Autor Tema: Porque este error al ensamblar ?????????  (Leído 5971 veces)
Desconectado JoseLuis2801
« en: 29 de Septiembre de 2011, 07:58:55 »
Hola, a ver si alguine me puede ayudar, una subrutina de pausa.:
; SUBRUTINA PAUSA 2 NIVELES
   Cont1      EQU   20h
   Cont2      EQU   21h
   Sigui      EQU   100h
;  CODIGO RESET
            ORG 00h
            CALL Pausa
            GOTO Sigui
            ORG   05h
   Pausa      CLRF   Cont1
            CLRF   Cont2
   Bucle      DECFSZ   Cont1
            GOTO    Bucle
            DECFSZ   Cont2
            GOTO    Bucle
            Return
   Sigui      end
Y cuando ensambla, me da un mensaje de error:
Debug build of project `C:\Users\Jose Luis\Desktop\PROYECTOS\SPAUSA2.mcp' started.
Language tool versions: MPASMWIN.exe v5.42, mplink.exe v4.40, mplib.exe v4.40
Preprocessor symbol `__DEBUG' is defined.
Thu Sep 29 12:45:32 2011
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F886 "SPAUSA2.asm" /l"SPAUSA2.lst" /e"SPAUSA2.err" /d__DEBUG=1
Warning[207] C:\USERS\JOSE LUIS\DESKTOP\PROYECTOS\SPAUSA2.ASM 5 : Found label after column 1. (Cont1)
Warning[207] C:\USERS\JOSE LUIS\DESKTOP\PROYECTOS\SPAUSA2.ASM 6 : Found label after column 1. (Cont2)
Warning[207] C:\USERS\JOSE LUIS\DESKTOP\PROYECTOS\SPAUSA2.ASM 7 : Found label after column 1. (Sigui)
Warning[207] C:\USERS\JOSE LUIS\DESKTOP\PROYECTOS\SPAUSA2.ASM 21 : Found label after column 1. (Pausa)
Warning[207] C:\USERS\JOSE LUIS\DESKTOP\PROYECTOS\SPAUSA2.ASM 26 : Found label after column 1. (Bucle)
Message[305] C:\USERS\JOSE LUIS\DESKTOP\PROYECTOS\SPAUSA2.ASM 26 : Using default destination of 1 (file).
Message[305] C:\USERS\JOSE LUIS\DESKTOP\PROYECTOS\SPAUSA2.ASM 28 : Using default destination of 1 (file).
Warning[207] C:\USERS\JOSE LUIS\DESKTOP\PROYECTOS\SPAUSA2.ASM 32 : Found label after column 1. (Sigui)
Error[121]   C:\USERS\JOSE LUIS\DESKTOP\PROYECTOS\SPAUSA2.ASM 32 : Illegal label (Sigui)
Halting build on first failure as requested.
Debug build of project `C:\Users\Jose Luis\Desktop\PROYECTOS\SPAUSA2.mcp' failed.
Thu Sep 29 12:45:38 2011
BUILD FAILED
No entiendo porque es ilegal la etiqueta Sigui
Desconectado solapower
Re: Porque este error al ensamblar ?????????
« Respuesta #1 en: 29 de Septiembre de 2011, 08:45:40 »
Creo que es porque la tienes duplicada, ya que al principio declaras una posición de memoria para registro propio y luego, al final, llamas de la misma forma a una etiqueta.
Una pregunta, porqué separas tanto los dos primeros registros del ultimo ? los dos primeros a 0x20h y 0x21h y el ultimo 0100h
« Respuesta #2 en: 29 de Septiembre de 2011, 10:41:36 »
Perdona, es que como soy novato, no lo tenía claro, y queria que la rutina empezase desde la dirección 100h. Empieza a partir de la 5h por el ORG 5h claro.
MIra ya la he quitado:
   Cont1      EQU   20h
   Cont2      EQU   21h
;  CODIGO RESET
            ORG 00h
            CALL Pausa
            GOTO Sigui
            ORG   05h
   Pausa      CLRF   Cont1
                   CLRF   Cont2
   Bucle      DECFSZ   Cont1
                  GOTO    Bucle
                  DECFSZ   Cont2
                  GOTO    Bucle
                  Return
   Sigui      end
Y al ensamblar, el mensaje me da 2 errorres:
Debug build of project `C:\Users\Jose Luis\Desktop\PROYECTOS\pausa.mcp' started.
Thu Sep 29 15:33:41 2011
Clean: Done.
Error[113]   C:\USERS\JOSE LUIS\DESKTOP\PROYECTOS\SPAUSA2.ASM 15 : Symbol not previously defined (Sigui)
Warning[207] C:\USERS\JOSE LUIS\DESKTOP\PROYECTOS\SPAUSA2.ASM 23 : Found label after column 1. (Pausa)
Warning[207] C:\USERS\JOSE LUIS\DESKTOP\PROYECTOS\SPAUSA2.ASM 28 : Found label after column 1. (Bucle)
Message[305] C:\USERS\JOSE LUIS\DESKTOP\PROYECTOS\SPAUSA2.ASM 30 : Using default destination of 1 (file).
Warning[207] C:\USERS\JOSE LUIS\DESKTOP\PROYECTOS\SPAUSA2.ASM 34 : Found label after column 1. (Sigui)
Error[121]   C:\USERS\JOSE LUIS\DESKTOP\PROYECTOS\SPAUSA2.ASM 34 : Illegal label (Sigui)
Debug build of project `C:\Users\Jose Luis\Desktop\PROYECTOS\pausa.mcp' failed.
Thu Sep 29 15:33:44 2011
BUILD FAILED
GRacias compi
« Última modificación: 29 de Septiembre de 2011, 10:52:48 por JoseLuis2801 »
« Respuesta #3 en: 29 de Septiembre de 2011, 11:43:42 »
El  "end"  como finalización del programa no debe ir con una etiqueta. Si no tiene que hacer nada más pon  en la linea de la etiqueta Sigui  un  nop (que es un paso que no hace "nada" especifico) y luego en la siguiente linea el end.
Es decir:
Sigui      nop
             end
Salud
« Respuesta #4 en: 29 de Septiembre de 2011, 15:57:39 »
Si señor , perfecto ahora.
Ya he visto que NOP lo único que hace es consumir 1 ciclo de instrucción..
Muchas gracias
« Última modificación: 30 de Septiembre de 2011, 07:24:08 por JoseLuis2801 »
