Programa que simula un joystick de u solo boton por puerto USB
Las rutinas de USB se ejecutan medianta la funcion USBDeviceTask()
del stack de Microchip
En este ejemplo se utiliza USB por interrupciones en lugar de polling
#include <xc.h>
// CONFIG1L
#pragma config PLLDIV = 5 // PLL Prescaler Selection bits (Divide by 5 (20 MHz oscillator input))
#pragma config CPUDIV = OSC1_PLL2// System Clock Postscaler Selection bits ([Primary Oscillator Src: /1][96 MHz PLL Src: /2])
#pragma config USBDIV = 2 // USB Clock Selection bit (used in Full-Speed USB mode only; UCFG:FSEN = 1) (USB clock source comes from the 96 MHz PLL divided by 2)
// CONFIG1H
#pragma config FOSC = HSPLL_HS // Oscillator Selection bits (HS oscillator, PLL enabled (HSPLL))
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
// CONFIG2L
#pragma config PWRT = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOR = OFF // Brown-out Reset Enable bits (Brown-out Reset disabled in hardware and software)
#pragma config BORV = 3 // Brown-out Reset Voltage bits (Minimum setting)
#pragma config VREGEN = ON // USB Voltage Regulator Enable bit (USB voltage regulator enabled)
// CONFIG2H
#pragma config WDT = OFF // Watchdog Timer Enable bit (WDT disabled (control is placed on the SWDTEN bit))
#pragma config WDTPS = 32768 // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = ON // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
#pragma config PBADEN = OFF // PORTB A/D Enable bit (PORTB<4:0> pins are configured as digital I/O on Reset)
#pragma config LPT1OSC = OFF // Low-Power Timer 1 Oscillator Enable bit (Timer1 configured for higher power operation)
#pragma config MCLRE = ON // MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
// CONFIG4L
#pragma config STVREN = ON // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = OFF // Single-Supply ICSP Enable bit (Single-Supply ICSP disabled)
#pragma config XINST = OFF // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG5L
#pragma config CP0 = OFF // Code Protection bit (Block 0 (000800-001FFFh) is not code-protected)
#pragma config CP1 = OFF // Code Protection bit (Block 1 (002000-003FFFh) is not code-protected)
#pragma config CP2 = OFF // Code Protection bit (Block 2 (004000-005FFFh) is not code-protected)
#pragma config CP3 = OFF // Code Protection bit (Block 3 (006000-007FFFh) is not code-protected)
// CONFIG5H
#pragma config CPB = OFF // Boot Block Code Protection bit (Boot block (000000-0007FFh) is not code-protected)
#pragma config CPD = OFF // Data EEPROM Code Protection bit (Data EEPROM is not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF // Write Protection bit (Block 0 (000800-001FFFh) is not write-protected)
#pragma config WRT1 = OFF // Write Protection bit (Block 1 (002000-003FFFh) is not write-protected)
#pragma config WRT2 = OFF // Write Protection bit (Block 2 (004000-005FFFh) is not write-protected)
#pragma config WRT3 = OFF // Write Protection bit (Block 3 (006000-007FFFh) is not write-protected)
// CONFIG6H
#pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) are not write-protected)
#pragma config WRTB = OFF // Boot Block Write Protection bit (Boot block (000000-0007FFh) is not write-protected)
#pragma config WRTD = OFF // Data EEPROM Write Protection bit (Data EEPROM is not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF // Table Read Protection bit (Block 0 (000800-001FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF // Table Read Protection bit (Block 1 (002000-003FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF // Table Read Protection bit (Block 2 (004000-005FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF // Table Read Protection bit (Block 3 (006000-007FFFh) is not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF // Boot Block Table Read Protection bit (Boot block (000000-0007FFh) is not protected from table reads executed in other blocks)
#include "HardwareProfile.h"
