LIBRERIA MODIFICADA PARA USO EN PUERTO D CON PIN RW ACTIVO, Y 4 BITS
CONTROLES EN LOS PINES portd0-3 Y DATOS EN portd4-7
CONEXIONES:
lcd conectado en PUERTO D
bus de datos en el nible alto conector idc rb 4 a 7
DATA7 PUERTO D.7
DATA6 PUERTO D.6
DATA5 PUERTO D.5
DATA4 PUERTO D.4
bus de control en el nible bajo conector idc rb 0 a 3
E_PIN PUERTO D.3
RS_PIN PUERTO D.2
RW_PIN PUERTO D.1
SE DEBE SELECCIONAR EL MODO DE MEMORIA LARGO LARGE MEMORY MODEL. SINO HAY QUE CAMBIAR LOS FAR POR NEAR.
#ifndef __XLCD_H
#define __XLCD_H
#include "p18cxxx.h"
/* PIC18 XLCD peripheral routines.
* Notes:
* - These libraries routines are written to support the
* Hitachi HD44780 LCD controller.
* - The user must define the following items:
* - The LCD interface type (4- or 8-bits)
* - If 4-bit mode
* - whether using the upper or lower nibble
* - The data port
* - The tris register for data port
* - The control signal ports and pins
* - The control signal port tris and pins
* - The user must provide three delay routines:
* - DelayFor18TCY() provides a 18 Tcy delay
* - DelayPORXLCD() provides at least 15ms delay
* - DelayXLCD() provides at least 5ms delay
/* Interface type 8-bit or 4-bit
* For 8-bit operation uncomment the #define BIT8
/* #define BIT8 */
/* When in 4-bit interface define if the data is in the upper
* or lower nibble. For lower nibble, comment the #define UPPER
#define UPPER
/* DATA_PORT defines the port to which the LCD data lines are connected */
#define DATA_PORT PORTD
#define TRIS_DATA_PORT TRISD
/* CTRL_PORT defines the port where the control lines are connected.
* These are just samples, change to match your application.
#define RW_PIN LATDbits.LATD1 /* PORT for RW */
#define TRIS_RW TRISDbits.TRISD1 /* TRIS for RW */
#define RS_PIN LATDbits.LATD2 /* PORT for RS */
#define TRIS_RS TRISDbits.TRISD2 /* TRIS for RS */
#define E_PIN LATDbits.LATD3 /* PORT for D */
#define TRIS_E TRISDbits.TRISD3 /* TRIS for E */
/* Display ON/OFF Control defines */
#define DON 0b00001111 /* Display on */
#define DOFF 0b00001011 /* Display off */
#define CURSOR_ON 0b00001111 /* Cursor on */
#define CURSOR_OFF 0b00001101 /* Cursor off */
#define BLINK_ON 0b00001111 /* Cursor Blink */
#define BLINK_OFF 0b00001110 /* Cursor No Blink */
/* Cursor or Display Shift defines */
#define SHIFT_CUR_LEFT 0b00010011 /* Cursor shifts to the left */
#define SHIFT_CUR_RIGHT 0b00010111 /* Cursor shifts to the right */
#define SHIFT_DISP_LEFT 0b00011011 /* Display shifts to the left */
#define SHIFT_DISP_RIGHT 0b00011111 /* Display shifts to the right */
/* Function Set defines */
#define FOUR_BIT 0b00101111 /* 4-bit Interface */
#define EIGHT_BIT 0b00111111 /* 8-bit Interface */
#define LINE_5X7 0b00110011 /* 5x7 characters, single line */
#define LINE_5X10 0b00110111 /* 5x10 characters */
#define LINES_5X7 0b00111011 /* 5x7 characters, multiple line */
#define PARAM_SCLASS auto
#define MEM_MODEL far // MODIFICAMOS FAR POR NEAR
#define LINE_0 0b10000000 //linea inicial
