Autor Tema: Mas velocidad en pantallas graficas (GLCD)  (Leído 1649 veces)
Desconectado Noelillo
« en: 15 de Julio de 2011, 07:59:11 »
como puedo aumentar la velocidad de muestreo en una pantalla grafica lcd...
Yo grabo los graficos en una memoria I2C con este programa:
'*  Name    : UNTITLED.BAS                                      *
'*  Author  : Miguel Noe Garcia Perez                           *
'*  Notice  : Copyright (c) 2011 Iberica 2000                   *
'*          : All Rights Reserved                               *
'*  Date    : 08/02/2011                                        *
'*  Version : 1.0                                               *
'*  Notes   :                                                   *
DEVICE 16F877
 XTAL = 4
 LCD_TYPE = GRAPHIC   ' Use a Graphic LCD
 ' Graphic LCD Pin Assignments
 LCD_DTPORT = PORTD
 LCD_RSPIN = PORTC.2
 LCD_RWPIN = PORTE.0
 LCD_ENPIN = PORTC.5
 LCD_CS1PIN = PORTE.2
 LCD_CS2PIN = PORTE.1
 PORTB_PULLUPS = ON              ' Enable PORTB pull-ups
 DECLARE GLCD_CS_INVERT on
 DECLARE INTERNAL_FONT  on  ' Use an internal chr set
  SCL_PIN   = PORTc.3
  SDA_PIN   = PORTc.4
 ALL_DIGITAL = on True'ON            ' Set PORTA and PORTE to all digital
 Symbol SW1      =    PORTb.0 ' Interruptor Set
 Symbol SW2      =    PORTB.1 ' Interruptor Incre
 Symbol SW3      =    PORTB.2 ' Interruptor Intro
Dim Glcd_Data        As byte
Dim letter           As Byte
Dim Adress           As word
Dim VarLetter        As Byte
Dim Plaats           As Byte
DIM X                AS WORD
dim Xpos             as Byte
dim Ypos             as Byte
dim n                as byte
dim Numero           as byte
dim Btnvar           as byte
cls
delayms 500
'cls
Inicio:
Adress = $00
X=0
ypos =0
xpos=0
cls
  print at 1,0,INVERSE 0,"GRABADOR DE GRAFICOS"
  print at 3,0,"EN MEMORIA I2C"
  DELAYMS 1000
  CLS
 for ypos=0 to 5
   for N=0 to 127
    ' Busin $A1,Adress,[Glcd_data.lowbyte]
     Glcd_data = LRead Pantalla + X
     LCDWrite ypos,Xpos,[Glcd_data]             ;Maak het even zichtbaar op GLCD
     x = x +1
     inc xpos
     'INC adress
    next N
     xpos = 0
 Next Ypos
 'delayms 2000
   'delayms 2000
    PRINT AT 1,1,"Adre:"
    PRINT AT 2,1,"Dato:"   ' 123456789012345678901
    PRINT AT 3,1,"Graf:  de5"
    PRINT AT 4,1, INVERSE 1," rec "
   ypos =6
   FOR X = 0 TO 5119
    Glcd_data = LRead Dibujo1 + X
    BSTART
    busout $A0,Adress,[Glcd_data.lowbyte]
    BSTOP
    Delayms 10' no quitar tiempo de espera para grabar memoria i2c
    if xpos = 128 then xpos = 0 :ypos = ypos +1
    if ypos = 8 then ypos = 6:print at 6,0,"                      ":print at 7,0,"                      "
    PRINT AT 1,7, INVERSE 0,dec4 adress
    PRINT AT 2,7, dec4 Glcd_Data
    INC ADRESS
    Numero = adress / 1024
    print at 3,7,dec1 Numero
    inc xpos
    'delayms 50
   NEXT
   'cls  PRINT AT 0 , 0 , INVERSE 1 , "HELLO WORLD"
    PRINT AT 4,1, INVERSE 0," ok! "
    delayms 1000
Pulsadores:
    button sw1,0,255,250,Btnvar,0,NoPulso
           goto PullA
NoPulso:
     button sw2,0,255,250,Btnvar,0,NoPulso2
            goto PullB
NoPulso2:
      button sw3,0,255,250,Btnvar,0,Pulsadores
