//18F2550.h
//////// Standard Header file for the PIC18F2550 device ////////////////
#device PIC18F2550
#nolist
//////// Program memory: 16384x16 Data RAM: 2048 Stack: 31
//////// I/O: 23 Analog Pins: 10
//////// Data EEPROM: 256
//////// C Scratch area: 00 ID Location: 200000
//////// Fuses: XT,XTPLL,EC_IO,EC,ECPIO,ECPLL,INTRC_IO,INTRC,PROTECT
//////// Fuses: NOPROTECT,BROWNOUT_NOSL,BROWNOUT_SW,NOBROWNOUT,BROWNOUT,WDT1
//////// Fuses: WDT2,WDT4,WDT8,WDT16,WDT32,WDT64,WDT128,WDT,NOWDT,BORV20
//////// Fuses: BORV28,BORV43,BORV46,PUT,NOPUT,CPD,NOCPD,NOSTVREN,STVREN
//////// Fuses: NODEBUG,DEBUG,NOLVP,LVP,WRT,NOWRT,WRTD,NOWRTD,IESO,NOIESO
//////// Fuses: FCMEN,NOFCMEN,PBADEN,NOPBADEN,CCP2B3,CCP2C1,WRTC,NOWRTC,WRTB
//////// Fuses: NOWRTB,EBTR,NOEBTR,EBTRB,NOEBTRB,CPB,NOCPB,MCLR,NOMCLR
//////// Fuses: LPT1OSC,NOLPT1OSC,XINST,WDT256,WDT512,WDT1024,WDT2048
//////// Fuses: WDT4096,WDT8192,WDT16384,WDT32768,NOXINST,INTXT,INTHS,HS
//////// Fuses: HSPLL,PLL1,PLL2,PLL3,PLL4,PLL5,PLL6,PLL10,PLL12,CPUDIV1
//////// Fuses: CPUDIV2,CPUDIV3,CPUDIV4,USBDIV,NOUSBDIV,VREGEN,NOVREGEN
////////////////////////////////////////////////////////////////// I/O
// Discrete I/O Functions: SET_TRIS_x(), OUTPUT_x(), INPUT_x(),
// PORT_x_PULLUPS(), INPUT(),
// OUTPUT_LOW(), OUTPUT_HIGH(),
// OUTPUT_FLOAT(), OUTPUT_BIT()
// Constants used to identify pins in the above are:
#define PIN_A0 31744
#define PIN_A1 31745
#define PIN_A2 31746
#define PIN_A3 31747
#define PIN_A4 31748
#define PIN_A5 31749
#define PIN_A6 31750
#define PIN_B0 31752
#define PIN_B1 31753
#define PIN_B2 31754
#define PIN_B3 31755
#define PIN_B4 31756
#define PIN_B5 31757
#define PIN_B6 31758
#define PIN_B7 31759
#define PIN_C0 31760
#define PIN_C1 31761
#define PIN_C2 31762
#define PIN_C4 31764
#define PIN_C5 31765
#define PIN_C6 31766
#define PIN_C7 31767
#define PIN_E3 31779
////////////////////////////////////////////////////////////////// Useful defines
#define FALSE 0
#define TRUE 1
#define BYTE int8
#define BOOLEAN int1
#define getc getch
#define fgetc getch
#define getchar getch
#define putc putchar
#define fputc putchar
#define fgets gets
#define fputs puts
////////////////////////////////////////////////////////////////// Control
// Control Functions: RESET_CPU(), SLEEP(), RESTART_CAUSE()
// Constants returned from RESTART_CAUSE() are:
#define WDT_TIMEOUT 7
#define MCLR_FROM_SLEEP 11
#define MCLR_FROM_RUN 15
#define NORMAL_POWER_UP 12
#define BROWNOUT_RESTART 14
#define WDT_FROM_SLEEP 3
#define RESET_INSTRUCTION 0
////////////////////////////////////////////////////////////////// Timer 0
// Timer 0 (AKA RTCC)Functions: SETUP_COUNTERS() or SETUP_TIMER_0(),
// SET_TIMER0() or SET_RTCC(),
// GET_TIMER0() or GET_RTCC()
// Constants used for SETUP_TIMER_0() are:
#define T0_INTERNAL 0
#define T0_EXT_L_TO_H 32
#define T0_EXT_H_TO_L 48
#define T0_DIV_1 8
#define T0_DIV_2 0
#define T0_DIV_4 1
#define T0_DIV_8 2
