Gracias khasistos por tu respuesta!
En realidad lo que me pasas esta correcto pero para displays a led, yo ya tenia utilizado rutinas parecidas a lo que planteas pero me di cuenta de que los LCD no funcionan de la misma manera.
Te paso el datasheet y una info mas para ver si vos entendes algo que ami se me esta pasando!!!
Static Drive LCD Technology
The configuration for Liquid Crystal Display Static Drive technique is that one side of all of the Liquid Crystal Display segments are tied to a common, or backplane, and the other side of each of the segments are routed to individual connection points that are tied to the driver control circuitry. This method uses a large number of interconnects and is not feasible for complex displays, but it does produce the best looking display.
LCD"s require an AC drive voltage with virtually no DC component. Segments are controlled by the magnitude of the AC voltage across the LCD segment, but there must always be AC voltage across ALL segments of the LCD. Prolonged DC operation may cause electrochemical reactions inside the displays which will cause significantly reduced life. The initial indications of display degradation because of excessive DC current is a loss of alignment along the edges of some of the characters. The visual indication will be a "fuzzy" appearance of some of the characters.
The TN LCD is an RMS voltage responsive device, that is, the contrast of a given segment is dependent upon the RMS value of the applied voltage across it, measured with respect to the common plane. This fact, which seems obvious now, is very important when discussing drive schemes.
Drive frequencies for direct drive displays are typically between 30Hz and 100Hz. Depending on the display size and design, displays can be operated at higher frequencies, but this will result in increased power consumption. LCDs portray a capacitive load, which reduces the load impedance as frequency increases. However, operation below 30Hz typically results in display flicker
LCD"s can be overdriven by a combination of voltage and frequency, which will result in cross talk or "ghosting". Ghosting is the appearance or partial activation of an "off" segment. This condition occurs when high drive voltage and frequency are applied. Since the current is directly proportional to the frequency, there is a voltage-frequency product which must not be exceeded. These values are very dependent on the design and layout of any given part, so proper display design and choice of driving conditions is important. It is also very important that all unused segments be connected to the backplane, and not allowed to float.
En este link te paso el datasheet del LCD:
http://www.pacificdisplay.com/glass/PD-302.pdfBueno un abrazo y gracias por la ayuda muchachos
Tony
