; FUSE OPTIONS
; PLL Prescaler Selection bits:
; CONFIG PLLDIV = 1 ;No prescale (4 MHz oscillator input drives PLL directly)
; CONFIG PLLDIV = 2 ;Divide by 2 (8 MHz oscillator input)
; CONFIG PLLDIV = 3 ;Divide by 3 (12 MHz oscillator input)
; CONFIG PLLDIV = 4 ;Divide by 4 (16 MHz oscillator input)
CONFIG PLLDIV = 5 ;Divide by 5 (20 MHz oscillator input)
; CONFIG PLLDIV = 6 ;Divide by 6 (24 MHz oscillator input)
; CONFIG PLLDIV = 10 ;Divide by 10 (40 MHz oscillator input)
; CONFIG PLLDIV = 12 ;Divide by 12 (48 MHz oscillator input)
; CPU System Clock Postscaler:
CONFIG CPUDIV = OSC1_PLL2 ;[OSC1/OSC2 Src: /1][96 MHz PLL Src: /2]
; CONFIG CPUDIV = OSC2_PLL3 ;[OSC1/OSC2 Src: /2][96 MHz PLL Src: /3]
; CONFIG CPUDIV = OSC3_PLL4 ;[OSC1/OSC2 Src: /3][96 MHz PLL Src: /4]
; CONFIG CPUDIV = OSC4_PLL6 ;[OSC1/OSC2 Src: /4][96 MHz PLL Src: /6]
; USB Clock Selection bit (used in Full Speed USB mode only; UCFG:FSEN = 1):
; CONFIG USBDIV = 1 ;USB clock source comes directly from the primary oscillator block with no postscale
CONFIG USBDIV = 2 ;USB clock source comes from the 96 MHz PLL divided by 2
; Oscillator Selection bits:
; CONFIG FOSC = XT_XT ;XT oscillator, XT used by USB
; CONFIG FOSC = XTPLL_XT ;XT oscillator, PLL enabled, XT used by USB
; CONFIG FOSC = ECIO_EC ;External clock, port function on RA6, EC used by USB
; CONFIG FOSC = EC_EC ;External clock, CLKOUT on RA6, EC used by USB
; CONFIG FOSC = ECPLLIO_EC ;External clock, PLL enabled, port function on RA6, EC used by USB
; CONFIG FOSC = ECPLL_EC ;External clock, PLL enabled, CLKOUT on RA6, EC used by USB
; CONFIG FOSC = INTOSCIO_EC ;Internal oscillator, port function on RA6, EC used by USB
; CONFIG FOSC = INTOSC_EC ;Internal oscillator, CLKOUT on RA6, EC used by USB
; CONFIG FOSC = INTOSC_XT ;Internal oscillator, XT used by USB
; CONFIG FOSC = INTOSC_HS ;Internal oscillator, HS used by USB
; CONFIG FOSC = HS ;HS oscillator, HS used by USB
CONFIG FOSC = HSPLL_HS ;HS oscillator, PLL enabled, HS used by USB
; Fail-Safe Clock Monitor Enable bit:
CONFIG FCMEN = OFF ;Fail-Safe Clock Monitor disabled
; CONFIG FCMEN = ON ;Fail-Safe Clock Monitor enabled
; Internal/External Oscillator Switchover bit:
CONFIG IESO = OFF ;Oscillator Switchover mode disabled
; CONFIG IESO = ON ;Oscillator Switchover mode enabled
; Power-up Timer Enable bit:
CONFIG PWRT = ON ;PWRT enabled
; CONFIG PWRT = OFF ;PWRT disabled
; Brown-out Reset Enable bits:
CONFIG BOR = OFF ;Brown-out Reset disabled in hardware and software
; CONFIG BOR = SOFT ;Brown-out Reset enabled and controlled by software (SBOREN is enabled)
; CONFIG BOR = ON_ACTIVE ;Brown-out Reset enabled in hardware only and disabled in Sleep mode (SBOREN is disabled)
; CONFIG BOR = ON ;Brown-out Reset enabled in hardware only (SBOREN is disabled)
; Brown-out Voltage bits:
; CONFIG BORV = 0 ; 4.59 v
CONFIG BORV = 1 ; 4.33 v
; CONFIG BORV = 2 ; 2.79 v
; CONFIG BORV = 3 ; 2.05 v
; USB Voltage Regulator Enable bit:
; CONFIG VREGEN = OFF ;USB voltage regulator disabled
CONFIG VREGEN = ON ;USB voltage regulator enabled
; Watchdog Timer Enable bit:
CONFIG WDT = OFF ;HW Disabled - SW Controlled
; CONFIG WDT = ON ;HW Enabled - SW Disabled
; Watchdog Timer Postscale Select bits:
; CONFIG WDTPS = 1 ;1:1
; CONFIG WDTPS = 2 ;1:2
; CONFIG WDTPS = 4 ;1:4
; CONFIG WDTPS = 8 ;1:8
; CONFIG WDTPS = 16 ;1:16
; CONFIG WDTPS = 32 ;1:32
; CONFIG WDTPS = 64 ;1:64
; CONFIG WDTPS = 128 ;1:128
; CONFIG WDTPS = 256 ;1:256
; CONFIG WDTPS = 512 ;1:512
; CONFIG WDTPS = 1024 ;1:1024
; CONFIG WDTPS = 2048 ;1:2048
; CONFIG WDTPS = 4096 ;1:4096
; CONFIG WDTPS = 8192 ;1:8192
; CONFIG WDTPS = 16384 ;1:16384
CONFIG WDTPS = 32768 ;1:32768
; MCLR Pin Enable bit:
; CONFIG MCLRE = OFF ;RE3 input pin enabled; MCLR disabled
CONFIG MCLRE = ON ;MCLR pin enabled; RE3 input pin disabled
; Low-Power Timer 1 Oscillator Enable bit:
; CONFIG LPT1OSC = OFF ;Timer1 configured for higher power operation
CONFIG LPT1OSC = ON ;Timer1 configured for low-power operation
; PORTB A/D Enable bit:
CONFIG PBADEN = OFF ;PORTB<4:0> pins are configured as digital I/O on Reset