#define T0_DIV_16 3
#define T0_DIV_32 4
#define T0_DIV_64 5
#define T0_DIV_128 6
#define T0_DIV_256 7
#define T0_OFF 0x80
#define T0_8_BIT 0x40
#define RTCC_INTERNAL 0 // The following are provided for compatibility
#define RTCC_EXT_L_TO_H 32 // with older compiler versions
#define RTCC_EXT_H_TO_L 48
#define RTCC_DIV_1 8
#define RTCC_DIV_2 0
#define RTCC_DIV_4 1
#define RTCC_DIV_8 2
#define RTCC_DIV_16 3
#define RTCC_DIV_32 4
#define RTCC_DIV_64 5
#define RTCC_DIV_128 6
#define RTCC_DIV_256 7
#define RTCC_OFF 0x80
#define RTCC_8_BIT 0x40
// Constants used for SETUP_COUNTERS() are the above
// constants for the 1st param and the following for
// the 2nd param:
////////////////////////////////////////////////////////////////// WDT
// Watch Dog Timer Functions: SETUP_WDT() or SETUP_COUNTERS() (see above)
// RESTART_WDT()
// WDT base is 4ms
#define WDT_ON 0x100
#define WDT_OFF 0
////////////////////////////////////////////////////////////////// Timer 1
// Timer 1 Functions: SETUP_TIMER_1, GET_TIMER1, SET_TIMER1
// Constants used for SETUP_TIMER_1() are:
// (or (via |) together constants from each group)
#define T1_DISABLED 0
#define T1_INTERNAL 0x85
#define T1_EXTERNAL 0x87
#define T1_EXTERNAL_SYNC 0x83
#define T1_CLK_OUT 8
#define T1_DIV_BY_1 0
#define T1_DIV_BY_2 0x10
#define T1_DIV_BY_4 0x20
#define T1_DIV_BY_8 0x30
////////////////////////////////////////////////////////////////// Timer 2
// Timer 2 Functions: SETUP_TIMER_2, GET_TIMER2, SET_TIMER2
// Constants used for SETUP_TIMER_2() are:
#define T2_DISABLED 0
#define T2_DIV_BY_1 4
#define T2_DIV_BY_4 5
#define T2_DIV_BY_16 6
////////////////////////////////////////////////////////////////// Timer 3
// Timer 3 Functions: SETUP_TIMER_3, GET_TIMER3, SET_TIMER3
// Constants used for SETUP_TIMER_3() are:
#define T3_DISABLED 0
#define T3_INTERNAL 0x85
#define T3_EXTERNAL 0x87
#define T3_EXTERNAL_SYNC 0x83
#define T3_DIV_BY_1 0
#define T3_DIV_BY_2 0x10
#define T3_DIV_BY_4 0x20
#define T3_DIV_BY_8 0x30
// OR in one of the following to use timer 3 with a CCP unit
#define T3_CCP1_TO_2 0x48
#define T3_CCP2 0x8
////////////////////////////////////////////////////////////////// CCP
// CCP Functions: SETUP_CCPx, SET_PWMx_DUTY
// CCP Variables: CCP_x, CCP_x_LOW, CCP_x_HIGH
// Constants used for SETUP_CCPx() are:
#define CCP_OFF 0
#define CCP_CAPTURE_FE 4
#define CCP_CAPTURE_RE 5
#define CCP_CAPTURE_DIV_4 6
#define CCP_CAPTURE_DIV_16 7
#define CCP_COMPARE_SET_ON_MATCH 8
#define CCP_COMPARE_CLR_ON_MATCH 9
#define CCP_COMPARE_INT 0xA
#define CCP_COMPARE_INT_AND_TOGGLE 0x2
#define CCP_COMPARE_RESET_TIMER 0xB
#define CCP_PWM 0xC
#define CCP_PWM_PLUS_1 0x1c
#define CCP_PWM_PLUS_2 0x2c
#define CCP_PWM_PLUS_3 0x3c
//#define CCP_USE_TIMER3 0x100 OBSOLETE, SEE TIMER-3
#word CCP_1 = getenv("SFR:CCPR1L")
#byte CCP_1_LOW= getenv("SFR:CCPR1L")
#byte CCP_1_HIGH= getenv("SFR:CCPR1H")
#word CCP_2 = getenv("SFR:CCPR2L")
