Autor Tema: Problema p18f452, ENC20j60 y Mikrobasic - Cuelgo y Falla en Reset  (Leído 2662 veces)
Desconectado Fhrozen
« en: 22 de Febrero de 2013, 20:12:06 »
Buenas Tardes a todos:
Me encuentro diseñando un sistema de alarmas empleando ethernet, que funcione 24/7.
El sistema esta diseñado empleando un Micro P18f452, y un modulo ethernet de la empresa geeetech.
El problema que tengo es que despues de un cierto tiempo el Modulo ethernet se apaga, incluso recibiendo informacion, y a pesar de haber implementado una rutina para reseteo en caso de no haber datos, este no se ejecuta, y el micro se cuelga, a pesar de estar activo el Watchdog.
No se si podrian darme una manito en este problema
Adjunto el diseño y el codigo, estoy empleando el mikrobasic pro for pic y una libreria instalada para uso del enc.. la libreria Net_enc, descargada del libstock.
program remoto52nt1
include images
include http_utils
include webpage
dim
  Net_Ethernet_28j60_Rst  as sbit at RC0_bit
  Net_Ethernet_28j60_CS  as sbit at RC1_bit
  Net_Ethernet_28j60_Rst_Direction  as sbit at TRISC0_bit
  Net_Ethernet_28j60_CS_Direction  as sbit at TRISC1_bit
  LED_OP     as sbit at RD4_bit
        LED_TX     as sbit at RD5_bit
        LED_RX     as sbit at RD6_bit
        SPI_INT    as sbit at RC2_bit
        SPI_WOL    as sbit at RC3_bit
        OU_01      as sbit at RB0_bit
        OU_02      as sbit at RB1_bit
        OU_03      as sbit at RB2_bit
        OU_04      as sbit at RB3_bit
        IN_01      as sbit at RB4_bit
        IN_02      as sbit at RB5_bit
        IN_03      as sbit at RB6_bit
        IN_04      as sbit at RB7_bit
' Declarations section
dim myMacAddr   as byte[6]   ' my MAC address
    myIpAddr    as byte[4]   ' my IP address
    gwIpAddr    as byte[4]   ' gateway (router) IP address
    ipMask      as byte[4]   ' network mask (for example : 255.255.255.0)
    dnsIpAddr   as byte[4]   ' DNS server IP address
dim
     datoeeprom  as byte
    dhcp_enable as byte
Const TipMod as String[7] = "CENTRAL"
dim counter      as integer
    counter2     as integer
    ver1         as boolean
    ver2         as boolean
    PortJob      as word
    i            as byte
    TipoAlarm    as byte
dim
    send_mark1, send_mark2, send_mark3, send_mark4, sendHTML_mark as byte
    socketImage1, socketImage2, socketImage3, socketImage4, socketHTML as ^SOCKET_28j60_Dsc
    pos as word[NUM_OF_SOCKET_28j60]
sub procedure Net_Ethernet_28j60_UserTCP(dim socket as ^SOCKET_28j60_Dsc)
end sub
sub function Net_Ethernet_28j60_UserUDP(dim udpDsc as ^UDP_28j60_Dsc) as word
 dim     value      as char[9]
         compar     as string[7]
         hx         as char
         Output     as byte
         l          as byte
         res        as byte
        tmp as string[5]
  result = 0
  LED_OP = 1
  if (udpDsc^.destPort = PortJob) then
     LED_RX = 1
     asm
           CLRWDT         ' asm line, clear WatchDog Timer
     end asm
     for l = 0 to 7
           value[l] =  Net_Ethernet_28j60_getByte()
           if value[0] <> "_" then
              LED_OP = 0
              LED_RX = 0
              asm
              end asm
             ' exit
           end if
           asm
           end asm
           if l = 7 then
              hx = value[l]
           end if
     next l
     asm
     end asm
     compar = "_MCL-D-"
     res = strspn(value,compar)
     asm
     end asm
     if (res = 7) then
        OutPut =  hx - 97
        Select Case Output
               Case 0
                    Counter2 = 0
                    If ver1 or ver2 then
                       TipoAlarm = 0
                       GIE_bit = 1           ' Enable global interrupt
                       TMR0IE_bit = 1          ' Enable Timer0 Interrupt
                       T0CON         = 0x86
                       TMR0H         = 0x67
                       TMR0L         = 0x67
                       counter = 0
                       OU_03 = 0
                       asm
                       end asm
                    end if
                    OU_01 = 1
                    OU_02 = 1
                    ver1 = false
                    ver2 = false
                    asm
                    end asm
               Case 1
                    counter2 = 0
                    if not ver1 then
                       TipoAlarm = 1
                       T0CON         = 0x86
                       TMR0H         = 0x67
                       TMR0L         = 0x67
                       counter = 0
                       OU_03 = 0
                       asm
                       end asm
                    end if
                    OU_01 = 0
                    OU_02 = 1
                    ver1 = true
                    asm
                    end asm
                    ver2 = false
               Case 2
                    counter2 = 0
                    if not ver2 then
                       TipoAlarm = 1
                       T0CON         = 0x86
                       TMR0H         = 0x67
                       TMR0L         = 0x67
                       counter = 0
                       OU_03 = 0
