//main.h
#include <18F2550.h>
#device adc=8
#FUSES NOWDT //No Watch Dog Timer
#FUSES WDT128 //Watch Dog Timer uses 1:128 Postscale
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOPROTECT //Code not protected from reading
#FUSES NOBROWNOUT //No brownout reset
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES NOPUT //No Power Up Timer
#FUSES NOCPD //No EE protection
#FUSES STVREN //Stack full/underflow will cause reset
#FUSES NODEBUG //No Debug mode for ICD
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT //Program memory not write protected
#FUSES NOWRTD //Data EEPROM not write protected
#FUSES IESO //Internal External Switch Over mode enabled
#FUSES FCMEN //Fail-safe clock monitor enabled
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES NOWRTC //configuration not registers write protected
#FUSES NOWRTB //Boot block not write protected
#FUSES NOEBTR //Memory not protected from table reads
#FUSES NOEBTRB //Boot block not protected from table reads
#FUSES NOCPB //No Boot Block code protection
#FUSES MCLR //Master Clear pin enabled
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES NOXINST //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES PLL12 //Divide By 12(48MHz oscillator input)
#FUSES CPUDIV4 //System Clock by 4
#FUSES USBDIV //USB clock source comes from PLL divide by 2
#FUSES NOVREGEN //USB voltage regulator disabled
#use delay(clock=20000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
//#use fast_io(A)
#define SS2 A5
#define SS2 A3
//main.c
#include "C:\spi_pic18F2550\master_04_01\main.h"
int taBCD[]={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15};
int dato; //variable entera que sirve para que , al incrementar, vaya variando el dato.
void main()
//int cnt=0;
setup_adc_ports(NO_ANALOGS|VSS_VDD);
setup_adc(ADC_CLOCK_DIV_2);
setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_16);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_3(T3_DISABLED|T3_DIV_BY_1);
setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
// TODO: USER CODE!!
// deshabilito la secion de esclavo con ssx=1
output_high(SS1);
output_high(SS2);
delay_ms(200);
while(true) {
for(dato=0;dato<10;dato++) {
// detecta numero par-impar
if(bit_test(dato,0)==1){
output_low(SS1); // activo esclavo 1
spi_write(taBCD[dato]);
delay_ms(300);
output_low(SS1); // desactivo esclavo 1
if(bit_test(dato,0)==0){
output_low(SS2); //activo esclavo 2
delay_ms(300);
output_high(SS2); //desactivo esclo 2
}//fin for
// dato=0;
} //fin while