#byte CCP_2_LOW= getenv("SFR:CCPR2L")
#byte CCP_2_HIGH= getenv("SFR:CCPR2H")
////////////////////////////////////////////////////////////////// SPI
// SPI Functions: SETUP_SPI, SPI_WRITE, SPI_READ, SPI_DATA_IN
// Constants used in SETUP_SPI() are:
#define SPI_MASTER 0x20
#define SPI_SLAVE 0x24
#define SPI_L_TO_H 0
#define SPI_H_TO_L 0x10
#define SPI_CLK_DIV_4 0
#define SPI_CLK_DIV_16 1
#define SPI_CLK_DIV_64 2
#define SPI_CLK_T2 3
#define SPI_SS_DISABLED 1
#define SPI_SAMPLE_AT_END 0x8000
#define SPI_XMIT_L_TO_H 0x4000
////////////////////////////////////////////////////////////////// UART
// Constants used in setup_uart() are:
// FALSE - Turn UART off
// TRUE - Turn UART on
#define UART_ADDRESS 2
#define UART_DATA 4
#define UART_AUTODETECT 8
#define UART_AUTODETECT_NOWAIT 9
#define UART_WAKEUP_ON_RDA 10
#define UART_SEND_BREAK 13
////////////////////////////////////////////////////////////////// COMP
// Comparator Variables: C1OUT, C2OUT
// Constants used in setup_comparator() are:
#define A0_A3_A1_A3 0xfff04
#define A0_A3_A1_A2_OUT_ON_A4_A5 0xfcf03
#define A0_A3_A1_A3_OUT_ON_A4_A5 0xbcf05
#define NC_NC_NC_NC 0x0ff07
#define A0_A3_A1_A2 0xfff02
#define A0_A3_NC_NC_OUT_ON_A4 0x9ef01
#define A0_VR_A1_VR 0x3ff06
#define A3_VR_A2_VR 0xcff0e
#define CP1_INVERT 0x0000010
#define CP2_INVERT 0x0000020
#bit C1OUT = 0xfb4.6
#bit C2OUT = 0xfb4.7
////////////////////////////////////////////////////////////////// VREF
// Constants used in setup_vref() are:
#define VREF_LOW 0xa0
#define VREF_HIGH 0x80
// Or (with |) the above with a number 0-15
#define VREF_F5 0x40
#define VREF_COMP 0x10
// Constants used in setup_low_volt_detect() are:
#define LVD_LVDIN 0x1F
#define LVD_45 0x1E
#define LVD_42 0x1D
#define LVD_40 0x1C
#define LVD_38 0x1B
#define LVD_36 0x1A
#define LVD_35 0x19
#define LVD_33 0x18
#define LVD_30 0x17
#define LVD_28 0x16
#define LVD_27 0x15
#define LVD_25 0x14
#define LVD_24 0x13
#define LVD_23 0x12
#define LVD_22 0x11
#define LVD_21 0x10
#define LVD_TRIGGER_BELOW 0
#define LVD_TRIGGER_ABOVE 0x80
////////////////////////////////////////////////////////////////// INTERNAL RC
// Constants used in setup_oscillator() are:
// First param:
#define OSC_31KHZ 0
#define OSC_125KHZ 0x10
#define OSC_250KHZ 0x20
#define OSC_500KHZ 0x30
#define OSC_1MHZ 0x40
#define OSC_2MHZ 0x50
#define OSC_4MHZ 0x60
#define OSC_8MHZ 0x70
#define OSC_16MHZ 0x4060
#define OSC_32MHZ 0x4070
// The following may be OR'ed in with the above using |
#define OSC_TIMER1 1
#define OSC_INTRC 2
#define OSC_NORMAL 0
#define OSC_IDLE_MODE 0x80
#define OSC_31250 0x8000
#define OSC_PLL_ON 0x4000
#define OSC_PLL_OFF 0
// A second optional parameter may be used with this part to fine
// tune the speed (signed int,0-31)
// Result may be (ignore all other bits)
#define OSC_STATE_STABLE 4
#define OSC_STATE_EXT_RUNNING 8
////////////////////////////////////////////////////////////////// ADC