#include "usb_config.h"
#include "./USB/usb.h"
#include "./USB/usb_function_hid.h"
* Algunas variables
#if defined(__XC8)
#if defined(_18F14K50) || defined(_18F13K50) || defined(_18LF14K50) || defined(_18LF13K50)
#define INPUT_CONTROLS_ADDRESS 0x260
#define HID_REPORT_ADDRESS (INPUT_CONTROLS_ADDRESS + HID_INT_IN_EP_SIZE)
#define INPUT_CONTROLS_ADDRESS_TAG @INPUT_CONTROLS_ADDRESS
#define HID_REPORT_ADDRESS_TAG @HID_REPORT_ADDRESS
#elif defined(_18F2455) || defined(_18F2550) || defined(_18F4455) || defined(_18F4550)\
|| defined(_18F2458) || defined(_18F2453) || defined(_18F4558) || defined(_18F4553)\
|| defined(_18LF24K50) || defined(_18F24K50) || defined(_18LF25K50)\
|| defined(_18F25K50) || defined(_18LF45K50) || defined(_18F45K50)
#define INPUT_CONTROLS_ADDRESS 0x500
#elif defined(_18F4450) || defined(_18F2450)
#define INPUT_CONTROLS_ADDRESS 0x480
#elif defined(_16F1459)
#define INPUT_CONTROLS_ADDRESS 0x2050
#else
#endif
#else
#endif
USB_HANDLE lastTransmission;
unsigned char dato INPUT_CONTROLS_ADDRESS_TAG;
BYTE hid_report[8] HID_REPORT_ADDRESS_TAG;
void ProcesoPersonal(void);
void interrupt high_priority ISR(void)
USBDeviceTasks();
void main(void)
TRISBbits.TRISB7 = 1;
lastTransmission = 0;
USBDeviceInit();
#if defined(USB_INTERRUPT)
USBDeviceAttach();
#endif
while(1)
ProcesoPersonal();
if((USBDeviceState < CONFIGURED_STATE)||(USBSuspendControl==1)) return;
dato = PORTBbits.RB7;
if(!HIDTxHandleBusy(lastTransmission))
lastTransmission = HIDTxPacket(HID_EP, (BYTE*)&dato, sizeof(dato));
// ************** USB Callback Functions ****************************************************************
// The USB firmware stack will call the callback functions USBCBxxx() in response to certain USB related
// events. For example, if the host PC is powering down, it will stop sending out Start of Frame (SOF)
// packets to your device. In response to this, all USB devices are supposed to decrease their power
// consumption from the USB Vbus to <2.5mA* each. The USB module detects this condition (which according
// to the USB specifications is 3+ms of no bus activity/SOF packets) and then calls the USBCBSuspend()
// function. You should modify these callback functions to take appropriate actions for each of these
// conditions. For example, in the USBCBSuspend(), you may wish to add code that will decrease power
// consumption from Vbus to <2.5mA (such as by clock switching, turning off LEDs, putting the
// microcontroller to sleep, etc.). Then, in the USBCBWakeFromSuspend() function, you may then wish to
// add code that undoes the power saving things done in the USBCBSuspend() function.
// The USBCBSendResume() function is special, in that the USB stack will not automatically call this
// function. This function is meant to be called from the application firmware instead. See the
// additional comments near the function.
// Note *: The "usb_20.pdf" specs indicate 500uA or 2.5mA, depending upon device classification. However,
// the USB-IF has officially issued an ECN (engineering change notice) changing this to 2.5mA for all
// devices. Make sure to re-download the latest specifications to get all of the newest ECNs.
* Function: void USBCBSuspend(void)
* PreCondition: None
* Input: None
* Output: None
* Side Effects: None
* Overview: Call back that is invoked when a USB suspend is detected
* Note: None
//Example power saving code. Insert appropriate code here for the desired
//application behavior. If the microcontroller will be put to sleep, a
//process similar to that shown below may be used:
//ConfigureIOPinsForLowPower();
//SaveStateOfAllInterruptEnableBits();
//DisableAllInterruptEnableBits();
//EnableOnlyTheInterruptsWhichWillBeUsedToWakeTheMicro(); //should enable at least USBActivityIF as a wake source
//Sleep();
//RestoreStateOfAllPreviouslySavedInterruptEnableBits(); //Preferrably, this should be done in the USBCBWakeFromSuspend() function instead.