            goto inicio
    'stop
PullA:
     cls
     print at 3,3,"pulso A"
     stop
PullB:
     cls
     print At 3,3,"Pulso B"
     stop
 stop
end
 font:-
   Cdata $00,$00,$00,$00,$00,$00,_
       $FF,$FF,$FF,$FF,$FF,$FF,_
         $07,$07,$07,$00,$00,$00,_
         $00,$00,$00,$07,$07,$07,_
         $E0,$E0,$E0,$00,$00,$00,_
         $00,$00,$00,$E0,$E0,$E0,_
         $FF,$FF,$FF,$00,$00,$00,_
         $00,$00,$00,$FF,$FF,$FF,_
         $07,$07,$07,$07,$07,$07,_
         $E0,$E0,$E0,$E0,$E0,$E0,_
         $E0,$E0,$E0,$07,$07,$07,_
         $07,$07,$07,$E0,$E0,$E0,_
         $FF,$FF,$FF,$E0,$E0,$E0,_
         $E0,$E0,$E0,$FF,$FF,$FF,_
         $07,$07,$07,$FF,$FF,$FF,_
         $FF,$FF,$FF,$07,$07,$07,_
         $55,$AA,$55,$AA,$55,$AA,_
         $AA,$55,$AA,$55,$AA,$55,_
         $01,$01,$01,$01,$01,$01,_
         $80,$80,$80,$80,$80,$80,_
         $FF,$00,$00,$00,$00,$00,_
         $00,$00,$00,$00,$00,$FF,_
         $FF,$01,$01,$01,$01,$01,_
         $01,$01,$01,$01,$01,$FF,_
         $FF,$80,$80,$80,$80,$80,_
         $80,$80,$80,$80,$80,$FF,_
         $00,$00,$06,$09,$09,$06,_
       $00,$00,$4F,$00,$00,$00,_
       $00,$07,$00,$07,$00,$00,_
       $14,$7F,$14,$7F,$14,$00,_
       $24,$2A,$7F,$2A,$12,$00,_
       $23,$13,$08,$64,$62,$00,_
       $36,$49,$55,$22,$50,$00,_
       $00,$05,$03,$00,$00,$00,_
       $1C,$22,$41,$00,$00,$00,_
       $00,$00,$41,$22,$1C,$00,_
       $14,$08,$3E,$08,$14,$00,_
       $08,$08,$3E,$08,$08,$00,_
       $00,$50,$30,$00,$00,$00,_
       $08,$08,$08,$08,$08,$00,_
       $00,$60,$60,$00,$00,$00,_
       $20,$10,$08,$04,$02,$00,_
       $3E,$51,$49,$45,$3E,$00,_
       $00,$42,$7F,$40,$00,$00,_
       $42,$61,$51,$49,$46,$00,_
       $21,$41,$45,$4B,$31,$00,_
       $18,$14,$12,$7F,$10,$00,_
       $27,$45,$45,$45,$39,$00,_
       $3C,$4A,$49,$49,$30,$00,_
       $01,$71,$09,$05,$03,$00,_
       $36,$49,$49,$49,$36,$00,_
       $06,$49,$49,$49,$3E,$00,_
       $00,$36,$36,$00,$00,$00,_
       $00,$56,$36,$00,$00,$00,_
       $08,$14,$22,$41,$00,$00,_
       $14,$14,$14,$14,$14,$00,_
       $00,$41,$22,$14,$08,$00,_
       $02,$01,$51,$09,$06,$00,_
       $32,$49,$79,$41,$3E,$00,_
       $7E,$11,$11,$11,$7E,$00,_
       $7F,$49,$49,$49,$36,$00,_
       $3E,$41,$41,$41,$22,$00,_
       $7F,$41,$41,$22,$1C,$00,_
       $7F,$49,$49,$49,$41,$00,_
       $7F,$09,$09,$09,$01,$00,_
       $3E,$41,$49,$49,$7A,$00,_
       $7F,$08,$08,$08,$7F,$00,_
       $00,$41,$7F,$41,$00,$00,_
       $20,$40,$41,$3F,$01,$00,_
       $7F,$08,$14,$22,$41,$00,_
       $7F,$40,$40,$40,$40,$00,_
       $7F,$02,$0C,$02,$7F,$00,_
       $7F,$04,$08,$10,$7F,$00,_
       $3E,$41,$41,$41,$3E,$00,_
       $7F,$09,$09,$09,$06,$00,_
       $3E,$41,$51,$21,$5E,$00,_
       $7F,$09,$19,$29,$46,$00,_
       $46,$49,$49,$49,$31,$00,_
       $01,$01,$7F,$01,$01,$00,_
       $3F,$40,$40,$40,$3F,$00,_
       $1F,$20,$40,$20,$1F,$00,_
       $3F,$40,$38,$40,$3F,$00,_
       $63,$14,$08,$14,$63,$00,_
       $07,$08,$70,$08,$07,$00,_
       $61,$51,$49,$45,$43,$00,_
       $7F,$41,$41,$00,$00,$00,_
       $02,$04,$08,$10,$20,$00,_
       $00,$00,$41,$41,$7F,$00,_
       $04,$02,$01,$02,$04,$00,_