// ADC Functions: SETUP_ADC(), SETUP_ADC_PORTS() (aka SETUP_PORT_A),
// SET_ADC_CHANNEL(), READ_ADC()
// Constants used for SETUP_ADC() are:
#define ADC_OFF 0 // ADC Off
#define ADC_CLOCK_DIV_2 0x100
#define ADC_CLOCK_DIV_4 0x04
#define ADC_CLOCK_DIV_8 0x01
#define ADC_CLOCK_DIV_16 0x05
#define ADC_CLOCK_DIV_32 0x02
#define ADC_CLOCK_DIV_64 0x06
#define ADC_CLOCK_INTERNAL 0x07 // Internal 2-6us
// Constants used in SETUP_ADC_PORTS() are:
#define NO_ANALOGS 0x0F // None
#define ALL_ANALOG 0x00 // A0 A1 A2 A3 A5 B2 B3 B1 B4 B0
#define AN0_TO_AN11 0x03 // A0 A1 A2 A3 A5 B2 B3 B1 B4
#define AN0_TO_AN10 0x04 // A0 A1 A2 A3 A5 B2 B3 B1
#define AN0_TO_AN9 0x05 // A0 A1 A2 A3 A5 B2 B3
#define AN0_TO_AN8 0x06 // A0 A1 A2 A3 A5 B2
#define AN0_TO_AN4 0x0A // A0 A1 A2 A3 A5
#define AN0_TO_AN3 0x0B // A0 A1 A2 A3
#define AN0_TO_AN2 0x0C // A0 A1 A2
#define AN0_TO_AN1 0x0D // A0 A1
#define AN0 0x0E // A0
#define AN0_TO_AN11_ANALOG 0x03 //!old only provided for compatibility
#define AN0_TO_AN10_ANALOG 0x04 //!old only provided for compatibility
#define AN0_TO_AN9_ANALOG 0x05 //!old only provided for compatibility
#define AN0_TO_AN8_ANALOG 0x06 //!old only provided for compatibility
#define AN0_TO_AN4_ANALOG 0x0A //!old only provided for compatibility
#define AN0_TO_AN3_ANALOG 0x0B //!old only provided for compatibility
#define AN0_TO_AN2_ANALOG 0x0C //!old only provided for compatibility
#define AN0_TO_AN1_ANALOG 0x0D //!old only provided for compatibility
#define AN0_ANALOG 0x0E //!old only provided for compatibility
#define VSS_VDD 0x00 // Range 0-Vdd
#define VREF_VREF 0x30 // Range VrefL-VrefH
#define VREF_VDD 0x20 // Range VrefL-Vdd
#define VSS_VREF 0x10 // Range 0-VrefH
// Constants used in READ_ADC() are:
#define ADC_START_AND_READ 7 // This is the default if nothing is specified
#define ADC_START_ONLY 1
#define ADC_READ_ONLY 6
// Interrupt Functions: ENABLE_INTERRUPTS(), DISABLE_INTERRUPTS(),
// CLEAR_INTERRUPT(), INTERRUPT_ACTIVE(),
// EXT_INT_EDGE()
// Constants used in EXT_INT_EDGE() are:
#define L_TO_H 0x40
#define H_TO_L 0
// Constants used in ENABLE/DISABLE_INTERRUPTS() are:
#define GLOBAL 0xF2C0
#define INT_RTCC 0x00F220
#define INT_TIMER0 0x00F220
#define INT_TIMER1 0x009D01
#define INT_TIMER2 0x009D02
#define INT_TIMER3 0x00A002
#define INT_EXT_L2H 0x5000F210
#define INT_EXT_H2L 0x6000F210
#define INT_EXT 0x00F210
#define INT_EXT1_L2H 0x5001F008
#define INT_EXT1_H2L 0x6001F008
#define INT_EXT1 0x00F008
#define INT_EXT2_L2H 0x5002F010
#define INT_EXT2_H2L 0x6002F010
#define INT_EXT2 0x00F010
#define INT_RB 0x00FFF208
#define INT_AD 0x009D40
#define INT_RDA 0x009D20
#define INT_TBE 0x009D10
#define INT_SSP 0x009D08
#define INT_CCP1 0x009D04
#define INT_CCP2 0x00A001
#define INT_BUSCOL 0x00A008
#define INT_LOWVOLT 0x00A004
#define INT_COMP 0x00A040
#define INT_EEPROM 0x00A010
#define INT_OSCF 0x00A080
#define INT_USB 0x00A020
#list