//RestoreIOPinsToNormal(); //Preferrably, this should be done in the USBCBWakeFromSuspend() function instead.
//Alternatively, the microcontorller may use clock switching to reduce current consumption.
#if defined(__18CXX)
//Configure device for low power consumption
//mLED_1_Off();
//mLED_2_Off();
//Should also configure all other I/O pins for lowest power consumption.
//Typically this is done by driving unused I/O pins as outputs and driving them high or low.
//In this example, this is not done however, in case the user is expecting the I/O pins
//to remain tri-state and has hooked something up to them.
//Leaving the I/O pins floating will waste power and should not be done in a
//real application.
//Note: The clock switching code needed is processor specific, as the
//clock trees and registers aren't identical accross all PIC18 USB device
//families.
#if defined(PIC18F97J94_FAMILY)
OSCCON = 0x06; //FRC / 16 = 500kHz selected.
#else
OSCCON = 0x13; //Sleep on sleep, 125kHz selected as microcontroller clock source
#endif
#endif
//IMPORTANT NOTE: Do not clear the USBActivityIF (ACTVIF) bit here. This bit is
//cleared inside the usb_device.c file. Clearing USBActivityIF here will cause
//things to not work as intended.
* Function: void USBCBWakeFromSuspend(void)
* Input: None
* Output: None
* Overview: The host may put USB peripheral devices in low power
* suspend mode (by "sending" 3+ms of idle). Once in suspend
* mode, the host may wake the device back up by sending non-
* idle state signalling.
* This call back is invoked when a wakeup from USB suspend
* is detected.
* Note: None
// If clock switching or other power savings measures were taken when
// executing the USBCBSuspend() function, now would be a good time to
// switch back to normal full power run mode conditions. The host allows
// 10+ milliseconds of wakeup time, after which the device must be
// fully back to normal, and capable of receiving and processing USB
// packets. In order to do this, the USB module must receive proper
// clocking (IE: 48MHz clock must be available to SIE for full speed USB
// operation).
// Make sure the selected oscillator settings are consistant with USB operation
// before returning from this function.
//Switch clock back to main clock source necessary for USB operation
//Previous clock source was something low frequency as set in the
//USBCBSuspend() function.
OSCCON3 = 0x01; //8MHz FRC / 2 = 4MHz output
OSCCON = 0x01; //FRC with PLL selected
while(OSCCON2bits.LOCK == 0); //Wait for PLL lock
#elif defined(PIC18F45K50_FAMILY)
OSCCON = 0x70; //Switch to 16MHz HFINTOSC (+ PLL)
while(OSCCON2bits.PLLRDY != 1); //Wait for PLL lock
#else
OSCCON = 0x60; //Primary clock source selected.
//Adding a software start up delay will ensure
//that the primary oscillator and PLL are running before executing any other
//code. If the PLL isn't being used, (ex: primary osc = 48MHz externally applied EC)
//then this code adds a small unnecessary delay, but it is harmless to execute anyway.
unsigned int pll_startup_counter = 800; //Long delay at 31kHz, but ~0.8ms at 48MHz
while(pll_startup_counter--); //Clock will switch over while executing this delay loop
#endif
#endif
* Function: void USBCB_SOF_Handler(void)
* Input: None
* Output: None
* Overview: The USB host sends out a SOF packet to full-speed
* devices every 1 ms. This interrupt may be useful
* for isochronous pipes. End designers should
* implement callback routine as necessary.
* Note: None
// No need to clear UIRbits.SOFIF to 0 here.
// Callback caller is already doing that.
* Function: void USBCBErrorHandler(void)
* Input: None
* Output: None
* Overview: The purpose of this callback is mainly for
* debugging during development. Check UEIR to see
* which error causes the interrupt.
* Note: None
// No need to clear UEIR to 0 here.