#define NEXT_LINE 0b11000000
// definiciones de funciones --------------------------------------------------------
/* OpenXLCD
* Configures I/O pins for external LCD
void OpenXLCD(PARAM_SCLASS unsigned char);
/* SetCGRamAddr
* Sets the character generator address
void SetCGRamAddr(PARAM_SCLASS unsigned char);
/* SetDDRamAddr
* Sets the display data address
void SetDDRamAddr(PARAM_SCLASS unsigned char);
/* BusyXLCD
* Returns the busy status of the LCD
unsigned char BusyXLCD(void);
/* ReadAddrXLCD
* Reads the current address
unsigned char ReadAddrXLCD(void);
/* ReadDataXLCD
* Reads a byte of data
char ReadDataXLCD(void);
/* WriteCmdXLCD
* Writes a command to the LCD
void WriteCmdXLCD(PARAM_SCLASS unsigned char);
/* WriteDataXLCD
* Writes a data byte to the LCD
void WriteDataXLCD(PARAM_SCLASS char);
/* putcXLCD
* A putc is a write
#define putcXLCD WriteDataXLCD
/* putsXLCD
* Writes a string of characters to the LCD
void putsXLCD(PARAM_SCLASS char *);
/* putrsXLCD
* Writes a string of characters in ROM to the LCD
void putrsXLCD(PARAM_SCLASS const MEM_MODEL rom char *);
/* User defines these routines according to the oscillator frequency */
extern void DelayFor18TCY(void);
extern void DelayPORXLCD(void);
extern void DelayXLCD(void);
#endif
* Function Name: OpenXLCD *
* Return Value: void *
* Parameters: lcdtype: sets the type of LCD (lines) *
* Description: This routine configures the LCD. Based on *
* the Hitachi HD44780 LCD controller. The *
* routine will configure the I/O pins of the *
* microcontroller, setup the LCD for 4- or *
* 8-bit mode and clear the display. The user *
* must provide three delay routines: *
* DelayFor18TCY() provides a 18 Tcy delay *
* DelayPORXLCD() provides at least 15ms delay *
* DelayXLCD() provides at least 5ms delay *
void OpenXLCD(unsigned char lcdtype)
// The data bits must be either a 8-bit port or the upper or
// lower 4-bits of a port. These pins are made into inputs
#ifdef BIT8 // 8-bit mode, use whole port
DATA_PORT = 0;
TRIS_DATA_PORT = 0xff;
#else // 4-bit mode
#ifdef UPPER // Upper 4-bits of the port
DATA_PORT &= 0x0f;
TRIS_DATA_PORT |= 0xf0;
#else // Lower 4-bits of the port
DATA_PORT &= 0xf0;
TRIS_DATA_PORT |= 0x0f;
#endif
#endif
TRIS_RW = 0; // All control signals made outputs
TRIS_RS = 0;
TRIS_E = 0;
RW_PIN = 0; // R/W pin made low
RS_PIN = 0; // Register select pin made low
E_PIN = 0; // Clock pin made low
// Delay for 15ms to allow for LCD Power on reset
DelayPORXLCD();
// Setup interface to LCD
#ifdef BIT8 // 8-bit mode interface
TRIS_DATA_PORT = 0; // Data port output
DATA_PORT = 0b00110000; // Function set cmd(8-bit interface)
#else // 4-bit mode interface
#ifdef UPPER // Upper nibble interface
TRIS_DATA_PORT &= 0x0f;
DATA_PORT &= 0x0f;
DATA_PORT |= 0b00100000; // Function set cmd(4-bit interface)
#else // Lower nibble interface
TRIS_DATA_PORT &= 0xf0;
DATA_PORT &= 0xf0;
DATA_PORT |= 0b00000010; // Function set cmd(4-bit interface)
#endif
#endif
E_PIN = 1; // Clock the cmd in
DelayFor18TCY();
E_PIN = 0;