       $40,$40,$40,$40,$40,$00,_
       $00,$01,$02,$04,$00,$00,_
       $20,$54,$54,$54,$78,$00,_
       $7F,$48,$44,$44,$38,$00,_
       $38,$44,$44,$44,$20,$00,_
       $38,$44,$44,$48,$7F,$00,_
       $38,$54,$54,$54,$18,$00,_
       $08,$7E,$09,$01,$02,$00,_
       $0C,$52,$52,$52,$3E,$00,_
       $7F,$08,$04,$04,$78,$00,_
       $00,$44,$7D,$40,$00,$00,_
       $00,$20,$40,$44,$3D,$00,_
       $7F,$10,$28,$44,$00,$00,_
       $00,$41,$7F,$40,$00,$00,_
       $7C,$04,$18,$04,$78,$00,_
       $7C,$08,$04,$04,$78,$00,_
       $38,$44,$44,$44,$38,$00,_
       $7C,$14,$14,$14,$08,$00,_
       $08,$14,$14,$18,$7C,$00,_
       $7C,$08,$04,$04,$08,$00,_
       $48,$54,$54,$54,$20,$00,_
       $04,$3F,$44,$40,$20,$00,_
       $3C,$40,$40,$20,$7C,$00,_
       $1C,$20,$40,$20,$1C,$00,_
       $3C,$40,$30,$40,$3C,$00,_
       $44,$28,$10,$28,$44,$00,_
       $0C,$50,$50,$50,$3C,$00,_
       $44,$64,$54,$4C,$44,$00,_
       $08,$36,$41,$00,$00,$00,_
       $00,$00,$7F,$00,$00,$00,_
       $00,$00,$41,$36,$08,$00,_
       $00,$08,$04,$08,$04,$00
Pantalla:
// GLCD Picture name: I2cAb.bmp
// GLCD Model: KS0108 128x64
 ldata 255,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,_
   1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,_
   1,  1,  1,  1,  1,  1,  1,  1,  1,  1,129,129,129,193,193,193,_
  97, 97,113,177,177,177,217,217,217,237,237,237,247,247,247,247,_
 247,207, 63,253,241,225,129,  1,  1,  1,  1,  1,  1,  1,  1,255,_
 255,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,128,192, 64, 32,240,240,176,184,216,220,_
 220,236,230,230,246,243,243,251,249,249,253,252,252,254,126,254,_
 255,255,127, 31,239,239,255,255,255,255,255,255,255,255,255,255,_
 255,255,255,254,249,231,223, 63,252,240,224,128,  0,  0,  0,255,_
   0,  0,  0,  0,  0,  2, 15, 53,203,239,221, 83,207,159,159, 63,_
 255,255,231,243,241,195,  9, 61, 61,191,190,238,198,210,216,223,_
 199,247,254,254,252,253,253,252,255,255,127,127,127,191,191,191,_
 255,255,223, 95,111,111,175,179,180,211,207,255,126, 60,  0,255,_
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0, 16,112,248,255,207,_
 239,187,255,191,188,190,222,223,223,239,239,111,111,119,183,183,_
 187,219, 91, 93,101,109,238, 54, 22, 30, 59,255,159,157,149,141,_
 206,254,255,  3,  1,  1,127,120,120,248,255,255, 31,  0,  0,255,_
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  3,  7,_
  11, 30, 19, 19, 11,253,229,229,196,198,226,127, 63,  1,  1,  0,_
  15, 31, 28,124,252,254,  7,  0,  0,  0,  0,  7,  7,  7, 31,255,_
 255,  1,  0,  0,  0,  0,  0,  0,  0,  1, 15, 15,  0,  0,  0,255,_
 255,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,_
 128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,_
 128,128,128,128,128,129,129,129,135,191,191,128,128,128,128,128,_
 128,128,128,128,129,129,128,128,128,128,128,128,128,128,128,128,_
 128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,255
'   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
Dibujo1:
ldata 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,_
 255,255,255,255,255,255,255,255,255, 63, 15, 15,  7, 11, 25, 17,_
  32, 96, 64,128,128,128,  0,  0,  0,  0,  0,  0,  1,  1,  3,  3,_
