'****************************************************************'* Name : UNTITLED.BAS *'* Author : Miguel Noe Garcia Perez *'* Notice : Copyright (c) 2011 Iberica 2000 *'* : All Rights Reserved *'* Date : 11/09/2011 *'* Version : 1.0 *'* Notes : *'* : *'****************************************************************DEVICE 16F877a XTAL = 4 LCD_TYPE = GRAPHIC ' Use a Graphic LCD ' Graphic LCD Pin Assignments LCD_DTPORT = PORTD LCD_RSPIN = PORTC.2 LCD_RWPIN = PORTE.0 LCD_ENPIN = PORTC.5 LCD_CS1PIN = PORTE.2 LCD_CS2PIN = PORTE.1 DECLARE GLCD_CS_INVERT on DECLARE INTERNAL_FONT on ' Use an internal chr set SCL_PIN = PORTC.4 SDA_PIN = PORTC.3 ALL_DIGITAL = ON ' Set PORTA and PORTE to all digital ' Define ADC parameters ADIN_RES = 10 ' 10-bit result required ADIN_TAD = FRC ' RC OSC chosen ADIN_STIME = 50 ' Allow 50us sample time '_______________________________________________________________ PORTB_PULLUPS = ON ' Enable PORTB pull-ups TRISA = %00000010 ' Set PORTA to all input ADCON1 = %10000010 ' Set PORTA analog and right justify result '********************* dim ******************************** DIM Xpos as BYTE DIM Ypos as BYTE dim BaudMode[7] as word dim Btnvar as byte ' Teclas dim Datos [128] as word dim Baudios as byte DIM SerData AS BYTE Dim Index As word ' Variable de uso general dim X as byte dim Coder as byte dim Grabar as byte dim N as word '******************************************************************************************'********************* SIMBOLOS DEL PROGRAMA *********************************************'****************************************************************************************** Symbol DQ = PORTc.1 ' Pin de conexión 1-Wire® Symbol SW1 = PORTb.0 ' Interruptor Set Symbol SW2 = PORTB.1 ' Interruptor Incre Symbol SW3 = PORTB.2 ' Interruptor Intro symbol Led = portc.7 BaudMode[1] = 19697 BaudMode[2] = 18030 BaudMode[3] = 17197 BaudMode[4] = 16780 BaudMode[5] = 16572 BaudMode[6] = 16468 '**************************** iniciar Variable ******************* Baudios = 1 grabar = 0 '******************* INICIO ********************************************************** Delayms 500 ' Wait .5 second Cls Print At 3,7,"M S X" DelayMS 2000 Cls Print At 0,0,"MSX BASIC version2.1" Print At 1,0,"Copyright 1986 by" Print At 2,0,"Microsoft" Print At 3,0,"Ok" Print At 7,0,"color auto goto list" DelayMS 500 cls Print At 3,7,"S P Y II" DELAYMS 500Star: gosub Menu'*********************** boton ***************************AA: button sw1,0,255,250,Btnvar,0,BB goto EscuchaBB: button sw2,0,255,250,Btnvar,0,CC goto GrabaCC: button sw3,0,255,250,Btnvar,0,AA GOTO Emitir '********************************************************* Escucha: circle 1,15,19,1 delayms 200 cls print at 0,2,"Selecciona Baudios" circle 1,15,19,2 circle 1,15,27,2 circle 