yo pensaba que el output enable (OE) era el strobe del 4094
este es el código de la librería:
#IFNDEF EXP_OUT_ENABLE
#define EXP_OUT_ENABLE PIN_B0
#define EXP_OUT_CLOCK PIN_B1
#define EXP_OUT_DO PIN_B2
#define NUMBER_OF_74595 1
#ENDIF
void write_expanded_outputs(BYTE* eo) {
BYTE i;
output_low(EXP_OUT_CLOCK);
output_low(EXP_OUT_ENABLE);
for(i=1;i<=NUMBER_OF_74595*8;++i) { // Clock out bits from the eo array
if((*(eo+(NUMBER_OF_74595-1))&0x80)==0)
output_low(EXP_OUT_DO);
else
output_high(EXP_OUT_DO);
shift_left(eo,NUMBER_OF_74595,0);
output_high(EXP_OUT_CLOCK);
output_high(EXP_OUT_ENABLE);