   7, 15, 31,127,255,255,255,255,255,255,255,255,255,255,255,255,_
 255,255,255,255,255,255,255,255,131,192, 28,  0,192,224,240,248,_
 248,248,248,240,  0,  0,  1,  1,255,254,254,252,252,252,248,248,_
 255, 24, 40,  8,  9,255,255,255,255,255,255,255,255,255,255,255,_
 255,255,255,255,255,255,255,255,255,254,227,224,192,193, 67,227,_
   3,163, 71,  5,  0, 62, 31, 31, 62,  1,  3, 99,  3,131,227, 67,_
   1,192,225,246,255,255,255,255,255,255,255,255,255,255,255,255,_
 255,255,255,255,255,255,255,255,255,255,255,255,255, 63, 63,191,_
 127,255,255,255,255,255,255,255,255,255,255,255,255,255,224,231,_
 199,156, 28, 24, 60, 92,116, 92, 84, 28, 44, 62,158,207,231,224,_
 248,255,255,255,255,255,255,255,255,255,255,255,255,255, 31, 15,_
  15, 15,255,255,255,255,255,255,255,255,255,255,255,255,255,255,_
 255,255,255,255,255,255,255,255,255,255,243,241,240,240,251,249,_
 240,240,240,241,225,227,227,227,247,231,231,239,239,143, 31, 31,_
  63, 63, 63, 62,124,248,120,120,124,124, 62, 63, 63, 31,191,191,_
 175,223,207,199,199,231,235,235,225,245,240,242,249,248,249,250,_
 248,240,240,253,255,255,255,255,255,255,255,255,255,255,255,255,_
 255,255,255,255,255,255,255,255,255,255, 63, 63, 63,127,127, 63,_
  63, 63, 31, 31, 31,159, 15, 79, 15,135,167,199,211,243,227,225,_
 241,241,248,248,248,252,252,254,250,250,241,241,241,243,243,227,_
 231,231,199,135,143,159, 31, 47, 31, 31, 95, 95, 95,159,159, 31,_
  31, 31, 31, 31, 15,143,223,255,255,255,255,255,255,255,255,255,_
 255,255,255,255,255,255,255,255,255,255,255,254,255,224,193,129,_
 194,226,240,253,252,254,254,255,255,255,255,255,255,255,255,255,_
 255,255,255,255,255,255,255,255,254,254,254,252,253,252,248,225,_
 224,192,192,250,255,255,255,255,255,255,255,255,255,255,255,255,_
 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,_'(1 END)
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_'(2 Star)
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  2,254,252,_
 252,248,248,112,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  2,  6, 28,124,248,248,_
 240,240,240,224,224,192,192,128,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,224,254,255,255,_
 255, 31,  3,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  1,  3,_
   3,  7, 15, 15, 31, 31, 31, 63, 63,127,126,126,252,252,248,248,_
 240,224,224,192,192,128,  0,  0,  0,  0,  0, 28,255,255,255, 31,_
 128,128,128,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  1,  3,  7,_
  15, 31, 63,127,255,255,255,255,254,252,248,248,251,255,255,255,_
 254,252,248,240,240,112, 48, 48, 16,  8,  8,  4,  4,  2,  3,  1,_
   0,  0,  0,  0,128,128,  0,  0,  0,  4,  4,  0,  0,  0,  8,  8,_
   8,  8,  8,  8, 12, 15, 15, 15, 15, 15, 15, 15,  7,  7,  7,  3,_
   3,  1,  1,  0,  0,  0,  0,128,128,128,128,128,128,128,128,128,_
   0,  0,  0,  0,  0,  0,  1,  1,  2,  2,  6,  4, 12, 12, 28, 24,_
  56, 56,120,120,120,120,120,248,248,248,248,248,248,252,252,252,_
 124,126,126, 62, 63, 31, 15,  7,  7,  3,  3,  1,  1,  1,  1,  1,_
   1,  1,  1,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,224,224, 32, 32, 32, 32, 32, 96,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  0,192,192,  0,  0,  0,  0,  0,  0,_
