Autor Tema: problema con sensor ds1820  (Leído 2045 veces)
Desconectado soymoe
    • El blog de Moe
« en: 07 de Octubre de 2012, 21:33:57 »
Hola estoy tratando de convertir mi rutina en assembler a C para hacer un termometro con el ds1820 y unos displays de 7 segmentos pero al simularlo en proteus no me muestra nada. Si fijo la temperatura y la muestro, si funciona pero al tratar de leer el dato del termometro no me muestra la temperatura del sensor, yo adapte una libreria:
// (C) copyright 2003 j.d.sandoz / jds-pic !at! losdos.dyndns.org
// released under the GNU GENERAL PUBLIC LICENSE (GPL)
// refer to http://www.gnu.org/licenses/gpl.txt
// This program is free software; you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation; either version 2 of the License, or
// (at your option) any later version.
// This program is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with this program; if not, write to the Free Software
// Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
/***********************1Wire Class***********************/
/*Description: This class handles all communication */
/* between the processor and the 1wire */
/* sensors.
/*-------1-wire definitions-------*/
#define ONE_WIRE_PIN PIN_A4
/*******************1-wire communication functions********************/
/************onewire_reset*************************************************/
/*This function initiates the 1wire bus */
/*PARAMETERS: */
/*RETURNS: */
void onewire_reset()  // OK if just using a single permanently connected device
 output_low(ONE_WIRE_PIN);
 delay_us( 500 ); // pull 1-wire low for reset pulse
 output_float(ONE_WIRE_PIN); // float 1-wire high
 delay_us( 500 ); // wait-out remaining initialisation window.
/*********************** onewire_write() ********************************/
/*This function writes a byte to the sensor.*/
/*Parameters: byte - the byte to be written to the 1-wire */
/*Returns: */
void onewire_write(int data)
 int count;
 for (count=0; count<8; ++count)
  delay_us( 2 ); // pull 1-wire low to initiate write time-slot.
  output_bit(ONE_WIRE_PIN, shift_right(&data,1,0)); // set output bit on 1-wire
  delay_us( 60 ); // wait until end of write slot.
  output_float(ONE_WIRE_PIN); // set 1-wire high again,
  delay_us( 2 ); // for more than 1us minimum.
/*********************** read1wire() *********************************/
/*This function reads the 8 -bit data via the 1-wire sensor. */
/*Parameters: */
/*Returns: 8-bit (1-byte) data from sensor */
int onewire_read()
 int count, data;
  delay_us( 2 ); // pull 1-wire low to initiate read time-slot.
  output_float(ONE_WIRE_PIN); // now let 1-wire float high,
  delay_us( 8 ); // let device state stabilise,
  shift_right(&data,1,input(ONE_WIRE_PIN)); // and load result.
  delay_us( 120 ); // wait until end of read slot.
 return( data );
y esta:
float ds1820_read()
 int8 busy=0, temp1, temp2;
 signed int16 temp3;
 float result;
 onewire_reset();
 onewire_write(0xCC);
 onewire_write(0x44);
 while (busy == 0)
  busy = onewire_read();
 onewire_reset();
 onewire_write(0xBE);
 temp1 = onewire_read();
 temp2 = onewire_read();
 temp3 = make16(temp2, temp1);
 result = (float) temp3 / 2.0;   //Calculation for DS18S20 with 0.5 deg C resolution
// result = (float) temp3 / 16.0;  //Calculation for DS18B20 with 0.1 deg C resolution
 delay_ms(200);
 return(result);
para que me de solo la parte entera de la temperatura:
int8 ds1820_read()
 int8 busy=0, temp1, temp2,result;
 onewire_reset();
 while (busy == 0)
 onewire_reset();
 result=temp1;
 delay_ms(200);
 return(result);
no se cual sera el problema, me ayudan, les paso los archivos.
https://dl.dropbox.com/u/50978562/termometroC%20dallas.rar
Desconectado jukinch
Re: problema con sensor ds1820
« Respuesta #1 en: 08 de Octubre de 2012, 11:51:41 »
Hola Soymoe:
             Encontré este post que quizá te pueda ayudar.
http://www.todopic.com.ar/foros/index.php?topic=19691
                     Jukinch
« Respuesta #2 en: 08 de Octubre de 2012, 12:21:21 »
Pero para que muestre solo la parte entera, en el original, solo declara result como int8  ;-)
Desconectado soymoe
    • El blog de Moe
« Respuesta #3 en: 08 de Octubre de 2012, 19:13:11 »
el problema que tengo ahora es que el digito de la unidad parpadea y no queda fijo, el valor de la temperatura la actualizo cada 1 seg mediante interrupcion de timer 0, alguien me da la solucion?Adjunto un video.
Archivos proyecto:
https://dl.dropbox.com/u/50978562/termometro3%20dallas.rar
« Última modificación: 10 de Octubre de 2012, 17:00:08 por soymoe »
Desconectado soymoe
    • El blog de Moe
« Respuesta #4 en: 28 de Julio de 2013, 20:52:33 »
Hola Gracias a todos ya solucione el problema, era por la velocidad de refresco del display, le agrege llamadas a la rutina de display entre las lineas de la rutina de lectura de la temperatura
