list p=16F690 ; list directive to define processor
#include <p16F690.inc> ; processor specific variable definitions
errorlevel -302 ; suppress message 302 from list file
__CONFIG _CP_OFF & _CPD_OFF & _BOR_OFF & _MCLRE_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT & _FCMEN_OFF & _IESO_OFF
; '__CONFIG' directive is used to embed configuration word within .asm file.
; The lables following the directive are located in the respective .inc file.
; See data sheet for additional information on configuration word settings.
;***** VARIABLE DEFINITIONS (examples)
; example of using Shared Uninitialized Data Section
INT_VAR UDATA 0x30
rOC RES 1 ; variable used for context saving
rOD RES 1 ; variable used for context saving
r13 RES 1 ; lugar de almacenaje del retardo
e equ 1h ;el pin RA1
rs equ 2h ;el pin RA2
r equ 1h ;almacena en el mismo registro
w equ 0h ;almacena en el acumulador
RESET_VECTOR CODE 0x000 ; processor reset vector
goto main ; go to beginning of program
CODE 0x05
;*****************Bloque de control y retado*****************************
;*************En este bloque esta la subrutina que crea un retardo***********
;************** al enviar comandos o datos al LCD****************************
;***************SUBRUTINA DE RETARDO*************************************
retardo
movlw 0xFF
movwf r13 ;contador de retadrdo
decre decfsz r13,r ;genera un retardo de aproximadamente
goto decre ;3*256 microsegundos.
retlw 0
;******ENVIO DE CONTROLES O DATOS*************************************
;****Para el envio de un comando*******************************************
;**rs=0**********************************************************
;**R/W=0****************************************************
;**e=1**********************************************
;****Para el envio de un dato***********************************************
;**rs=1*********************************************
control
bcf PORTA,rs ;se prepara para enviar se?ales de control
goto dato2 ;va a enviar el comando
dato bsf PORTA,rs ;se prepara para enviar un dato
dato2 bsf PORTA,e ;va a enviar lo que se haya desidido
;habilita
movwf PORTC
call retardo
call retardo
call retardo
bcf PORTA,e ;deshabilita
call retardo
retlw 0
main
;Inicializaci?n de los puertos, recuerde que los bits PA1 y PA2 se utilizaran para******
;las se?ales de control ?e? y ?rs?respectivamentes por lo que deben ser *****************
;programados como salidas****************************************************************
;***********Inicializaci?n puerto A, puesta en Cero del puerto*********
BCF STATUS,RP0
BCF STATUS,RP1
CLRF PORTA
BSF STATUS,RP1
CLRF ANSEL
BCF STATUS,RP1
BSF STATUS,RP0
CLRF TRISA
BCF STATUS,RP0
clrf PORTA
;************************INICIALIZA PUERTO C*****************************
BCF STATUS,RP0 ;Cambia al banco 0
BCF STATUS,RP1
CLRF PORTC ;Inicializa el puerto C
BSF STATUS,RP1 ;Cambia el banco 2 para poner los purtos como digitales
CLRF ANSEL ;Digital I/O
CLRF ANSELH
BCF STATUS,RP1 ;Ahora se cambia al banco 1 para programar a TRISC
BSF STATUS,RP0
MOVLW 0x00
MOVWF TRISC ;Todas en salida
BCF STATUS,RP0 ;Se regresa al banco 0 para programar al puerto C
BCF STATUS,RP1
CLRF PORTC ;esta instrucci?n se pudiera quitar, se dejo por seguridad
;***********************PROGRAMA PRINCIPAL**********************************************
;inicializaci?n del LCD
movlw 0x0F ;DISPLAY ON/OFF CONTROL
call control
call retardo
movlw 0x01 ;CLEAR DISPLAY
call control
call retardo
movlw 0x06 ;ENTRY MODE SET
call control
call retardo
movlw 0x34 ;FUNCTION SET
call control
call retardo
;************************MENSAJE*************************************
movlw " "
call dato
call retardo
movlw "R" ;Mensaje
call dato
call retardo
movlw "I" ;Mensaje
call dato
call retardo
movlw "C" ;Mensaje
call dato
call retardo
movlw "A" ;Mensaje
call dato
call retardo
movlw "R" ;Mensaje
call dato
call retardo
movlw "D" ;Mensaje
call dato
call retardo
movlw "O" ;Mensaje
call dato
call retardo
movlw " " ;Mensaje
call dato
call retardo
movlw "F" ;Mensaje
call dato
call retardo
movlw "E" ;Mensaje
call dato
call retardo
movlw "R" ;Mensaje
call dato
call retardo
movlw "R" ;Mensaje
call dato
call retardo
movlw "E" ;Mensaje
call dato
call retardo
movlw "R" ;Mensaje
call dato
call retardo
movlw " " ;Mensaje
call dato
call retardo
END ; directive 'end of program'
Este es el programa que he utilizado pero no puedo poner que se vea la segunda linea del LCD, e intentado cambiar el lugar donde se guardan los datos o configurar otra rutina de control pero no he podido, si me pudieran ayudar, gracias.