   0, 32,224,224,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,255,255,  8,  8,  8,  8, 24,  0,  0,  0,  2,  6,142, 88,_
 112,200,132,  2,  0,  0,  0,  2,255,255,  2,  2,  0,  0,  2,254,_
 254,  2,  2,  3,  6,  0,240,252, 18, 18, 17, 18, 30, 28, 16,  0,_
   2,254,255,  4,  2,  2,  2,254,254,  4,  2,  2,  2,  6,254,  0,_
   0,  0,140,206, 34, 33, 17,254,252,  0,  0,240,252,  6,  2,  1,_
   1,  2,255,255,  0,  0,  0,254,254,  0,  0,  0,  0,254,254,  0,_
   0,  0,  2,254,254,  0,  2,  2,  2,  0,136,206, 66, 33, 33, 18,_
 254,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_'2 (end)
   1,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_'3 star
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,128,128,_
 192, 64, 64, 32, 32, 16, 56,  8, 24,  4,  4,  4,  4,  4,  4,  4,_
   8,  8, 24, 24,240,160, 32, 64,192,128,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,128,192, 64, 32, 16, 16,200,196,194,  7, 39, 49, 48,_
  48, 48, 24,216,216,216,216, 56, 56, 56, 56, 56, 56, 56, 56, 56,_
  40,217,216,222,158,159, 17, 48, 54, 40, 33,  6,212,196,  8, 16,_
  48, 32, 64,192,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,128, 64, 48, 16,  8,  8,_
   4,  6,131,129,  0, 64,112, 58,  9,  9,  8,  4,  4,  4,  4,132,_
 134, 67, 99, 49, 24,  8,  8,  4,  4,  4,  4,  4,  8,  8,  8, 56,_
 112, 64, 64,129,129,  3,  3,  7,  6,  2,  4,  4,  8,  8, 25, 25,_
  50,112, 64,128,129,  3,  6,  4,  8,  8, 56,112, 64,128,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0, 31,  8, 16, 16,  8, 12,_
   2,  3,  1,  0,128,128, 64, 32, 80, 48,152,132,132, 14,  3, 65,_
  64, 96, 96, 96,240,240,240,240,112,112,112,112,112,112,112,240,_
 240,248,252,112, 99,111, 65, 66, 14,  4,136,200,144, 48, 96, 64,_
 128,128,128,  0,  1,  1,  2, 12, 12,  8, 16, 48, 32, 31,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,128, 96, 16,  8,  8,_
   4,  4,  3,  1,  0,  0,131,224,112, 16,  8,  8,  4,  4,  4,  7,_
   3,  3,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,  3,  7,  4,  4,  0,  0,  8, 24, 16, 96,_
 224,128,  1,  2,  2,  7,  4,  8, 16, 24,176,224,  0,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0, 63, 32, 32, 56, 16,  8,_
   4,  6,  2,  1,  1,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,  1,  2,  6,  4,  0,  0, 24, 24, 24, 25, 30,  0,  0,_
   0,  0,  0,  0,192,224,224,224, 32, 32, 32, 32, 32, 32,224,224,_
 224,192,  0,  0,  0,  0,224,224,224,224,  0,  0,  0,224,224,224,_
 224,224,224,224,224,224,224,224,224,224,224,224,224,  0,  0,192,_
 224,224,224,224, 32, 32, 32, 32, 32, 32, 32,224,224,192,  0,  0,_
   0,  0,  0,192,192,224,224,224,224,224,224,224,224,224,224,224,_
 192,192,  0,  0,  0,  0,224,224,224,224, 32, 32, 32, 32, 32, 32,_
  32, 32, 32,224,  0,  0,  0,224,224,224, 32, 32, 32, 32, 32, 32,_
 224,224,192,192,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  6, 31, 63,123,112,224,224,128,128,128,128,128,224,249,_
 249,121,  9,  0,  0,  0,255,255,255,255,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,255,255,255,  0,  0,  0,  0,  0,  0,  0,  0,  0,255,_
 255,255,255,  4,  4,  4,  4,  4,  4,  4, 60,255,255,255,227,192,_
   0,  0, 31,127,127,225,192,192,192,192,192,192,192,192,224,241,_
