Autor Tema: NECESITO COLABORACION DE TODOPIC, LAGER O CUALQUIERA  (Leído 1978 veces)
Desconectado electrobol
« en: 07 de Abril de 2005, 16:54:00 »
TENGO ESTE PROGRAMA HECHO EN PIC BASIC, ACTUALMENTE SOY NUEVO, PERO CON DESEOS DE APRENDER MICROS. EL PROGRAMA QUE TENGO ES EL PBP Y PROTON IDE LITE. ESTE PROGRAMA EN PBP NO PUEDO COMPILARLO Y EN PROTON ME DICE QUE SOBREPASO LAS 50 LIEAS USTEDES PUEDEN COLABORARME COMPILANDOLO Y ENVIANDOME EL ASM. PORFAVOR ES PARA UNA NOTA EN LA U.
"*  Name    : UNTITLED.BAS                                      *
"*  Author  : [select VIEW...EDITOR OPTIONS]                    *
"*  Notice  : Copyright (c) 2005 [select VIEW...EDITOR OPTIONS] *
"*          : All Rights Reserved                               *
"*  Date    : 07/04/2005                                        *
"*  Version : 1.0                                               *
"*  Notes   :                                                   *
define osc4
define adc_bits 8
define adc_clock 3
define adc_sampleus 5000
define oscal_1k1
@ device mclr_off
symbol carga = gpio.5
symbol panel = gpio.2
symbol led = gpio.4
tens1  var byte[10]
tens2  var byte[10]
tmp    var byte
tenspanel  var word
tensbateria    var word
conta          var byte
intensa        var byte
OPTION_REG= %10000000
CMCON= %00000111
ADCON0= %00000000
ANSEL=%00000011
WPU=%00000000
IOCB=%00000000
INTCON=%00000000
OUTPUT CARGA
OUTPUT PANEL
OUTPUT LED
LOW LED
LOW PANEL
LOW CARGA
CLEAR
MAIN:
GOSUB AD
IF TENSPANEL<TENSBATERIA THEN
HIGH LED
PAUSE 200
LOW LED
ELSE
HIGH LED
ENDIF
IF INTENSA=0 THEN
IF TENSABATERIA>13800 AND PANEL=0 THEN
HIGH PANEL
CONTA=CONTA+1
ENDIF
ELSE
IF TENSABATERIA>14400 THEN
HIGH PANEL
CONTA=0
INTENSA=0
ENDIF
ENDIF
IF TENSABATERIA<12000 THEN
LOW CARGA
ENDIF
IF TENSABATERIA<10000 THEN
LOW CARGA
ENDIF
IF TENSABATERIA>11000 THEN
HIGH CARGA
ENDIF
IF CONTA>20 THEN
INTENSA=1
ENDIF
GOTO MAIN
AD:
FOR TMP=0 TO 9
ADCIN 0,TENS1[TMP]
TENSPANEL=
(TENS1[0]+TENS1[1]+TENS1[2]+TENS1[3]+TENS1[4]+TENS1[5]+TENS1[6]+
TENS1[7]+TENS1[8]+TENS1[9])/10
TENSPANEL=(TENSPANEL+1)*196
ADCIN 1,TENS2[TMP]
TENSBATERIA=
(TENS2[0]+TENS2[1]+TENS2[2]+TENS2[3]+TENS2[4]+TENS2[5]+TENS2[6]+
TENS2[7]+TENS2[8]+TENS2[9])/10
TENSBATERIA=(TENSBATERIA+1)*196
PAUSE 100
NEXT TMP
RETURN
MI EMAIL ES: electromoderna@hotmail.com
Desconectado Colores
RE: NECESITO COLABORACION DE TODOPIC, LAGER O CUALQUIERA
« Respuesta #1 en: 07 de Abril de 2005, 20:34:00 »
Te olvidaste de definir para que micro es? Te falta la línea DEVICE (pic).
Desconectado Lager.
« Respuesta #2 en: 07 de Abril de 2005, 20:42:00 »
Escrito originalmente por electrobol
Que micro es el que vas a usar pana???????, por que no puedes compilarlo,, tiene errores???????
