Hola buenas,
Tengo este simple codigo:
// FUNCION PRINCIPAL
#include <xc.h>
#include <delays.h>
#define _XTAL_FREQ 4000000
// PIC16F819 Configuration Bit Settingsbvdfg
// PIC16F648A Configuration Bit Settings
#define config INTOSC = ON // Oscillator Selection bits (INTOSC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN)
#pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = OFF // RA5/MCLR/VPP Pin Function Select bit (RA5/MCLR/VPP pin function is digital input, MCLR internally tied to VDD)
#pragma config BOREN = ON // Brown-out Detect Enable bit (BOD enabled)
#pragma config LVP = OFF // Low-Voltage Programming Enable bit (RB4/PGM pin has digital I/O function, HV on MCLR must be used for programming)
#pragma config CPD = OFF // Data EE Memory Code Protection bit (Data memory code protection off)
#pragma config CP = OFF
void main(void)
int i;
//config
ANSELH=0;
ANSEL=0;
TRISA=0xFF;
TRISB=0x0;
Delay10TCY(20);
PORTB=0x0;
for(;;){
if(RA0 == 1){
PORTB=0x0;
}else{
PORTB=1;
for(i=0;i<=4;i++){
PORTB=PORTB<<1;
__delay_ms(1000);
Y meda este error:
:: warning: Omniscient Code Generation not available in Free mode
:0: error: undefined symbol:
_Delay10TCY(dist/default/production\tuto_C18.X.production.obj)
(908) exit status = 1
make[2]: *** [dist/default/production/tuto_C18.X.production.hex] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
make[2]: Leaving directory `C:/Users/Limbo/MPLABXProjects/tuto_C18.X'
make[1]: Leaving directory `C:/Users/Limbo/MPLABXProjects/tuto_C18.X'
BUILD FAILED (exit value 2, total time: 5s)
Me tiene loco, estoy usando _delay y __delay_ms, pero quiero saber porque falla eso...
Hola ...si es un pic 16f819 ..los pragma estan mal....deberian estar asi
#pragma config FOSC = INTOSCCLK // Oscillator Selection bits (INTRC oscillator; CLKO function on RA6/OSC2/CLKO pin and port I/O function on RA7/OSC1/CLKI pin)
#pragma config PWRTE = ON // Power-up Timer Enable bit (PWRT enabled)
#pragma config MCLRE = OFF // RA5/MCLR/VPP Pin Function Select bit (RA5/MCLR/VPP pin function is digital I/O, MCLR internally tied to VDD)
#pragma config BOREN = OFF // Brown-out Reset Enable bit (BOR disabled)
#pragma config LVP = OFF // Low-Voltage Programming Enable bit (RB3/PGM pin has digital I/O function, HV on MCLR must be used for programming)
#pragma config CPD = OFF // Data EE Memory Code Protection bit (Code protection off)
#pragma config WRT = OFF // Flash Program Memory Write Enable bits (Write protection off)
#pragma config CCPMX = RB2 // CCP1 Pin Selection bit (CCP1 function on RB2)
#pragma config CP = OFF // Flash Program Memory Code Protection bit (Code protection off)
Fijate que en mplab podes definirlos desde windows/pics memori view / configuration bits
una vez que lo hiciste apretas el boton generar source code to output y listo copias y pegas
