en el programa siguiente, muestra una sumatoria mostrada en lcd siempre y cuanto portb > %11. en este caso la sumatoria se hace correctamente y se muesta en la lcd... el problema opcurre cuando se realiza la captacion de PORTA no hace nadaaaaaaaaa no la suma y no muestra en la lcd "donde dice regi_rojo= porta.0 + etc"" esa parte no logro q me de de antemano gracias por mirar
program contador
' Declarations section
DIM LCD_RS AS SBIT AT RD4_BIT 'CONFIGURACION PARA LA
LCD_EN AS SBIT AT RD5_BIT 'PANTALLA LCD POR EL PUERTO D
LCD_D4 AS SBIT AT RD0_BIT
LCD_D5 AS SBIT AT RD1_BIT
LCD_D6 AS SBIT AT RD2_BIT
LCD_D7 AS SBIT AT RD3_BIT
LCD_RS_DIRECTION AS SBIT AT TRISD4_BIT
LCD_EN_DIRECTION AS SBIT AT TRISD5_BIT
LCD_D4_DIRECTION AS SBIT AT TRISD0_BIT
LCD_D5_DIRECTION AS SBIT AT TRISD1_BIT
LCD_D6_DIRECTION AS SBIT AT TRISD2_BIT
LCD_D7_DIRECTION AS SBIT AT TRISD3_BIT
dim contan, contar as word
dim regi_negro as word
dim regi_rojo as word
dim text as char[3]
dim ch, adc_rd as word
dim cont as byte [20]
dim txt1 as char[16]
txt2 as char[9]
txt3 as char[9]
u as byte
i AS BYTE
a as byte
o as byte
ANSEL AS BYTE
ANSELH AS WORD
CONF:
ANSEL = 0 ' Todos los pines de E/S se configuran como digitales
ANSELH = 0
TRISB = %00001111 'PUERTO b COMO entranda de registro negro
PORTB = %00001111
TRISA = %00001111 'PUERTO a COMO entranda de registro rojo
PORTA = %00001111
TRISD = 0 'PUERTO D COMO SALIDA
PORTD = 0
PORTC = %00000111 'PUERTO C COMO COMO ENTRANDAS
TRISC = %00000111
txt1 = "NEGRO"
txt2 = "ROJO"
txt3 = "0"
MAIN:
' Inicializamos el módulo UART a 2400 bps.
LCD_INIT() 'INICIALIZAR LCD
LCD_CMD(_LCD_CLEAR) 'BORRAR DISPLAY
LCD_CMD(_LCD_CURSOR_OFF)
LCD_OUT(1,5,"PRECIONE") 'MENSAJE INICIAL
LCD_OUT(2,6,"INICIO")
' Bucle infinito
'APAGAR CURSOR
while 1 'SISTEMA DE
if PORTC.0 = 1 then ' Si se presiona el pulsador 1
delay_ms(50)
PORTB.0 = 1
LCD_CMD(_LCD_CLEAR)
Lcd_Out(1,1,txt1)
Lcd_Out(2,1,txt2)
Lcd_Out(1,9,"PTS:")
Lcd_Out(2,9,"PTS:")
Lcd_Out(1,13,txt3)
Lcd_Out(2,13,txt3)
DELAY_MS(1500)
End if
contar=0
contan=0
regi_negro = portb.0 + portb.1+ portb.2 + portb.3
if regi_negro > %10 then
i= i+1
if i<10 then
Lcd_Chr(1,14,48+i)
DELAY_MS(600)
end if
if i=10 then
lcd_Out(1,14,txt3)
u=u+1
Lcd_Chr(1,13,48+u)
DELAY_MS(600)
contan= contan +1
end if
end if
regi_rojo = porta.0 + porta.1+ porta.2 + porta.3
if regi_rojo > %10 then
o= o+1
if o<10 then
Lcd_Chr(2,14,48+o)
DELAY_MS(600)
end if
if o=10 then
lcd_Out(2,14,txt3)
a=a+1
Lcd_Chr(2,13,48+a)
DELAY_MS(600)
end if
end if
contar= contar +1
if portc.2 = 1 then
if contar > contan then
porta.4 =1
end if
if contan > contar then
porta.5 =1
end if
end if
if portc.1 = 1 then
delay_ms(100)
porta.4=0
porta.5=0
contar =0
contan =0
i=0
u=0
o=0
a=0
goto main
end if
wend
END.
