Autor Tema: Error de compilación con PIC 16F887 y librería LCD de MpAM  (Leído 1404 veces)
Desconectado ale141414
« en: 29 de Mayo de 2016, 16:45:06 »
Hola a todos,
Estoy usando la aplicación maestro de Microchip para controlar un LCD. Cuando estaba utilizando el PIC 16F873A el programa compilaba y compila sin ningún problema. Pero ahora decidí cambiar de PIC y utilizar el 16F887. Cunado compilo con éste PIC me da el siguiente error:
Error[113]   D:\MIS DOCUMENTOS\PROGRAMACIóN PIC\EN ASM\LCD 2X16\XLCD.INC 71 : Symbol not previously defined (XLCDInit)
Error[113]   D:\MIS DOCUMENTOS\PROGRAMACIóN PIC\EN ASM\LCD 2X16\XLCD.INC 72 : Symbol not previously defined (XLCDCommand)
Error[113]   D:\MIS DOCUMENTOS\PROGRAMACIóN PIC\EN ASM\LCD 2X16\XLCD.INC 73 : Symbol not previously defined (XLCDPut)
Error[113]   D:\MIS DOCUMENTOS\PROGRAMACIóN PIC\EN ASM\LCD 2X16\XLCD.INC 74 : Symbol not previously defined (XLCDDelay5ms)
Error[113]   D:\MIS DOCUMENTOS\PROGRAMACIóN PIC\EN ASM\LCD 2X16\XLCD.INC 75 : Symbol not previously defined (XLCDDelay100us)
Error[113]   D:\MIS DOCUMENTOS\PROGRAMACIóN PIC\EN ASM\LCD 2X16\XLCD.INC 76 : Symbol not previously defined (XLCDCommandInit4bit)
Error[113]   D:\MIS DOCUMENTOS\PROGRAMACIóN PIC\EN ASM\LCD 2X16\XLCD.INC 77 : Symbol not previously defined (XLCDL1home)
Error[113]   D:\MIS DOCUMENTOS\PROGRAMACIóN PIC\EN ASM\LCD 2X16\XLCD.INC 78 : Symbol not previously defined (XLCDL2home)
Error[113]   D:\MIS DOCUMENTOS\PROGRAMACIóN PIC\EN ASM\LCD 2X16\XLCD.INC 79 : Symbol not previously defined (XLCDClear)
Error[113]   D:\MIS DOCUMENTOS\PROGRAMACIóN PIC\EN ASM\LCD 2X16\XLCD.INC 80 : Symbol not previously defined (XLCDReturnHome)
Error[113]   D:\MIS DOCUMENTOS\PROGRAMACIóN PIC\EN ASM\LCD 2X16\XLCD.INC 81 : Symbol not previously defined (XLCDSendMsg)
Error[113]   D:\MIS DOCUMENTOS\PROGRAMACIóN PIC\EN ASM\LCD 2X16\XLCD.INC 89 : Symbol not previously defined (XLCDIsBusy)
Error[113]   D:\MIS DOCUMENTOS\PROGRAMACIóN PIC\EN ASM\LCD 2X16\XLCD.INC 90 : Symbol not previously defined (XLCDReadData)
Éste error me lo da en las siguientes líneas de código:
    GLOBAL  XLCDInit                    ;initialize LCD
    GLOBAL  XLCDCommand                 ;instruction command
    GLOBAL  XLCDPut                       ;put content into LCD
    GLOBAL  XLCDDelay5ms
    GLOBAL  XLCDDelay100us
    GLOBAL  XLCDCommandInit4bit         ;function used only in 4 bit init by instruction
    GLOBAL  XLCDL1home                  ;Sets DDRam address to first line
    GLOBAL  XLCDL2home                  ;Sets DDRam address to second line
    GLOBAL  XLCDClear                   ;Clears DDram content and points to address 00
    GLOBAL  XLCDReturnHome              ;Sets DDRAM address 0 DDramConent remain unchanged
    GLOBAL  XLCDSendMsg
    #if XLCDMODE == 1
    GLOBAL  XLCDDelay                   ;delay to becalled after every instruction Command
    #endif
    #if XLCDRWPIN !=10                  ;if RW grounded
    GLOBAL  XLCDIsBusy                  ;reads the busy flag
    GLOBAL  XLCDReadData                ;readdata from DDRAM
    #endif
Mi duda es entonces porqué con un PIC el programa compila de forma correcta y con el otro me tira éste error.
Desde ya muchas gracias
Alejandro
Re:Error de compilación con PIC 16F887 y librería LCD de MpAM
« Respuesta #1 en: 29 de Mayo de 2016, 17:25:48 »
Claramente dice que las funciones "XLCDInit" , etc, etc ,etc se estan intentando crear como "globales", pero que jamas se definieron.
Lo mas seguro es que sea un problema de direcciones de libreria o que este restringido a algunos PICs por lo que comentas.
« Respuesta #2 en: 29 de Mayo de 2016, 20:19:20 »
A que te referís con las direcciones de librería?
Si estuviese restringiendo algunos PICs, ésto decís que lo hace la librería? Creo que no lo esta haciendo.
« Respuesta #3 en: 30 de Mayo de 2016, 07:39:23 »
La directiva global hace que el simbolo aparezca dentro del proyecto sin necesidad de incluir el mismo. El cual seria algo asi:
Archivo1
Código: ASM
  1. Global Funcion1
  2.
  3. Funcion1:        ;Tu error es como si esto no estuviera, solo el global
  4.       ;Aca instrucciones
Y para que sea usado por los demas, no es necesario "incluirlo" sino con hacer:
Archivo2
Código: ASM
  1. Extern Funcion1
  2.
  3.       CALL   Funcion1
Ya podrias usarlo, siempre y cuando esten agregados como archivos fuentes (Source) del proyecto.
Supuse que por alguna razon que podria llegar a ser que pida algun include o algo y le este errando de ruta. A eso me referi con problemas de direcciones.
Tal ves todas esas funciones no estan en un solo archivo y hacen algo asi:
Código: ASM
  1. global Funcion1
  2.
  3. #include Funcion1.inc  ; Donde aca esta la funcion1