Salu2 pana Sonrisa
« Respuesta #3 en: 08 de Abril de 2005, 07:05:00 »
es para el pic 12f675. Les agradezco la mayor colaboracion. Y por favor me indican si la version demo de PIC BASIC tiene una opcion para compilar, pero esta no me compila siempre me salen estos errores.
erro de proyecto bas,11:´:´or ´=´expected(token´osc4´Giño por favor y me indican en donde bajo un demo de buena calidad o cual me sugieren. POR AHORA NECESITO ES QUE ME COMPILEN Y ME CREEN EL ASM.
GRACIAS Y FELICITACIONES POR ESTE GRAN FORO NUNCA ANTES VISTO.
Desconectado Lager.
« Respuesta #4 en: 08 de Abril de 2005, 11:22:00 »
De principio tienes errores de sintaxis y definiciones erroneas(en lugar de poner tensbateria pones TENSABATERIA)  pana, aqui te lo pongo corregido y YA DEBE de compilar
Codigo:
"* Version : 1.0 *
"* Notes : *
define osc4
define adc_bits 8
define adc_clock 3
define oscal_1k1
@ device mclr_off
symbol led = gpio.4
tens1 var byte[10]
tens2 var byte[10]
tmp var byte
tenspanel var word
conta var byte
intensa var byte
CMCON= %00000111
ADCON0= %00000000
ANSEL=%00000011
WPU=%00000000
IOCB=%00000000
INTCON=%00000000
OUTPUT CARGA
OUTPUT PANEL
OUTPUT LED
LOW LED
LOW PANEL
LOW CARGA
CLEAR
MAIN:
GOSUB AD
HIGH LED
PAUSE 200
LOW LED
ELSE
HIGH LED
ENDIF
IF INTENSA=0 THEN
IF TENSBATERIA > 13800 AND PANEL=0 THEN
HIGH PANEL
CONTA=CONTA+1
ENDIF
ELSE
IF TENSBATERIA>14400 THEN
HIGH PANEL
CONTA=0
INTENSA=0
ENDIF
ENDIF
IF TENSBATERIA<12000 THEN
LOW CARGA
ENDIF
IF TENSBATERIA<10000 THEN
LOW CARGA
ENDIF
IF TENSBATERIA>11000 THEN
HIGH CARGA
ENDIF
IF CONTA>20 THEN
INTENSA=1
ENDIF
GOTO MAIN
AD:
FOR TMP=0 TO 9
ADCIN 0,TENS1[TMP]
TENSPANEL=(TENS1[0]+TENS1[1]+TENS1[2]+TENS1[3]+TENS1[4]+_
TENS1[5]+TENS1[6]+TENS1[7]+TENS1[8]+TENS1[9])/10
ADCIN 1,TENS2[TMP]
TENSBATERIA=(TENS2[0]+TENS2[1]+TENS2[2]+TENS2[3]+TENS2[4]+_
TENS2[5]+TENS2[6]+TENS2[7]+TENS2[8]+TENS2[9])/10
PAUSE 100
NEXT TMP
RETURN
SAlu2 panaSonrisa
« Respuesta #5 en: 08 de Abril de 2005, 13:27:00 »
Amigo Lager esta bien tenia algunos errores de sintaxis pero no me compilo el programa, yo lo que necesito es el ASM, es que proton no me deja porque sobrepaso las 50 lieas y PBP no sirve.
Ayudenme porfa.
Edwin Castaño
Colombia
Desconectado Lager.
« Respuesta #6 en: 08 de Abril de 2005, 15:09:00 »
Pana electrobol,
No te serviria en proton ya que maneja diferentes definiciones. El asm solo no te serviria ya que lo que necesitas en el micro es el HEX.
Lo que puedes hacer es abrir algun maletin y ver si alguien te lo puede compilar y subir al maletin.
Veo que tambien  necesitas el Manual en español, este te puede servir
http://todopic.com.ar/proyectos/
Me parece que aqui hay uno mas:http://www.frino.com.ar/
Un gran abrazo pana Sonrisa
