Autor Tema: Tengo un problema al intentar cargar la libreria mpusbapi a Matlab  (Leído 1785 veces)
Desconectado betatierradelsur
« en: 04 de Febrero de 2014, 23:14:59 »
Hola, estoy comenzando con esto del PIC - USB con matlab, y estoy queriendo reproducir este ejemplo de la pag de Mathworks, para ser exacto estoy intendo hacer funcionar el ejemplo 1 de esa pagina.
Pero tengo problemas al cargar la libreria en matlab (tecleando la instruccion loadlibrary mpusbapi _mpusbapi.h alias libreria ), y esto es lo que me aparece en matlab:
Warning: Warnings messages were produced while parsing.  Check the functions you
intend to use for correctness.  Warning text can be viewed using:
[notfound,warnings]=loadlibrary(...)
> In loadlibrary at 360
Error loading library intermediate output follows.
The actual error is at the end of this output.
Type 'PCHAR' was not found.  Defaulting to type error.
Found on line 56 of input from line 55 of file C:\\Users\\Fenix\\Documents\\USB Matlab\\_mpusbapi.h
Type 'HANDLE' was not found.  Defaulting to type error.
Found on line 63 of input from line 62 of file C:\\Users\\Fenix\\Documents\\USB Matlab\\_mpusbapi.h
Found on line 70 of input from line 69 of file C:\\Users\\Fenix\\Documents\\USB Matlab\\_mpusbapi.h
Type 'PVOID' was not found.  Defaulting to type error.
Type 'PDWORD' was not found.  Defaulting to type error.
Found on line 77 of input from line 76 of file C:\\Users\\Fenix\\Documents\\USB Matlab\\_mpusbapi.h
Found on line 84 of input from line 83 of file C:\\Users\\Fenix\\Documents\\USB Matlab\\_mpusbapi.h
Type 'BOOL' was not found.  Defaulting to type error.
Found on line 87 of input from line 86 of file C:\\Users\\Fenix\\Documents\\USB Matlab\\_mpusbapi.h
??? Error using ==> loadlibrary at 441
Building libreria_thunk_pcwin64 failed.  Compiler output is:
cl -I"C:\Program Files\MATLAB\R2011a\extern\include"  /Zp8  /W3  /D_CRT_SECURE_NO_DEPRECATE
/D_SCL_SECURE_NO_DEPRECATE /D_SECURE_SCL=0  /nologo  -I"C:\Program Files\MATLAB\R2011a\bin"
-I"C:\Users\Fenix\Documents\USB Matlab" "libreria_thunk_pcwin64.c" -LD
-Fe"libreria_thunk_pcwin64.dll"
C:\Users\Fenix\Documents\USB Matlab\_mpusbapi.h(51) : error C2059: syntax error : 'string'
C:\Users\Fenix\Documents\USB Matlab\_mpusbapi.h(54) : error C2059: syntax error : 'string'
C:\Users\Fenix\Documents\USB Matlab\_mpusbapi.h(57) : error C2059: syntax error : 'string'
C:\Users\Fenix\Documents\USB Matlab\_mpusbapi.h(64) : error C2059: syntax error : 'string'
C:\Users\Fenix\Documents\USB Matlab\_mpusbapi.h(71) : error C2059: syntax error : 'string'
C:\Users\Fenix\Documents\USB Matlab\_mpusbapi.h(78) : error C2059: syntax error : 'string'
C:\Users\Fenix\Documents\USB Matlab\_mpusbapi.h(85) : error C2059: syntax error : 'string'
libreria_thunk_pcwin64.c(59) : error C2065: 'PCHAR' : undeclared identifier
libreria_thunk_pcwin64.c(59) : error C2146: syntax error : missing ';' before identifier 'p0'
libreria_thunk_pcwin64.c(59) : error C2065: 'p0' : undeclared identifier
libreria_thunk_pcwin64.c(60) : error C2065: 'p0' : undeclared identifier
libreria_thunk_pcwin64.c(60) : error C2146: syntax error : missing ')' before identifier 'PCHAR'
libreria_thunk_pcwin64.c(60) : error C2065: 'PCHAR' : undeclared identifier
libreria_thunk_pcwin64.c(60) : error C2100: illegal indirection
libreria_thunk_pcwin64.c(60) : error C2059: syntax error : ')'
libreria_thunk_pcwin64.c(60) : error C2297: '*' : illegal, right operand has type 'const char *'
libreria_thunk_pcwin64.c(61) : error C2065: 'p0' : undeclared identifier
libreria_thunk_pcwin64.c(62) : error C2146: syntax error : missing ')' before identifier 'PCHAR'
libreria_thunk_pcwin64.c(62) : error C2065: 'PCHAR' : undeclared identifier
libreria_thunk_pcwin64.c(62) : error C2059: syntax error : ')'
libreria_thunk_pcwin64.c(62) : error C2146: syntax error : missing ';' before identifier 'fcn'
libreria_thunk_pcwin64.c(62) : warning C4047: 'return' : 'uint32' differs in levels of indirection
from 'uint32 (__cdecl *)()'
libreria_thunk_pcwin64.c(62) : error C2065: 'p0' : undeclared identifier
libreria_thunk_pcwin64.c(66) : error C2061: syntax error : identifier
'HANDLEuint32PCHARPCHARuint32uint32Thunk'
libreria_thunk_pcwin64.c(66) : error C2059: syntax error : ';'
libreria_thunk_pcwin64.c(66) : error C2059: syntax error : 'type'
libreria_thunk_pcwin64.c(89) : error C2065: 'HANDLE' : undeclared identifier
libreria_thunk_pcwin64.c(89) : error C2146: syntax error : missing ';' before identifier 'p0'
libreria_thunk_pcwin64.c(89) : error C2065: 'p0' : undeclared identifier
