
call LCDWriteNibble
call LCDBusy ;Busy?
movlw b"00101000" ;#5 Function set
movwf temp_wr
call i_write
movlw b"00001101" ;#6 Display = ON
movwf temp_wr
call i_write
movlw b"00000001" ;#7 Display Clear
movwf temp_wr
call i_write
movlw b"00000110" ;#8 Entry Mode
movwf temp_wr
call i_write
movlw b"10000000" ;DDRAM addresss 0000
movwf temp_wr
call i_write
; movlw b"00000010" ;return home
; movwf temp_wr
; call i_write
return
GLOBAL LCDInit
; _ ______________________________
; RS _>--<______________________________
; _____
; RW \_____________________________
; __________________
; E ____________/ \___
; _____________ ______
; DB _____________>--------------<______
LCDWriteNibble
btfss STATUS, C ; Set the register select
bcf LCD_RS
btfsc STATUS, C
bsf LCD_RS
bcf LCD_RW ; Set write mode
banksel TRISD
bcf LCD_D4_DIR ; Set data bits to outputs
bcf LCD_D5_DIR
bcf LCD_D6_DIR
bcf LCD_D7_DIR
NOP ; Small delay
NOP
banksel PORTA
bsf LCD_E ; Setup to clock data
btfss temp_wr, 7 ; Set high nibble
bcf LCD_D7
btfsc temp_wr, 7
bsf LCD_D7
btfss temp_wr, 6
bcf LCD_D6
btfsc temp_wr, 6
bsf LCD_D6
btfss temp_wr, 5
bcf LCD_D5
btfsc temp_wr, 5
bsf LCD_D5
btfss temp_wr, 4
bcf LCD_D4
btfsc temp_wr, 4
bsf LCD_D4
NOP
NOP
bcf LCD_E ; Send the data
return
LCDWrite
; call LCDBusy
call LCDWriteNibble
BANKSEL temp_wr
swapf temp_wr, f
call LCDWriteNibble
banksel temp_wr
swapf temp_wr,f
return
GLOBAL LCDWrite
; _____ _____________________________________________________
; RS _____>--<_____________________________________________________
; ____________________________________________________
; RW _________/
; ____________________ ____________________
; E ____________/ \____/ \__
; _________________ __________ ___
; DB _________________>--------------<__________>--------------<___
LCDRead
banksel TRISD
bsf LCD_D4_DIR ; Set data bits to inputs
bsf LCD_D5_DIR
bsf LCD_D6_DIR
bsf LCD_D7_DIR
BANKSEL PORTA
bcf LCD_RS
btfsc STATUS, C
bsf LCD_RS
bsf LCD_RW ;Read = 1
NOP
NOP
NOP
NOP
NOP
NOP
btfss LCD_D7 ; Get high nibble
bcf temp_rd, 7
btfsc LCD_D7
bsf temp_rd, 7
btfss LCD_D6
bcf temp_rd, 6
btfsc LCD_D6
bsf temp_rd, 6
btfss LCD_D5
bcf temp_rd, 5
btfsc LCD_D5
bsf temp_rd, 5
btfss LCD_D4
bcf temp_rd, 4
btfsc LCD_D4
bsf temp_rd, 4
bcf LCD_E ; Finished reading the data
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
btfss LCD_D7 ; Get low nibble
bcf temp_rd, 3
btfsc LCD_D7
bsf temp_rd, 3
btfss LCD_D6
bcf temp_rd, 2
btfsc LCD_D6
bsf temp_rd, 2
btfss LCD_D5
bcf temp_rd, 1
btfsc LCD_D5
bsf temp_rd, 1
btfss LCD_D4
bcf temp_rd, 0
btfsc LCD_D4
bsf temp_rd, 0
FinRd
return
LCDBusy
; Check BF
rlcd LCD_INS
btfsc temp_rd, 7
goto LCDBusy
return
GLOBAL LCDBusy
DelayXCycles
decfsz delay, F
goto DelayXCycles
return
END
