Autor Tema: TECLADO HEXADECIMAL CON PCF8574A,EXPANSOR DE BUS I2C proton ide  (Leído 1646 veces)
Desconectado Noelillo
« en: 26 de Marzo de 2014, 03:25:34 »
[code'****************************************************************
'*  Name    : UNTITLED.BAS                                      *
'*  Author  : [select VIEW...EDITOR OPTIONS]                    *
'*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
'*          : All Rights Reserved                               *
'*  Date    : 23/03/2014                                        *
'*  Version : 1.0                                               *
'*  Notes   :                                                   *
        Device 16F877A
        XTAL = 4
' LCD pin Configuracion
        LCD_TYPE = 0
        LCD_LINES = 4
        LCD_DTPIN = PORTB.4
        LCD_RSPIN = PORTB.2
        LCD_ENPIN = PORTB.3
        LCD_INTERFACE = 4
        Cls      ' Clear LCD
        ALL_DIGITAL = True ' Set ports to digital mode
        Clear
'*********************  SIMBOLOS DEL PROGRAMA *********************************************
   Symbol SDA = PORTC.5           ' Alias the SDA (Data) line
   Symbol SCL = PORTC.4           ' Alias the SSL (Clock) line
   Symbol Escribe = %01111000
   Symbol Lee     = %01111001
Dim N          As Byte
Dim A          As Byte
Dim Ylcd       As Byte
Dim Numero     As DWord 'Byte
Dim OldNumero  As DWord 'Byte
Dim Numeros    As Byte
Dim Multi      As Byte
Dim Direccion  As Byte
'****************INICIO*******************************************
 Inicio:
 Ylcd      = 17
 Multi     = 0
 OldNumero = 0
 Direccion = 0
 EWrite Direccion,[OldNumero]
 Numero  = ERead 40
Print At 1,1,Dec Numero
DelayMS 2000
Cls
Numero    = 0
Print At 2,1,"*-Borra #-Enter"
    '01234568
A = %11110000
'**************************** TECLADO ****************************
Teclado:
 A = %11110000
 I2COUT SDA, SCL, Lee ,   [ A ]
 I2Cin  SDA, SCL, Escribe,[ N ]
 If N=224 Then '<----------------------
 A= %00000111                        '
   I2COUT SDA, SCL, Lee ,   [ A ]    '
   I2Cin  SDA, SCL, Escribe,[ N ]    '
   If N=6 Then                       '
   Numeros = 1                       '
   GoSub Numeraco                    '
   EndIf                             '
   If N=5 Then                       '
   Numeros = 4                       '
   GoSub Numeraco                    '
   EndIf                             '
   If N=3 Then                       '
   Numeros = 7                       '
   GoSub Numeraco                    '
   EndIf                             '
   If N=7 Then '(*)
   GoSub Numeraco
   EndIf                             '
 EndIf '<------------------------------
 If N=208 Then'<---------------------
   A= %00001011                     '
   If N=10 Then                     '
   Numeros = 2                      '
   GoSub Numeraco                   '
   EndIf                            '
   If N=9 Then                      '
   Numeros = 5                      '
   GoSub Numeraco                   '
   EndIf                            '
   If N=11 Then                     '
   Numeros = 8                      '
   GoSub Numeraco                   '
   EndIf                            '
   If N=3 Then                      '
   Numeros = 0                      '
   GoSub Numeraco                   '
   EndIf                            '
 EndIf '<----------------------------'
 If N=176 Then'<----------------------
   A= %00001101                      '
     If N=12 Then                    '
     Numeros = 3                     '
     GoSub Numeraco                  '
     EndIf                           '
     If N=13 Then                    '
     Numeros = 6                     '
     GoSub Numeraco                  '
     EndIf                           '
     If N=9 Then                     '
     Numeros = 9                     '
     GoSub Numeraco                  '
     EndIf                           '
      If N=5 Then '(#)               '
      Cls                            '
      Print At 1,1,"Meto ",Dec Numero'
       EWrite 40,[Numero]
      DelayMS 1500                   '
      Cls                            '
      GoTo Inicio                    '
      EndIf                          '
 DelayMS 200
 GoTo Teclado
 Numeraco:
  If N=7 Then
   Dec Multi
    If Multi = 255 Then
     Multi = 0
     Return
    EndIf
   Direccion = Direccion -4 ' dword 4bit,
   OldNumero  = ERead Direccion                       '
   Numero = OldNumero
   Inc Ylcd
 Print At 1,8,"           "
 Print At 1,Ylcd,Dec Numero
 Return
 EndIf
  Inc Multi
  If Multi >= 10 Then
   Multi = 10
   GoTo Salgo ' return de numeraco
   EndIf
  Numero = OldNumero * 10
  Numero= Numero + Numeros
  OldNumero = Numero
  Direccion = Direccion + 4 ' dword 4bit,
  Dec Ylcd
 Salgo:
 Return
End]
