#include <16f73.h>
#use delay (clock =4000000)
#fuses XT,NOWDT,PUT, NOPROTECT
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use rs232(BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7, BITS=8)
#include <stdio.h>
#include <math.h>
#include <string.h>
#include <stdlib.h>
char datos[16]={'1','1','0','1','0','1','1','0','1','0','1','0','0','1','1','0'};
int j;
void main(){
setup_adc_ports(PIN_A0,PIN_A1,PIN_A2,PIN_A3,PIN_A4,PIN_A5);
set_tris_b(0x00);
set_tris_a(0x08);
set_tris_c(0x00);
output_high(PIN_A0);
while(true)
if(input(PIN_A4)==0)
output_high(PIN_B0);
output_high(PIN_B1);
output_high(PIN_B2);
output_high(PIN_B3);
else
output_low(PIN_B0);
output_low(PIN_B1);
output_low(PIN_B2);
output_low(PIN_B3);
for (j=0;j<15;j++ )
putc(datos[j]);
me sale el siguiente error
Clean: Deleting intermediary and output files.
Clean: Deleted file "programa7.ESYM".
Clean Warning: File "C:\Users\ciel\Desktop\archivos mplab\programa7.o" doesn't exist.
Clean: Deleted file "programa7.ERR".
Clean: Done.
Executing: "C:\Program files\Picc\CCSC.exe" +FM "programa7.c" +DF +LN +T +A +M +Z +Y=9 +EA
*** Error 58 "programa7.c" Line 30(30,31): Expecting a close paren
1 Errors, 0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Fri Aug 28 14:52:47 2015
es una linea arriba de setup_adc_ports(PIN_A0,PIN_A1,PIN_A2,PIN_A3,PIN_A4,PIN_A5); no importa donde lo ponga una linea arriba de esta me sale ese error alguien sabe como corregirlo
