Autor Tema: AYUDA CON ESTE PROGRAMA DE TECLADO MATRICIAL, EVITAR AUTOREPETICION!!!  (Leído 2063 veces)
Desconectado Sacahe
BUENAS TARDES AMIGOS!!! RESULTA QUE ESTOY APRENDIEDO A PROGRAMAR LOS PIC CON PBP, ESTOY REALIZANDO UN PROGRAMA QUE MANEJA UN TECLADO MATRICIAL Y LOS DIGITOS QUE SE PRESIONAN SE VISUALICAN EN UN LCD, HASTA AQUI ESTA BIEN, PERO NO HE PODIDO LOGRAR QUE CUANDO PRESIONE UNA TECLA ESTE DEJE DE AUTOREPETIRSE EN EL LCD, SE QUE PARA ELLO DEBO DETECTAR CUANDO SE SUELTA LA TECLA, PERO NO ME SALE!!!..ACONTINUACION LES DEJO EL PROGRAMITA QUE HE REALIZADO Y ME PUEDAN DECIR PORQUE NO FUNCIONA Y COMO PUEDO SOLUCIONARLO. ESTOY UTILIZANDO UN 18F4550
DEFINE OSC 4
    PORTA = 0
    LATA = $00
    CMCON = $07         ;COMPARADORES APAGADOS
    TRISA = $00         ;CONFIGURA EL PUERTOA COMO SALIDA, ACA SE CONECTA EL LCD
    ADCON1 = %00001111  ;CONFIGURA ADCON1, PINES PORTA Y PORTB COMO I/O DIGITAL
    LATD = $00
    TRISD = $F0         ;CONFIGURA PUERTOD COMO SALIDA, ACA SE CONECTA EL TECLADO
    PORTD = 0
DATO_TEC VAR BYTE
;*********************DEFINIMOS OPERACION LCD*******************************
DEFINE LCD_DREG     PORTA   ;EL BUS ESTARA CONECTADO EN EL PUERTOA
DEFINE LCD_BITS     4       ;EL BUS SERA DE CUATRO BITS
DEFINE LCD_DBIT     0       ;SELECCION DEL BIT DE INICIO DEL PUERTO
DEFINE LCD_RSREG    PORTA   ;EL PIN "RS" ESTARA EN EL PUERTOA
DEFINE LCD_RSBIT    4       ;"RS" ESTARA CONECTADO EN RA4
DEFINE LCD_EREG     PORTA   ;EL PIN "E" ESTARA EN EL PUERTOA
DEFINE LCD_EBIT     5       ;"E" ESTARA CONECTADO EN RA5
        GOTO    INICIO
 TECLADO:
        PORTD.3 = 0         ;COLUMNA  1 = 0
        PORTD.2 = 1         ;COLUMNA  2 = 1
        PORTD.1 = 1         ;COLUMNA  3 = 1
        If PORTD.7 = 0 Then DATO_TEC = %00000001  ;TECLA "1"
        If PORTD.6 = 0 Then DATO_TEC = %00000100  ;TECLA "4"
        If PORTD.5 = 0 Then DATO_TEC = %00000111  ;TECLA "7"
        If PORTD.4 = 0 Then DATO_TEC = %00001010  ;TECLA "10"
        PAUSE   50
        PORTD.3 = 1         ;COLUMNA 1 = 1
        PORTD.2 = 0         ;COLUMNA 2 = 0
        If PORTD.7 = 0 Then DATO_TEC = %00000010   ;TECLA "2"
        If PORTD.6 = 0 Then DATO_TEC = %00000101   ;TECLA "5"
        If PORTD.5 = 0 Then DATO_TEC = %00001000   ;TECLA "8"
        If PORTD.4 = 0 Then DATO_TEC = %00000000   ;TECLA "0"
        PAUSE   50
        PORTD.1 = 0         ;COLUMNA 3 = 0
        If PORTD.7 = 0 Then DATO_TEC = %00000011  ;tecla "3"
        If PORTD.6 = 0 Then DATO_TEC = %00000110  ;tecla "6"
        If PORTD.5 = 0 Then DATO_TEC = %00001001  ;tecla "9"
        If PORTD.4 = 0 Then DATO_TEC = %00001100  ;tecla "12"
        PAUSE   50
        IF  DATO_TEC = $FF  THEN GOTO TECLADO
;RUTINA ANTIREPETICION
WT1:    PAUSE   50
        IF  PORTD.7 = 0  THEN GOTO WT1
WT2:    PAUSE   50
        IF  PORTD.6 = 0  THEN GOTO WT2
WT3:    PAUSE   50
        IF  PORTD.5 = 0  THEN GOTO WT3
WT4:    PAUSE   50
        IF  PORTD.4 = 0  THEN GOTO WT4
        RETURN
INICIO:
        DATO_TEC = $FF      ;DATO ASIGNADO CUANDO NO SE PRESIONA NINGUNA TECLA
        LCDOUT  $FE,1       ;LIMPA LA PANTALLA LCD
        LCDOUT  $FE,2       ;POSICIONA EL CURSOR AL INICIO
        lCDOUT  $FE,$0F     ;CURSOR INTERMITENTE ACTIVO
OTRA:   call    teclado
        LCDOUT  #DATO_TEC   ;VISUALIZA EN EL LCD
        DATO_TEC = $FF
        goto    OTRA
        END
Desconectado KALLITOS
Re: AYUDA CON ESTE PROGRAMA DE TECLADO MATRICIAL, EVITAR AUTOREPETICION!!!