                       asm
                       end asm
                    end if
                    OU_01 = 1
                    OU_02 = 0
                    ver2 = true
                    ver1 = false
                    asm
                    end asm
        End Select
        goto fin
     end if
     compar = "_DPC"
     asm
     end asm
     if (res = 4) then
     end if
fin:
     'Net_Ethernet_28j60_putBytes(@value, 9)
     'Net_Ethernet_28j60_putBytes(hx, 1)
     LED_RX = 0
     'result = 29 + udpDsc^.dataLength
     asm
     end asm
  end if
  result = 0
  LED_OP = 0
  asm
     end asm
end  sub
sub procedure InitGlobals()
        for i = 0 to 5
            myMacAddr[i] = EEPROM_Read(0x20 + i)
            asm
            end asm
        next i
        If dhcp_enable = 1 then
              ' * if you have a DHCP server, ip address 0.0.0.0 means DCHP request,
              ' * otherwise, set your IP address here :
              myipAddr[0]  = 0
              myipAddr[1]  = 0
              myipAddr[2]  = 0
              myipAddr[3]  = 0
              asm
     end asm
        else
              ' * if you don't have a DHCP server, put your network settings here
              for i = 0 to 3
              asm
              end asm
                  myIpAddr[i]  = EEPROM_Read(0x02 + i)
                  gwIpAddr[i]  = EEPROM_Read(0x07 + i)
                  dnsIpAddr[i] = EEPROM_Read(0x0C + i)
                  ipMask[i]    = EEPROM_Read(0x10 + i)
              next i
        end if
end sub
sub procedure Interrupt()
  Inc(counter2)
  TMR0IF_bit = 0          ' Set T0IE, clear T0IF
  T0CON         = 0x86
  TMR0H         = 0x67
  TMR0L         = 0x67
  asm
  end asm
  if Counter2 > 120 then
       GIE_bit = 0            ' Disable global interrupt
       TMR0IE_bit = 0          ' Disable Timer0 Interrupt
       delay_ms(2000)
  end if
  Select Case TipoAlarm
         Case 0
             Inc(counter)            ' Increment value of counter on every Interrupt
             OU_03 = OU_03 xor 1
             asm
             end asm
             if (counter > 5) then
                 OU_03 = 1      ' Apaga la Alarma
                 counter = 0    ' Reset counter
                 asm
                 end asm
                 TipoAlarm = 2
             end if
         Case 1
             if (counter > 60 ) then
                  asm
                  end asm
                   TipoAlarm = 2
              end if
  End Select
  asm
  end asm
end sub
dim j as char
main:
'   Main program
  asm
  end asm
  TRISA = $00
  PORTA = $00
  TRISB = $F0
  PORTB = $0F
  asm
  end asm
  TRISD = $00
  PORTD = $00
  TRISE = $00
  PORTE = $00
  asm
  end asm
  Counter2 = 0
  TipoAlarm = 2
  TMR0L = 0               ' Timer0 initial value
  T0CON = 0xC7            ' Set TMR0 to 8bit mode and prescaler to 256
  GIE_bit = 1            ' Disable global interrupt
  TMR0IE_bit = 1          ' Disable Timer0 interrupt
  LED_OP = 1
  LED_TX = 1
  LED_RX = 1
  asm
  end asm
  OU_01 = 1
  OU_02 = 1
  OU_03 = 1
  OU_04 = 1
  ver1 = false
  ver2 = false
  dhcp_enable = EEPROM_Read(0x00)
   InitGlobals()
   asm
  end asm
   'datoeeprom = EEPROM_Read(0x15)
  'PortJob = datoeeprom
  'datoeeprom = EEPROM_Read(0x16)
  'PortJob = PortJob   + datoeeprom*0x100
  PortJob = EEPROM_Read(0x15) + EEPROM_Read(0x16)*0x100
  asm
  end asm
'   * starts ENC28J60 with :
'   * reset bit on PORTC.C0
'   * CS bit on PORTC.C1
'   * my MAC & IP address
'   * full duplex
  for j = 0 to (NUM_OF_SOCKET_28j60 - 1)
          pos[j] = 0
  next j
  asm
  end asm
  LED_RX = 0
  LED_TX = 0
  Net_Ethernet_28j60_stackInitTCP()
  asm
  end asm
  SPI1_Init()
   asm
  end asm
  Net_Ethernet_28j60_Init(@myMacAddr, @myIpAddr, Net_Ethernet_28j60_FULLDUPLEX)  ' init ethernet board
  asm
  end asm
    if dhcp_enable = 1 then
        while(Net_Ethernet_28j60_initDHCP(5) = 0)
        asm
        end asm
        LED_OP = (LED_OP) xor 1
        wend ' try to get one from DHCP until it works
        ' * read network parameters if neccessary
        ' * by copying them into your globals,
        ' * do NOT modify the contents of the locations pointed to
        ' * by pointers which are returned by the below Spi_Ethernet_get routines
        asm
        end asm
        memcpy(@myipAddr,    Net_Ethernet_28j60_getIpAddress(),    4)  ' get assigned IP address
        asm
        end asm
        memcpy(@ipMask,    Net_Ethernet_28j60_getIpMask(),       4)  ' get assigned IP mask
        asm
        end asm
        memcpy(@gwIpAddr,  Net_Ethernet_28j60_getGwIpAddress(),  4)  ' get assigned gateway IP address
        asm
        end asm
        memcpy(@dnsIpAddr, Net_Ethernet_28j60_getDnsIpAddress(), 4)  ' get assigned dns IP address
        asm
        end asm
  else
       asm
        end asm
        Net_Ethernet_28j60_confNetwork(@ipMask, @gwIpAddr, @dnsIpAddr)  ' use configured IP address
  end if
  asm
  end asm
  Delay_ms(100)
  asm
  end asm
  LED_OP = 0
  while(1)
    '  Process incoming Ethernet packets
    LED_TX = 1
    Net_Ethernet_28j60_doPacket()
    LED_RX = 0
    asm
    end asm
  wend
end.