 255,127, 15,  0,  0,  0,255,255,255,255,134,134,134,134,134,134,_
 134,134,128,192,  0,  0,  0,255,255,255,  0,  0,  0,  0,  0,  0,_
   0,255,255,255,255,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_'3 END
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_'4 star
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,128,_
 128,128,128,160,160,  0,  0, 64,208,208,208,240,240,248,120,120,_
  32, 32,248,248,248,248,240,240,224,192,128, 32,224,224,192,192,_
 192,128,128,128,128,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  2,  7,  5,  5,  7,_
   7,  7,  7,  7,  7,  7,  7,  7,  7,  7,135,199,199,243,255,255,_
 127,127, 59,187,187,255,255,255,255,255,255,126,  9,129,247,127,_
 127, 87,247,247,185,173,173, 13, 69, 69,  4,  0,  0,  0,  0,  0,_
   0,  0,192,224,240,112,112, 72, 56,184,188,140,140,136,188,188,_
 140,140, 92,120,120,184,112, 96, 48,176,176,112,112,176,224,248,_
 184,216,176,240,212,214,246,247,247,247,247,251,255,253,244,252,_
 254,254,255,253,255,255,255,255,127,111,119,250,252,239,239, 43,_
  43,139, 74, 74, 90, 76, 76, 69,  1,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  0,  0,192,192,192, 32, 32, 48,144,_
 144,192, 64, 64,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  4,_
   7, 15,  3,  3,  0,  0,  7, 63,253,239,241,195,195,  2,  3,  0,_
   5,  3,  2,  7,  5, 15, 15, 11, 29, 30, 27, 31, 63, 63,125,223,_
 223,159, 63, 63,127,127,255,255,255,255,255,255,255,255,255,255,_
 255,255,255,255,255,251,247,247,236,248,248,240,240,240,224,224,_
 224,193,128,192,128,128,128,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  0,  7, 31, 31,255,127,255,251,249,_
 249,140,  6,  6,  3,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  1,  7,  7,  3,  7,  7,_
   7,  7,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  1,  1,  1,  2,  2,  6,  5,  5,249,251,255,239,255,255,_
 255,255,223,255,255,255,255,255,159,249,233,255,255,255,255,255,_
 255,255,255,255,255,255,255,255,255,255,158,156,156,248,112,112,_
 240,240,240,240,240,240,248,248,248, 22, 22, 23, 25, 24, 15, 15,_
  15,  7,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  0, 64, 64,192,224,224,224,224,224,224, 96, 96, 96, 96,_
  96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 97, 97,103,231,231,_
 239,239,255,251,243,239, 61, 61,127,255,255,255,255,255,255,191,_
 191, 31, 31, 31, 15, 15, 15,  7,  7,  7,  3,  1,  1,  0, 31, 23,_
  25, 25, 14,  7,  7,  1,  1,  1,  7,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  0,128,128,192,192,192,192,224,224,_
 240,240,240, 48, 48, 56, 28, 28, 28, 14, 14, 15,  7,  7,  3,  3,_
   0,  0,  0,  0,  0,  0,  0,  1,  1,  1,  1,  1,  1,  1,  1,  1,_
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_' 4 END
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_'5 Star
   0,  0,144,184,232, 72,200,224,160,164,216,248,248,232,232,244,_
 244,252, 58, 58,156, 28, 95,127,126,126,127,127,255,252,252,250,_
 254,244,240,232,248,208,192,160,224, 64,128,128,128,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,128,128,128,128,  0,  0,128,128,128,128,_
   0,200,248,180,180,212,210,250,234,234,246,244,188,158,218,156,_