// Delay for at least 4.1ms
DelayXLCD();
#ifdef BIT8 // 8-bit interface
#else // 4-bit interface
DATA_PORT &= 0x0f; // Function set cmd(4-bit interface)
DATA_PORT &= 0xf0; // Function set cmd(4-bit interface)
#endif
#endif
DelayFor18TCY();
E_PIN = 0;
// Delay for at least 100us
DelayXLCD();
#endif
#endif
E_PIN = 1; // Clock cmd in
DelayFor18TCY();
E_PIN = 0;
TRIS_DATA_PORT = 0xff; // Make data port input
TRIS_DATA_PORT |= 0xf0; // Make data nibble input
TRIS_DATA_PORT |= 0x0f; // Make data nibble input
#endif
#endif
// Set data interface width, # lines, font
while(BusyXLCD()); // Wait if LCD busy
WriteCmdXLCD(lcdtype); // Function set cmd
// Turn the display on then off
WriteCmdXLCD(DOFF&CURSOR_OFF&BLINK_OFF); // Display OFF/Blink OFF
WriteCmdXLCD(DON&CURSOR_ON&BLINK_ON); // Display ON/Blink ON
// Clear display
WriteCmdXLCD(0x01); // Clear display
// Set entry mode inc, no shift
WriteCmdXLCD(SHIFT_CUR_LEFT); // Entry Mode
// Set DD Ram address to 0
SetDDRamAddr(0); // Set Display data ram address to 0
return;
* Function Name: putrsXLCD
* Parameters: : pointer to string
* Description: This routine writes a string of bytes to the
* Hitachi HD44780 LCD controller. The user
* must check to see if the LCD controller is
* busy before calling this routine. The data
* is written to the character generator RAM or
* the display data RAM depending on what the
* previous SetxxRamAddr routine was called.
void putrsXLCD(const rom char *buffer_)
while(*buffer_) // Write data to LCD up to null
while(BusyXLCD()); // Wait while LCD is busy
WriteDataXLCD(*buffer_); // Write character to LCD
buffer_++; // Increment buffer
return;
* Function Name: putsXLCD
* Parameters: buffer: pointer to string
void putsXLCD(char *buffer)
while(*buffer) // Write data to LCD up to null
WriteDataXLCD(*buffer); // Write character to LCD
buffer++; // Increment buffer
return;
* Function Name: ReadAddrXLCD *
* Return Value: char: address from LCD controller *
* Parameters: void *
* Description: This routine reads an address byte from the *
* Hitachi HD44780 LCD controller. The user *
* must check to see if the LCD controller is *
* busy before calling this routine. The address*
* is read from the character generator RAM or *
* the display data RAM depending on what the *
* previous SetxxRamAddr routine was called. *
char data; // Holds the data retrieved from the LCD
RW_PIN = 1; // Set control bits for the read
RS_PIN = 0;
DelayFor18TCY();
E_PIN = 1; // Clock data out of the LCD controller
DelayFor18TCY();
data = DATA_PORT; // Save the data in the register
E_PIN = 0;
RW_PIN = 0; // Reset the control bits
RS_PIN = 0;
DelayFor18TCY();
DelayFor18TCY();
data = DATA_PORT&0xf0; // Read the nibble into the upper nibble of data
data = (DATA_PORT<<4)&0xf0; // Read the nibble into the upper nibble of data
#endif
E_PIN = 0; // Reset the clock
DelayFor18TCY();
E_PIN = 1; // Clock out the lower nibble
DelayFor18TCY();
data |= (DATA_PORT>>4)&0x0f; // Read the nibble into the lower nibble of data