1,15,35,2 circle 1,15,43,2 circle 1,15,51,2 circle 1,15,59,2 print at 2,4,"300 Baud" print at 3,4,"600 Baud" print at 4,4,"1200 Baud" print at 5,4,"2400 Baud" print at 6,4,"4800 Baud" print at 7,4,"9600 Baud"Seleccion: if baudios = 1 then circle 1,15,19,1 if baudios = 2 then circle 1,15,27,1:circle 0,15,19,1 if baudios = 3 then circle 1,15,35,1:circle 0,15,27,1 if baudios = 4 then circle 1,15,43,1:circle 0,15,35,1 if baudios = 5 then circle 1,15,51,1:circle 0,15,43,1 if baudios = 6 then circle 1,15,59,1:circle 0,15,51,1 if baudios > 6 then Baudios = 1:circle 0,15,59,1:circle 1,15,19,1'********************************************AAA: button sw1,0,255,250,Btnvar,0,BBB delayms 200: baudios = baudios +1:goto seleccionBBB: button sw2,0,255,250,Btnvar,0,AAA goto Escuchando stop Escuchando: cls print at 0,0,"Escuchando..." for Index = 0 to 127 SERIN PORTc.6 ,BaudMode[baudios],[SerData] 'print at 0,15,dec3 index DATOS [iNDEX] = SERDATA Next x=0 for index = 1 to 21 Coder = Datos[Index] print at 1,x,dec1 Coder x=x+1 next x=0 for index = 22 to 42 Coder = Datos[Index] print at 2,x,dec1 Coder x=x+1 next x=0 for index = 43 to 63 Coder = Datos[Index] print at 3,x,dec1 Coder x=x+1 next x=0 for index = 64 to 84 Coder = Datos[Index] print at 4,x,dec1 Coder x=x+1 next x=0 for index = 85 to 105 Coder = Datos[Index] print at 5,x,dec1 Coder x=x+1 next x=0 for index = 104 to 124 Coder = Datos[Index] print at 6,x,dec1 Coder x=x+1 next grabar = 1 print at 7,9,"FIN"CCCC: button sw3,0,255,250,Btnvar,0,AAAA delayms 200:GOTO Star AAAA: goto cccc stop Graba: circle 1,15,27,1 delayms 200 cls if grabar = 0 then print at 3,0,"No Hay datos":delayms 500:goto star print at 3,0,"GRABANDO" for n = 0 to 128 ewrite n,[datos[n]] next n CLS GOTO STAR stop Emitir: circle 1,15,35,1 delayms 200 cls PRINT AT 3,0,"Emitiendo" high led FOR N= 0 TO 127 Coder = Datos[N] Serout portc.0,BaudMode[baudios],[CODER] ' Display "Hello", next line NEXT low led delayms 200 cls goto star stop '******************* gosub *************************** Menu: CLS '123456789012345678901 print at 0,0,"_______ Menu _______" CIRCLE 1,15,19,2 print at 2,4,"Escuchar" circle 1,15,27,2 print at 3,4,"Grabar" circle 1,15,35,2 print at 4,4,"Emitir grabacion" print at 7,5,"Pulsa Boton" return end ' Letras font:- Cdata $00,$00,$00,$00,$00,$00,_ $FF,$FF,$FF,$FF,$FF,$FF,_ $07,$07,$07,$00,$00,$00,_ $00,$00,$00,$07,$07,$07,_ $E0,$E0,$E0,$00,$00,$00,_ $00,$00,$00,$E0,$E0,$E0,_ $FF,$FF,$FF,$00,$00,$00,_ $00,$00,$00,$FF,$FF,$FF,_ $07,$07,$07,$07,$07,$07,_ $E0,$E0,$E0,$E0,$E0,$E0,_ $E0,$E0,$E0,$07,$07,$07,_ $07,$07,$07,$E0,$E0,$E0,_ $FF,$FF,$FF,$E0,$E0,$E0,_ $E0,$E0,$E0,$FF,$FF,$FF,_ $07,$07,$07,$FF,$FF,$FF,_ $FF,$FF,$FF,$07,$07,$07,_ $55,$AA,$55,$AA,$55,$AA,_ $AA,$55,$AA,$55,$AA,$55,_ $01,$01,$01,$01,$01,$01,_ $80,$80,$80,$80,$80,$80,_ $FF,$00,$00,$00,$00,$00,_ $00,$00,$00,$00,$00,$FF,_ $FF,$01,$01,$01,$01,$01,_ $01,$01,$01,$01,$01,$FF,_ $FF,$80,$80,$80,$80,$80,_ $80,$80,$80,$80,$80,$FF,_ $00,$00,$06,$09,$09,$06,_ $00,$00,$00,$00,$00,$00,_ $00,$00,$00,$00,$00,$00,_ $00,$00,$00,$00,$00,$00,_ $00,$00,$00,$00,$00,$00,_ $00,$00,$00,$00,$00,$00,_ $00,$00,$00,$00,$00,$00,_ $00,$00,$4F,$00,$00,$00,_ $00,$07,$00,$07,$00,$00,_ $14,$7F,$14,$7F,$14,$00,_ $24,$2A,$7F,$2A,$12,$00,_ $23,$13,$08,$64,$62,$00,_ $36,$49,$55,$22,$50,$00,_ $00,$05,$03,$00,$00,$00,_ $1C,$22,$41,$00,$00,$00,_ $00,$00,$41,$22,$1C,$00,_ $14,$08,$3E,$08,$14,$00,_ $08,$08,$3E,$08,$08,$00,_ $00,$50,$30,$00,$00,$00,_ $08,$08,$08,$08,$08,$00,_ $00,$60,$60,$00,$00,$00,_ $20,$10,$08,$04,$02,$00,_ $3E,$51,$49,$45,$3E,$00,_ $00,$42,$7F,$40,$00,$00,_ $42,$61,$51,$49,$46,$00,_ $21,$41,$45,$4B,$31,$00,_ $18,$14,$12,$7F,$10,$00,_ $27,$45,$45,$45,$39,$00,_ $3C,$4A,$49,$49,$30,$00,_ $01,$71,$09,$05,$03,$00,_ $36,$49,$49,$49,$36,$00,_ $06,$49,$49,$49,$3E,$00,_ $00,$36,$36,$00,$00,$00,_ $00,$56,$36,$00,$00,$00,_ $08,$14,$22,$41,$00,$00,_ $14,$14,$14,$14,$14,$00,_ $00,$41,$22,$14,$08,$00,_ $02,$01,$51,$09,$06,$00,_ $32,$49,$79,$41,$3E,$00,_ $7E,$11,$11,$11,$7E,$00,_ $7F,$49,$49,$49,$36,$00,_ $3E,$41,$41,$41,$22,$00,_ $7F,$41,$41,$22,$1C,$00,_ $7F,$49,$49,$49,$41,$00,_ $7F,$09,$09,$09,$01,$00,_ $3E,$41,$49,$49,$7A,$00,_ $7F,$08,$08,$08,$7F,$00,_ $00,$41,$7F,$41,$00,$00,_ $20,$40,$41,$3F,$01,$00,_ $7F,$08,$14,$22,$41,$00,_ $7F,$40,$40,$40,$40,$00,_ $7F,$02,$0C,$02,$7F,$00,_ $7F,$04,$08,$10,$7F,$00,_ $3E,$41,$41,$41,$3E,$00,_ $7F,$09,$09,$09,$06,$00,_ $3E,$41,$51,$21,$5E,$00,_ $7F,$09,$19,$29,$46,$00,_ $46,$49,$49,$49,$31,$00,_ $01,$01,$7F,$01,$01,$00,_ $3F,$40,$40,$40,$3F,$00,_ $1F,$20,$40,$20,$1F,$00,_ $3F,$40,$38,$40,$3F,$00,_ $63,$14,$08,$14,$63,$00,_ $07,$08,$70,$08,$07,$00,_ $61,$51,$49,$45,$43,$00,_ $7F,$41,$41,$00,$00,$00,_ $02,$04,$08,$10,$20,$00,_ $00,$00,$41,$41,$7F,$00,_ $04,$02,$01,$02,$04,$00,_ $40,$40,$40,$40,$40,$00,_ $00,$01,$02,$04,$00,$00,_ $20,$54,$54,$54,$78,$00,_ $7F,$48,$44,$44,$38,$00,_ $38,$44,$44,$44,$20,$00,_ $38,$44,$44,$48,$7F,$00,_ $38,$54,$54,$54,$18,$00,_ $08,$7E,$09,$01,$02,$00,_ $0C,$52,$52,$52,$3E,$00,_ $7F,$08,$04,$04,$78,$00,_ $00,$44,$7D,$40,$00,$00,_ $00,$20,$40,$44,$3D,$00,_ $7F,$10,$28,$44,$00,$00,_ $00,$41,$7F,$40,$00,$00,_ $7C,$04,$18,$04,$78,$00,_ $7C,$08,$04,$04,$78,$00,_ $38,$44,$44,$44,$38,$00,_ $7C,$14,$14,$14,$08,$00,_ $08,$14,$14,$18,$7C,$00,_ $7C,$08,$04,$04,$08,$00,_ $48,$54,$54,$54,$20,$00,_ $04,$3F,$44,$40,$20,$00,_ $3C,$40,$40,$20,$7C,$00,_ $1C,$20,$40,$20,$1C,$00,_ $3C,$40,$30,$40,$3C,$00,_ $44,$28,$10,$28,$44,$00,_ $0C,$50,$50,$50,$3C,$00,_ $44,$64,$54,$4C,$44,$00,_ $08,$36,$41,$00,$00,$00,_ $00,$00,$7F,$00,$00,$00,_ $00,$00,$41,$36,$08,$00,_ $00,$08,$04,$08,$04,$00