  28,127,255,254,254,255,195,131,167,135,207,221,142,159,125,121,_
 123, 39, 39,  6, 22, 62,125,125,125,253,252,254,255,255,255,255,_
 255,255,255,255,255,255,255,255,255,255,254,254,255,253,250,250,_
 254,244,236,248,248,192,160,224, 64,  0,128,  0,  0,  0,  0,  0,_
   0,  0,  0,  0,128,128,128,128,128,  0,  0,128,192, 64,160,160,_
 192,211,247,253,237,245,245,252,254,251,251,253,239,199,142, 46,_
 127,159,159,153,185,181,167,238,238,220,205,233, 99,119,127,191,_
 191,156, 57,127,127,255,255,255,253,249,249,241,240,226,230,198,_
 134,142,158,158,134,194,192,224,160,  0, 49,177,121,123,239,231,_
 231,239,255,223,159, 61,121,186,178,248,233,253,233,235,231,247,_
 255,255,255,127,127,255,255,191,191,223,222,255,252,236,234,228,_
 216,176, 96,192,128,128,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,  3,  3, 14,  8,  8, 12,  6,  2,  2,255,  0,255,255,_
 254,254,254,253,251,251,255,247,239,255,255,223,191,255,255,127,_
 254,254,255,255,255,255,253,249,241,225,203,131,247,246,246,231,_
 109,248,250,254,254,254,255,157,253,255,255,255,255,255,251,241,_
 229,237,253,221,217,219,243,231,255,254,252,253,253,126,126,254,_
 253,191,191,223,223,255,255,239,247,247,255,255,251,251,253,253,_
 127,127,254,255,191,191,223,255,255,239,239,247,255,255,251,251,_
  29, 29, 22, 23, 31, 15, 98,128,  0,  0,  0,  0,  0,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  3,  4,  3,  7,_
   3, 31, 47, 15, 95,191,191, 63,127,255,223,255,255,255,127,127,_
 254,253,255,255,251,247,255,239,239,223,255,191,191,127,255,255,_
 255,255,255,255,255,255,255,255,255,127,127,191,191,255,255,223,_
 239,239,255,255,247,247,251,251,255,255,253,254,254,255,127,191,_
 191,255,255,223,239,239,255,255,247,247,251,255,255,253, 61,142,_
 139, 11, 15, 31,127,215,191, 63, 31, 15, 15, 15, 15,  7,  7,  3,_
  14, 56, 96,224,224, 32, 32, 51, 30, 48, 32,  0,192,128,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  1,  3,  2,  1,  4, 15, 10, 19, 63,_
  47, 47, 79,119,191,127,127,255,191,255,255,255,255,255,255,254,_
 253,253,255,241,205,190,126,255,255,127,127,191,255,255,223,223,_
 239,239,255,247,247,251,251,255,253,253,254,254,247,255, 69,131,_
   2,  3,  7, 15, 31,111,207, 15,  7,  7,  3,  3,  3,  3,  1,  0,_
   3, 28, 48, 80,208,128,  9, 15,  4, 12, 56, 32,192,  0,  0,  0,_
   0,  0,  0,  0,  0,  1,  3,  2,  0,  4,  4,  5,  0,  2,  3,  0,_
   0,  0,  0,  0,  0,  0,  1,  2,  2,  0,  7, 13, 11,  7, 31, 47,_
  31, 31, 63, 63,127, 15,240,255,255, 95, 63, 51, 63, 50,193,  0,_
   0,  1,  3, 15, 55,231,  3,  3,  3,  1,  1,  0,  0,  0,  0,  1,_
   2, 12, 24, 60, 36, 68,131,131,132,200, 64, 48, 32,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,  1,  3,  2,  2,  3,  1,  0,  0,  0,  0,_
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  3,_
   4, 14, 10, 19, 49,  0,  1, 51, 18, 20, 12,  0,  0,  0,  0,  0,_
Grabo en la menoria y a la hora de recuperar esos graficos y mostralos en pantalla la velocidad es muy lenta.
A 20 Mhz se mejora un poco pero sigue siendo lenta.
 :-/ :5] :-/
Re: Mas velocidad en pantallas graficas (GLCD)
« Respuesta #1 en: 15 de Julio de 2011, 13:53:28 »
Cual es la funcion que dibuja sobre la pantalla y que lee la memoria?...