data |= DATA_PORT&0x0f; // Read the nibble into the lower nibble of data
#endif
E_PIN = 0;
RW_PIN = 0; // Reset the control lines
#endif
return (data&0x7f); // Return the address, Mask off the busy bit
* Function Name: ReadDataXLCD *
* Return Value: char: data byte from LCD controller *
* Description: This routine reads a data byte from the *
* busy before calling this routine. The data *
char data;
RS_PIN = 1; // Set the control bits
RW_PIN = 1;
DelayFor18TCY();
E_PIN = 1; // Clock the data out of the LCD
DelayFor18TCY();
data = DATA_PORT; // Read the data
E_PIN = 0;
RS_PIN = 0; // Reset the control bits
RW_PIN = 0;
RW_PIN = 1;
RS_PIN = 1;
DelayFor18TCY();
DelayFor18TCY();
data = DATA_PORT&0xf0; // Read the upper nibble of data
data = (DATA_PORT<<4)&0xf0; // read the upper nibble of data
#endif
E_PIN = 0; // Reset the clock line
DelayFor18TCY();
E_PIN = 1; // Clock the next nibble out of the LCD
DelayFor18TCY();
data |= (DATA_PORT>>4)&0x0f; // Read the lower nibble of data
data |= DATA_PORT&0x0f; // Read the lower nibble of data
#endif
E_PIN = 0;
RW_PIN = 0;
#endif
return(data); // Return the data byte
* Function Name: SetCGRamAddr *
* Parameters: CGaddr: character generator ram address *
* Description: This routine sets the character generator *
* address of the Hitachi HD44780 LCD *
* controller. The user must check to see if *
* the LCD controller is busy before calling *
* this routine. *
void SetCGRamAddr(unsigned char CGaddr)
TRIS_DATA_PORT = 0; // Make data port ouput
DATA_PORT = CGaddr | 0b01000000; // Write cmd and address to port
RW_PIN = 0; // Set control signals
RS_PIN = 0;
DelayFor18TCY();
E_PIN = 1; // Clock cmd and address in
DelayFor18TCY();
E_PIN = 0;
DelayFor18TCY();
TRIS_DATA_PORT = 0xff; // Make data port inputs
TRIS_DATA_PORT &= 0x0f; // Make nibble input
DATA_PORT &= 0x0f; // and write upper nibble
DATA_PORT |= ((CGaddr | 0b01000000) & 0xf0);
TRIS_DATA_PORT &= 0xf0; // Make nibble input
DATA_PORT &= 0xf0; // and write upper nibble
DATA_PORT |= (((CGaddr |0b01000000)>>4) & 0x0f);
#endif
RS_PIN = 0;
DelayFor18TCY();
DelayFor18TCY();
E_PIN = 0;
DATA_PORT &= 0x0f; // Write lower nibble
DATA_PORT |= ((CGaddr<<4)&0xf0);
DATA_PORT &= 0xf0; // Write lower nibble
DATA_PORT |= (CGaddr&0x0f);
#endif
DelayFor18TCY();
DelayFor18TCY();
E_PIN = 0;
TRIS_DATA_PORT |= 0xf0; // Make inputs
TRIS_DATA_PORT |= 0x0f; // Make inputs
#endif
#endif
return;
* Function Name: SetDDRamAddr *
* Parameters: CGaddr: display data address *
* Description: This routine sets the display data address *
* of the Hitachi HD44780 LCD controller. The *
* user must check to see if the LCD controller*
* is busy before calling this routine. *
void SetDDRamAddr(unsigned char DDaddr)
TRIS_DATA_PORT = 0; // Make port output
DATA_PORT = DDaddr | 0b10000000; // Write cmd and address to port
RW_PIN = 0; // Set the control bits
RS_PIN = 0;
DelayFor18TCY();
E_PIN = 1; // Clock the cmd and address in
DelayFor18TCY();
E_PIN = 0;
DelayFor18TCY();
TRIS_DATA_PORT = 0xff; // Make port input
