Hola
bueno dado que ese no funciona voy por partes
configura el timer 0 a 8 bit para que a cada interrumcion
cunata de 00 a FF y cuando pasa de FF a 00 hace interrrupcion
aumente una variable y se muestre el incremento en un buclue while.
para los led uso:
#USE FAST_IO
main.h
#include <18F2550.h>
#device adc=8
#FUSES NOWDT //No Watch Dog Timer
#FUSES WDT128 //Watch Dog Timer uses 1:128 Postscale
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOPROTECT //Code not protected from reading
#FUSES NOBROWNOUT //No brownout reset
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES NOPUT //No Power Up Timer
#FUSES NOCPD //No EE protection
#FUSES STVREN //Stack full/underflow will cause reset
#FUSES NODEBUG //No Debug mode for ICD
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT //Program memory not write protected
#FUSES NOWRTD //Data EEPROM not write protected
#FUSES IESO //Internal External Switch Over mode enabled
#FUSES FCMEN //Fail-safe clock monitor enabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOWRTC //configuration not registers write protected
#FUSES NOWRTB //Boot block not write protected
#FUSES NOEBTR //Memory not protected from table reads
#FUSES NOEBTRB //Boot block not protected from table reads
#FUSES NOCPB //No Boot Block code protection
#FUSES MCLR //Master Clear pin enabled
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES NOXINST //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES PLL12 //Divide By 12(48MHz oscillator input)
#FUSES CPUDIV4 //System Clock by 4
#FUSES USBDIV //USB clock source comes from PLL divide by 2
#FUSES VREGEN //USB voltage regulator enabled
#use delay(clock=20000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#use fast_io(B)
main.c
int8 tm0=0;
#INT_TIMER0
void prueba_timer0(void){
output_high(PIN_B6);
tm0=tm0+1;
void main()
setup_adc_ports(NO_ANALOGS);
setup_adc(adc_off);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_8_bit);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
//setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
// TODO: USER CODE!!
//set_timer0(0); //retardo de led
//set_timer1(0); //retardo inc proceso
enable_interrupts(int_timer0);
enable_interrupts(global);
While(true){
printf("\n\r tm0: %u"tm0);
}//fin while
Con lo sencillo que es esto, no funciona
¿Cual puede ser el error?con proteus veo como desborda el timer pero
nunca incrementa la variable tambien intente poner el prinf dentro de la interrupcion
y nada al final lo deje dentro del bucle.
si cnt es variable global, y entra en la interupcion
¿Por que no enciende el led ?
¿Porque no incrementa la variable?sigo con esto..
bueno olvide esto:
pero sigue sin encender el led.. veo que tendre que hacerlo por variable
sigo indagando..
