unsigned char ch;unsigned int adc_rd;char *text,*text1;long tlong;int i,j;void main() { INTCON = 0; Lcd_Config(&PORTB, 4, 5, 6, 3, 2, 1, 0); LCD_Cmd(LCD_CURSOR_OFF); LCD_Cmd(LCD_CLEAR); for(i=0;i<5;i++){ LCD_Cmd(LCD_CLEAR); text = "INGENIERIA"; LCD_Out(1,i,text); Delay_ms(100); } text1 = "ELECTRONICA"; LCD_Out(2,3,text1); ADCON1 = 0x82; TRISA = 0xFF; Delay_ms(1000); LCD_Cmd(LCD_CLEAR); text = "Temperatura:"; for(j=16;j>0;j--){ LCD_Cmd(LCD_CLEAR); LCD_Out(1,j,text); Delay_ms(100); } while (1) { adc_rd = ADC_read(2); tlong = (long)adc_rd * 5000; tlong = tlong / 1023 - 40; ch = tlong / 1000; if(ch==0) LCD_Chr(2,6,' '); else LCD_Chr(2,6,48+ch); ch = (tlong / 100) % 10; LCD_Chr_CP(48+ch); ch = (tlong / 10) % 10; LCD_Chr_CP(48+ch); LCD_Chr_CP('.'); ch = tlong % 10; LCD_Chr_CP(48+ch); LCD_Chr_CP('C'); Delay_ms(200); }}
Deberias comparar la temperatura, guardada en Tlong, con otra variable, si Tlong es mayor, apagas la salida del bombillo, si es menor la enciendes.Para hacer estas comparaciones, puedes utilizar sentencias if-then.