// Typically, user firmware does not need to do anything special
// if a USB error occurs. For example, if the host sends an OUT
// packet to your device, but the packet gets corrupted (ex:
// because of a bad connection, or the user unplugs the
// USB cable during the transmission) this will typically set
// one or more USB error interrupt flags. Nothing specific
// needs to be done however, since the SIE will automatically
// send a "NAK" packet to the host. In response to this, the
// host will normally retry to send the packet again, and no
// data loss occurs. The system will typically recover
// automatically, without the need for application firmware
// intervention.
// Nevertheless, this callback function is provided, such as
// for debugging purposes.
* Function: void USBCBCheckOtherReq(void)
* Input: None
* Output: None
* Overview: When SETUP packets arrive from the host, some
* firmware must process the request and respond
* appropriately to fulfill the request. Some of
* the SETUP packets will be for standard
* USB "chapter 9" (as in, fulfilling chapter 9 of
* the official USB specifications) requests, while
* others may be specific to the USB device class
* that is being implemented. For example, a HID
* class device needs to be able to respond to
* "GET REPORT" type of requests. This
* is not a standard USB chapter 9 request, and
* therefore not handled by usb_device.c. Instead
* this request should be handled by class specific
* firmware, such as that contained in usb_function_hid.c.
* Note: None
USBCheckHIDRequest();
}//end
* Function: void USBCBStdSetDscHandler(void)
* Input: None
* Output: None
* Overview: The USBCBStdSetDscHandler() callback function is
* called when a SETUP, bRequest: SET_DESCRIPTOR request
* arrives. Typically SET_DESCRIPTOR requests are
* not used in most applications, and it is
* optional to support this type of request.
* Note: None
// Must claim session ownership if supporting this request
}//end
* Function: void USBCBInitEP(void)
* Input: None
* Output: None
* Overview: This function is called when the device becomes
* initialized, which occurs after the host sends a
* SET_CONFIGURATION (wValue not = 0) request. This
* callback function should initialize the endpoints
* for the device's usage according to the current
* configuration.
* Note: None
//enable the HID endpoint
USBEnableEndpoint(HID_EP,USB_OUT_ENABLED|USB_IN_ENABLED|USB_HANDSHAKE_ENABLED|USB_DISALLOW_SETUP);
* Function: void USBCBSendResume(void)
* Input: None
* Output: None
* Overview: The USB specifications allow some types of USB
* peripheral devices to wake up a host PC (such
* as if it is in a low power suspend to RAM state).
* This can be a very useful feature in some
* USB applications, such as an Infrared remote
* control receiver. If a user presses the "power"
* button on a remote control, it is nice that the
* IR receiver can detect this signalling, and then
* send a USB "command" to the PC to wake up.
* The USBCBSendResume() "callback" function is used
* to send this special USB signalling which wakes
* up the PC. This function may be called by
* application firmware to wake up the PC. This
* function will only be able to wake up the host if
* all of the below are true:
* 1. The USB driver used on the host PC supports
* the remote wakeup capability.
* 2. The USB configuration descriptor indicates
* the device is remote wakeup capable in the
* bmAttributes field.
* 3. The USB host PC is currently sleeping,
* and has previously sent your device a SET
* FEATURE setup packet which "armed" the
* remote wakeup capability.
* If the host has not armed the device to perform remote wakeup,
* then this function will return without actually performing a
* remote wakeup sequence. This is the required behavior,
* as a USB device that has not been armed to perform remote
* wakeup must not drive remote wakeup signalling onto the bus;
* doing so will cause USB compliance testing failure.
* This callback should send a RESUME signal that
* has the period of 1-15ms.
* Note: This function does nothing and returns quickly, if the USB
* bus and host are not in a suspended condition, or are
* otherwise not in a remote wakeup ready state. Therefore, it
* is safe to optionally call this function regularly, ex:
* anytime application stimulus occurs, as the function will
* have no effect, until the bus really is in a state ready
* to accept remote wakeup.
* When this function executes, it may perform clock switching,
* depending upon the application specific code in
* USBCBWakeFromSuspend(). This is needed, since the USB
* bus will no longer be suspended by the time this function
* returns. Therefore, the USB module will need to be ready
* to receive traffic from the host.
* The modifiable section in this routine may be changed
* to meet the application needs. Current implementation
* temporary blocks other functions from executing for a
* period of ~3-15 ms depending on the core frequency.