; CONFIG PBADEN = ON ;PORTB<4:0> pins are configured as analog input channels on Reset
; CCP2 MUX bit:
; CONFIG CCP2MX = OFF ;CCP2 input/output is multiplexed with RB3
CONFIG CCP2MX = ON ;CCP2 input/output is multiplexed with RC1
; Stack Full/Underflow Reset Enable bit:
CONFIG STVREN = OFF ;Stack full/underflow will not cause Reset
; CONFIG STVREN = ON ;Stack full/underflow will cause Reset
; Single-Supply ICSP Enable bit:
CONFIG LVP = OFF ;Single-Supply ICSP disabled
; CONFIG LVP = ON ;Single-Supply ICSP enabled
; Extended Instruction Set Enable bit:
CONFIG XINST = OFF ;Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
; CONFIG XINST = ON ;Instruction set extension and Indexed Addressing mode enabled
; Background Debugger Enable bit:
; CONFIG DEBUG = ON ;Background debugger enabled, RB6 and RB7 are dedicated to In-Circuit Debug
CONFIG DEBUG = OFF ;Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
; Code Protection bit Block 0:
; CONFIG CP0 = ON ;Block 0 (000800-001FFFh) code-protected
CONFIG CP0 = OFF ;Block 0 (000800-001FFFh) not code-protected
; Code Protection bit Block 1:
; CONFIG CP1 = ON ;Block 1 (002000-003FFFh) code-protected
CONFIG CP1 = OFF ;Block 1 (002000-003FFFh) not code-protected
; Code Protection bit Block 2:
; CONFIG CP2 = ON ;Block 2 (004000-005FFFh) code-protected
CONFIG CP2 = OFF ;Block 2 (004000-005FFFh) not code-protected
; Code Protection bit Block 3:
; CONFIG CP3 = ON ;Block 3 (006000-007FFFh) code-protected
CONFIG CP3 = OFF ;Block 3 (006000-007FFFh) not code-protected
; Boot Block Code Protection bit:
; CONFIG CPB = ON ;Boot block (000000-0007FFh) code-protected
CONFIG CPB = OFF ;Boot block (000000-0007FFh) not code-protected
; Data EEPROM Code Protection bit:
; CONFIG CPD = ON ;Data EEPROM code-protected
CONFIG CPD = OFF ;Data EEPROM not code-protected
; Write Protection bit Block 0:
; CONFIG WRT0 = ON ;Block 0 (000800-001FFFh) write-protected
CONFIG WRT0 = OFF ;Block 0 (000800-001FFFh) not write-protected
; Write Protection bit Block 1:
; CONFIG WRT1 = ON ;Block 1 (002000-003FFFh) write-protected
; CONFIG WRT1 = OFF ;Block 1 (002000-003FFFh) not write-protected
; Write Protection bit Block 2:
; CONFIG WRT2 = ON ;Block 2 (004000-005FFFh) write-protected
CONFIG WRT2 = OFF ;Block 2 (004000-005FFFh) not write-protected
; Write Protection bit Block 3:
; CONFIG WRT3 = ON ;Block 3 (006000-007FFFh) write-protected
CONFIG WRT3 = OFF ;Block 3 (006000-007FFFh) not write-protected
; Boot Block Write Protection bit:
; CONFIG WRTB = ON ;Boot block (000000-0007FFh) write-protected
CONFIG WRTB = OFF ;Boot block (000000-0007FFh) not write-protected
; Configuration Register;Write Protection bit:
; CONFIG WRTC = ON ;Configuration registers (300000-3000FFh) write-protected
CONFIG WRTC = OFF ;Configuration registers (300000-3000FFh) not write-protected
; Data EEPROM Write Protection bit:
; CONFIG WRTD = ON ;Data EEPROM write-protected
CONFIG WRTD = OFF ;Data EEPROM not write-protected
; Table Read Protection bit Block 0:
; CONFIG EBTR0 = ON ;Block 0 (000800-001FFFh) protected from table reads executed in other blocks
CONFIG EBTR0 = OFF ;Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
; Table Read Protection bit Block 1:
; CONFIG EBTR1 = ON ;Block 1 (002000-003FFFh) protected from table reads executed in other blocks
CONFIG EBTR1 = OFF ;Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
; Table Read Protection bit Block 2:
; CONFIG EBTR2 = ON ;Block 2 (004000-005FFFh) protected from table reads executed in other blocks
CONFIG EBTR2 = OFF ;Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
; Table Read Protection bit Block 3:
; CONFIG EBTR3 = ON ;Block 3 (006000-007FFFh) protected from table reads executed in other blocks
CONFIG EBTR3 = OFF ;Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
; Boot Block Table Read Protection:
; CONFIG EBTRB = ON ;Boot block (000000-0007FFh) protected from table reads executed in other blocks
CONFIG EBTRB = OFF ;Boot block (000000-0007FFh) not protected from table reads executed in other blocks