TRIS_DATA_PORT &= 0x0f; // Make port output
DATA_PORT |= ((DDaddr | 0b10000000) & 0xf0);
TRIS_DATA_PORT &= 0xf0; // Make port output
DATA_PORT |= (((DDaddr | 0b10000000)>>4) & 0x0f);
#endif
RW_PIN = 0; // Set control bits
RS_PIN = 0;
DelayFor18TCY();
DelayFor18TCY();
E_PIN = 0;
DATA_PORT |= ((DDaddr<<4)&0xf0);
DATA_PORT |= (DDaddr&0x0f);
#endif
DelayFor18TCY();
DelayFor18TCY();
E_PIN = 0;
TRIS_DATA_PORT |= 0xf0; // Make port input
TRIS_DATA_PORT |= 0x0f; // Make port input
#endif
#endif
return;
* Function Name: BusyXLCD *
* Return Value: char: busy status of LCD controller *
* Description: This routine reads the busy status of the *
* Hitachi HD44780 LCD controller. *
RW_PIN = 1; // Set the control bits for read
RS_PIN = 0;
DelayFor18TCY();
E_PIN = 1; // Clock in the command
DelayFor18TCY();
if(DATA_PORT&0x80) // Read bit 7 (busy bit)
{ // If high
E_PIN = 0; // Reset clock line
RW_PIN = 0; // Reset control line
return 1; // Return TRUE
else // Bit 7 low
return 0; // Return FALSE
if(DATA_PORT&0x80)
if(DATA_PORT&0x08)
#endif
DelayFor18TCY();
E_PIN = 1; // Clock out other nibble
DelayFor18TCY();
E_PIN = 0;
else // Busy bit is low
DelayFor18TCY();
DelayFor18TCY();
E_PIN = 0;
#endif
* Function Name: WriteCmdXLCD *
* Parameters: cmd: command to send to LCD *
* Description: This routine writes a command to the Hitachi*
* HD44780 LCD controller. The user must check *
* to see if the LCD controller is busy before *
* calling this routine. *
void WriteCmdXLCD(unsigned char cmd)
DATA_PORT = cmd; // Write command to data port
RW_PIN = 0; // Set the control signals
RS_PIN = 0; // for sending a command
DelayFor18TCY();
E_PIN = 1; // Clock the command in
DelayFor18TCY();
E_PIN = 0;
DelayFor18TCY();
TRIS_DATA_PORT = 0xff; // Data port input
DATA_PORT &= 0x0f;
DATA_PORT |= cmd&0xf0;
DATA_PORT &= 0xf0;
DATA_PORT |= (cmd>>4)&0x0f;
#endif
RW_PIN = 0; // Set control signals for command
RS_PIN = 0;
DelayFor18TCY();
E_PIN = 1; // Clock command in
DelayFor18TCY();
E_PIN = 0;
DATA_PORT &= 0x0f;
DATA_PORT |= (cmd<<4)&0xf0;
DATA_PORT &= 0xf0;
DATA_PORT |= cmd&0x0f;
#endif
DelayFor18TCY();
DelayFor18TCY();
E_PIN = 0;
#ifdef UPPER // Make data nibble input
#else
#endif
#endif
return;
* Function Name: WriteDataXLCD *
* Parameters: data: data byte to be written to LCD *
* Description: This routine writes a data byte to the *
* is written to the character generator RAM or*
void WriteDataXLCD(char data)
DATA_PORT = data; // Write data to port
RS_PIN = 1; // Set control bits
RW_PIN = 0;
DelayFor18TCY();
E_PIN = 1; // Clock data into LCD
DelayFor18TCY();
E_PIN = 0;
RS_PIN = 0; // Reset control bits
DATA_PORT &= 0x0f;
DATA_PORT |= data&0xf0;
DATA_PORT &= 0xf0;
DATA_PORT |= ((data>>4)&0x0f);
#endif
RW_PIN = 0;
DelayFor18TCY();
E_PIN = 1; // Clock nibble into LCD
DelayFor18TCY();
E_PIN = 0;
DATA_PORT &= 0x0f;
DATA_PORT |= ((data<<4)&0xf0);
DATA_PORT &= 0xf0;
DATA_PORT |= (data&0x0f);
#endif
DelayFor18TCY();
DelayFor18TCY();
E_PIN = 0;
#endif
#endif
return;