* According to USB 2.0 specification section 7.1.7.7,
* "The remote wakeup device must hold the resume signaling
* for at least 1 ms but for no more than 15 ms."
* The idea here is to use a delay counter loop, using a
* common value that would work over a wide range of core
* frequencies.
* That value selected is 1800. See table below:
* Core Freq(MHz) MIP RESUME Signal Period (ms)
* 48 12 1.05
* 4 1 12.6
* * These timing could be incorrect when using code
* optimization or extended instruction mode,
* or when having other interrupts enabled.
* Make sure to verify using the MPLAB SIM's Stopwatch
* and verify the actual signal on an oscilloscope.
static WORD delay_count;
//First verify that the host has armed us to perform remote wakeup.
//It does this by sending a SET_FEATURE request to enable remote wakeup,
//usually just before the host goes to standby mode (note: it will only
//send this SET_FEATURE request if the configuration descriptor declares
//the device as remote wakeup capable, AND, if the feature is enabled
//on the host (ex: on Windows based hosts, in the device manager
//properties page for the USB device, power management tab, the
//"Allow this device to bring the computer out of standby." checkbox
//should be checked).
if(USBGetRemoteWakeupStatus() == TRUE)
//Verify that the USB bus is in fact suspended, before we send
//remote wakeup signalling.
if(USBIsBusSuspended() == TRUE)
USBMaskInterrupts();
//Clock switch to settings consistent with normal USB operation.
USBCBWakeFromSuspend();
USBSuspendControl = 0;
USBBusIsSuspended = FALSE; //So we don't execute this code again,
//until a new suspend condition is detected.
//Section 7.1.7.7 of the USB 2.0 specifications indicates a USB
//device must continuously see 5ms+ of idle on the bus, before it sends
//remote wakeup signalling. One way to be certain that this parameter
//gets met, is to add a 2ms+ blocking delay here (2ms plus at
//least 3ms from bus idle to USBIsBusSuspended() == TRUE, yeilds
//5ms+ total delay since start of idle).
delay_count = 3600U;
do
delay_count--;
}while(delay_count);
//Now drive the resume K-state signalling onto the USB bus.
USBResumeControl = 1; // Start RESUME signaling
delay_count = 1800U; // Set RESUME line for 1-13 ms
do
delay_count--;
USBResumeControl = 0; //Finished driving resume signalling
USBUnmaskInterrupts();
* Function: BOOL USER_USB_CALLBACK_EVENT_HANDLER(
* int event, void *pdata, WORD size)
* Input: int event - the type of event
* void *pdata - pointer to the event data
* WORD size - size of the event data
* Output: None
* Overview: This function is called from the USB stack to
* notify a user application that a USB event
* occured. This callback is in interrupt context
* when the USB_INTERRUPT option is selected.
* Note: None
BOOL USER_USB_CALLBACK_EVENT_HANDLER(USB_EVENT event, void *pdata, WORD size)
switch( event )
case EVENT_TRANSFER:
//Add application specific callback task or callback function here if desired.
break;
case EVENT_SOF:
USBCB_SOF_Handler();
break;
case EVENT_SUSPEND:
USBCBSuspend();
break;
case EVENT_RESUME:
break;
case EVENT_CONFIGURED:
USBCBInitEP();
break;
case EVENT_SET_DESCRIPTOR:
USBCBStdSetDscHandler();
break;
case EVENT_EP0_REQUEST:
USBCBCheckOtherReq();
break;
case EVENT_BUS_ERROR:
USBCBErrorHandler();
break;
case EVENT_TRANSFER_TERMINATED:
//The EVENT_TRANSFER_TERMINATED event occurs when the host performs a CLEAR
//FEATURE (endpoint halt) request on an application endpoint which was
//previously armed (UOWN was = 1). Here would be a good place to:
//1. Determine which endpoint the transaction that just got terminated was
// on, by checking the handle value in the *pdata.
//2. Re-arm the endpoint if desired (typically would be the case for OUT
// endpoints).
break;
default:
break;
return TRUE;