libreria_thunk_pcwin64.c(90) : error C2065: 'PVOID' : undeclared identifier
libreria_thunk_pcwin64.c(90) : error C2146: syntax error : missing ';' before identifier 'p1'
libreria_thunk_pcwin64.c(90) : error C2065: 'p1' : undeclared identifier
libreria_thunk_pcwin64.c(91) : error C2275: 'uint32' : illegal use of this type as an expression
        libreria_thunk_pcwin64.c(45) : see declaration of 'uint32'
libreria_thunk_pcwin64.c(91) : error C2146: syntax error : missing ';' before identifier 'p2'
libreria_thunk_pcwin64.c(91) : error C2065: 'p2' : undeclared identifier
libreria_thunk_pcwin64.c(92) : error C2065: 'PDWORD' : undeclared identifier
libreria_thunk_pcwin64.c(92) : error C2146: syntax error : missing ';' before identifier 'p3'
libreria_thunk_pcwin64.c(92) : error C2065: 'p3' : undeclared identifier
libreria_thunk_pcwin64.c(93) : error C2275: 'uint32' : illegal use of this type as an expression
libreria_thunk_pcwin64.c(93) : error C2146: syntax error : missing ';' before identifier 'p4'
libreria_thunk_pcwin64.c(93) : error C2065: 'p4' : undeclared identifier
libreria_thunk_pcwin64.c(94) : error C2065: 'p0' : undeclared identifier
libreria_thunk_pcwin64.c(94) : error C2146: syntax error : missing ')' before identifier 'HANDLE'
libreria_thunk_pcwin64.c(94) : error C2065: 'HANDLE' : undeclared identifier
libreria_thunk_pcwin64.c(94) : error C2100: illegal indirection
libreria_thunk_pcwin64.c(94) : error C2059: syntax error : ')'
libreria_thunk_pcwin64.c(94) : error C2297: '*' : illegal, right operand has type 'const char *'
libreria_thunk_pcwin64.c(95) : error C2065: 'p0' : undeclared identifier
libreria_thunk_pcwin64.c(96) : error C2065: 'p1' : undeclared identifier
libreria_thunk_pcwin64.c(96) : error C2146: syntax error : missing ')' before identifier 'PVOID'
libreria_thunk_pcwin64.c(96) : error C2065: 'PVOID' : undeclared identifier
libreria_thunk_pcwin64.c(96) : error C2100: illegal indirection
libreria_thunk_pcwin64.c(96) : error C2059: syntax error : ')'
libreria_thunk_pcwin64.c(96) : error C2297: '*' : illegal, right operand has type 'const char *'
libreria_thunk_pcwin64.c(97) : error C2065: 'p1' : undeclared identifier
libreria_thunk_pcwin64.c(98) : error C2065: 'p2' : undeclared identifier
libreria_thunk_pcwin64.c(99) : error C2065: 'p2' : undeclared identifier
libreria_thunk_pcwin64.c(100) : error C2065: 'p3' : undeclared identifier
libreria_thunk_pcwin64.c(100) : error C2146: syntax error : missing ')' before identifier 'PDWORD'
libreria_thunk_pcwin64.c(100) : error C2065: 'PDWORD' : undeclared identifier
libreria_thunk_pcwin64.c(100) : error C2100: illegal indirection
libreria_thunk_pcwin64.c(100) : error C2059: syntax error : ')'
libreria_thunk_pcwin64.c(100) : error C2297: '*' : illegal, right operand has type 'const char *'
libreria_thunk_pcwin64.c(101) : error C2065: 'p3' : undeclared identifier
libreria_thunk_pcwin64.c(102) : error C2065: 'p4' : undeclared identifier
libreria_thunk_pcwin64.c(103) : error C2065: 'p4' : undeclared identifier
libreria_thunk_pcwin64.c(104) : error C2146: syntax error : missing ')' before identifier 'HANDLE'
libreria_thunk_pcwin64.c(104) : error C2065: 'HANDLE' : undeclared identifier
libreria_thunk_pcwin64.c(104) : error C2065: 'PVOID' : undeclared identifier
libreria_thunk_pcwin64.c(104) : error C2275: 'uint32' : illegal use of this type as an expression
libreria_thunk_pcwin64.c(104) : error C2065: 'PDWORD' : undeclared identifier
libreria_thunk_pcwin64.c(104) : error C2059: syntax error : ')'
libreria_thunk_pcwin64.c(104) : error C2146: syntax error : missing ';' before identifier 'fcn'
libreria_thunk_pcwin64.c(104) : warning C4033: 'uint32HANDLEPVOIDuint32PDWORDuint32Thunk' must
return a value
libreria_thunk_pcwin64.c(104) : error C2065: 'p0' : undeclared identifier
libreria_thunk_pcwin64.c(104) : error C2065: 'p1' : undeclared identifier
libreria_thunk_pcwin64.c(104) : error C2065: 'p2' : undeclared identifier
libreria_thunk_pcwin64.c(104) : error C2065: 'p3' : undeclared identifier
libreria_thunk_pcwin64.c(104) : error C2065: 'p4' : undeclared identifier
libreria_thunk_pcwin64.c(108) : error C2061: syntax error : identifier 'BOOLHANDLEThunk'
libreria_thunk_pcwin64.c(108) : error C2059: syntax error : ';'
libreria_thunk_pcwin64.c(108) : error C2059: syntax error : 'type'
Como datos adicionales estoy usando matlab version R2011a de 64bits, con el compildaor Microsoft Visual C++ 2010 Express, windows 7 de 64. No se que hacer! Espero puedan ayudarme, muchas gracias!
« Última modificación: 05 de Febrero de 2014, 00:35:23 por betatierradelsur »