« Respuesta #1 en: 05 de Diciembre de 2011, 16:36:42 »
Hola, te recomiendo utilizar indicadores o banderas, cuando ya se presionó la tecla pones la bandera de esa tecla a 1, cuando lees teclas y detectas que ya ha sido soltada pones la bandera de la tecla a 0, y para imprimir en lcd verifica que la bandera este en 0 y la colocas a 1 nuevamente.
algo asi:
if tecla = 1 and flag_tecla = 0 then
flag_tecla = 1
aqui imprime en lcd
endif
if tecla = 0 then flag_tecla = 0
saludos.
Desconectado Sacahe
« Respuesta #2 en: 05 de Diciembre de 2011, 22:46:37 »
GRACIAS COMPAÑERO POR TU COLABORACION, YA ENCONTRE LA SOLUCION A MI PROBLEMA. LOGRE ELIMINAR LA AUTOREPETICION. PARA LOS QUE NECESITEN UN PROGRAMA SENCILLO Y CORTO DE TECLADO MATRICIAL EN PBP AQUI LES DEJO EL CODIGO, PERO OJO ME FUNCIONO SIMULADO EN PROTEUS, TODAVIA NO LO HE MONTADO:
DEFINE OSC 4
    PORTA = 0
    LATA = $00
    ADCON1 = %00001111
    LATD = $00
    PORTD = 0
DATO_TEC VAR BYTE
        goto    INICIO
 TECLADO:
        If PORTD.7 = 0 Then DATO_TEC = %00000001 : GOTO ANTIREBOTE  ;TECLA "1"
        If PORTD.6 = 0 Then DATO_TEC = %00000100 : GOTO ANTIREBOTE  ;TECLA "4"
        If PORTD.5 = 0 Then DATO_TEC = %00000111 : GOTO ANTIREBOTE  ;TECLA "7"
        If PORTD.4 = 0 Then DATO_TEC = %00001010 : GOTO ANTIREBOTE  ;TECLA "10"
        PAUSE   50
        If PORTD.7 = 0 Then DATO_TEC = %00000010 : GOTO ANTIREBOTE   ;TECLA "2"
        If PORTD.6 = 0 Then DATO_TEC = %00000101 : GOTO ANTIREBOTE   ;TECLA "5"
        If PORTD.5 = 0 Then DATO_TEC = %00001000 : GOTO ANTIREBOTE   ;TECLA "8"
        If PORTD.4 = 0 Then DATO_TEC = %00000000 : GOTO ANTIREBOTE   ;TECLA "0"
        PAUSE   50
        If PORTD.7 = 0 Then DATO_TEC = %00000011 : GOTO ANTIREBOTE  ;tecla "3"
        If PORTD.6 = 0 Then DATO_TEC = %00000110 : GOTO ANTIREBOTE  ;tecla "6"
        If PORTD.5 = 0 Then DATO_TEC = %00001001 : GOTO ANTIREBOTE  ;tecla "9"
        If PORTD.4 = 0 Then DATO_TEC = %00001100 : GOTO ANTIREBOTE  ;tecla "12"
        PAUSE   50
        GOTO    TECLADO
ANTIREBOTE:
        PAUSE   100
WAIT1:  IF  PORTD.7 = 0  THEN GOTO WAIT1
WAIT2:  IF  PORTD.6 = 0  THEN GOTO WAIT2
WAIT3:  IF  PORTD.5 = 0  THEN GOTO WAIT3
WAIT4:  IF  PORTD.4 = 0  THEN GOTO WAIT4
        PAUSE   80
        RETURN
INICIO:
OTRA:   CALL    TECLADO     ;ESCANEA TECLADO
        LCDOUT  #DATO_TEC   ;VISUALIZA TECLA PULSADA EN EL LCD
        GOTO    OTRA
        END
