Autor Tema: Puerto serie en ATtiny(w/Arduino as ISP)  (Leído 2830 veces)
« en: 17 de Mayo de 2012, 07:06:50 »
Estoy intentando compilar con Arduino el siguiente código, y me lanza el error: 'Serial' was not declared in this scope
El código lo descargué de aquí es del cargador de baterias, segun eso el puerto serie funciona, pero no consigo compilarlo. ¿Alguna idea?
Edito: ya me compila, hera por las lineas: Serial.xxxx que tenia que ponerlas mySerial.xxxx, además de unos include. Ahora me falta probarlo en real.
NiMh Charger 0.9
with AtTiny85 @ 1Mhz
by Luca Soltoggio
10/03/2012 - 20/04/2012
Use negative deltaV to determine end of charge.
Suitable for NiMh and NiCD battery pack.
Default is for 6 cells 2500mAh.
Need some hardware/software adjustment for changing current / cells number
See http://arduinoelettronica.wordpress.com/
//#include "Arduino.h"
#include <stdlib.h>
#include <math.h>
#include "wiring.h"
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3);
#include "WProgram.h"
const int inputPin = B1;
const int outputPin = 0;
const int numReadings = 30; // number of analog read before checking battery status
const int multi = 1614; // multi coefficent for obtaining millivolts from analogread
long interval = 1000;     // interval for pulse charging and analog read - don't change this
long interval2 = 250;     // pulse off interval - you can adjust power with this. Use 100 for 2-4Ah battery packs, 500 for 1-2Ah battery pack
long interval2b=interval2;
long previousMillis,currentMillis,currentMillis2,trickleMillis = 0;
unsigned int readingtemp;
unsigned int total = 0;
unsigned int average,medium,maxmedium = 0;
boolean executed,endcharge,trickle=false;  // booleans for controlling various activities (for example "end of charge")
unsigned int myarray [7];   // array for keeping last 7 readings
int index,i = 0;
void setup()
  mySerial.begin(9600);
  pinMode(0,OUTPUT);
  // Some readings for initial check
  for (i=0;i<10;i++) {
    readingtemp = analogRead(inputPin);
    total=total+readingtemp;
  average = (((float)total / 1023.0) * (float)multi) / 10.0 + 0.5;
  if (average<=70) endcharge=true;  // If there is no battery, end charge
  mySerial.println((int)average);
  total=0;
  average=0;
void pusharray() {
  // push the array
  for (i=0;i<=5;++i) {
    myarray[i]=myarray[i+1];
  myarray[6]=average;
void voltread() {
  readingtemp = analogRead(inputPin);  // read analog input
  total= total + readingtemp;
  index++;
  // if numReadings reached, calculate the average
  if (index==numReadings) {
    index=0;
    average = (((float)total / 1023.0) * (float)multi) / numReadings + 0.5;
    if (average<=70) endcharge=true;  // stop charge if battery is detached
    total=0;
    pusharray(); // insert new average in array
    medium=(float)(myarray[6]+myarray[5]+myarray[4]+myarray[3]+myarray[2]+myarray[1]+myarray[0])/7.0+0.5; // calculate the average of the last 7 readings
    if (medium>maxmedium) maxmedium=medium; // save the value of highest medium in "maxmedium"
    mySerial.print(medium);
    mySerial.print(",");
    mySerial.print(maxmedium);
    mySerial.println((byte)myarray[6]);
    if ( ((medium+1) < maxmedium) && ((millis()/60000)>=11) ) {  // if battery charged (average voltage is dropped 0.02v), but not in the firsts 11 mintues
      if (!trickle) trickleMillis=millis(); // start trickle timer
      trickle=true; // enter final trickle charging mode
      if ((millis()/60000)<=15) endcharge=true; // if battery is charged in the firts 15 minutes, don't apply trickle charge (maybe was yet charged)
void loop() {
  currentMillis = millis();
  // executed every "interval" millis
  if(currentMillis - previousMillis > interval) {
    voltread();  // call reading and check volts function
    digitalWrite(outputPin,LOW);  // temporaly stop charging
    previousMillis = currentMillis;
    executed=false;  // boolean for setting and checking if has been yet turned ON charge
    // in the firsts 10 minutes and in the endings 15 minutes do a trickle charge (change OFF interval)
    if ( ( (trickle) && (((millis()-trickleMillis)/60000)<15) ) || ((millis()/60000)<10) ) {
      interval2=(interval-(interval-interval2b)/5);
    } else if ((millis()/60000)>=10) interval2=interval2b;  // after initial trickle charghe set back right time
    if ( (trickle) && (((millis()-trickleMillis)/60000)>=15) ) endcharge=true;  // if final trickle charge end, end charge
  currentMillis2 = millis();
  // executed "interval2" millis after turning OFF charge
  if ((currentMillis2 - previousMillis > interval2) && (!executed)) {
    executed=true;
    if (!endcharge) {
      digitalWrite(outputPin,HIGH); // if battery is not charged, re-enable charging
« Última modificación: 17 de Mayo de 2012, 10:33:00 por micro_pepe »
