Hola a todos!!
Quiero realizar un conversor digital/analógico utilizando el MCP4921, pero a la hora de mirar la librería existente en el CCS C compiler no encuentro las funciones que utiliza para realizar la conversión digital-analógica.
//////////////// Driver for MCP4921 D/A Converter ///////////////////////
//// init_dac() Call this before using a MCP4921 DAC ////
//// write_dac( long int ) Writes command and 12 bit resolution ////
//// to the MCP4921 which converts it to a ////
//// voltage ////
//// 0-4095 input represents 0-vref V out. ////
//// (C) Copyright 1996,2003 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS ////
//// C compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, ////
//// reproduction or distribution is permitted without written ////
//// permission. Derivative programs created using this software ////
//// in object code form are not restricted in any way. ////
#ifndef EEPROM_SELECT
#define DAC_CS PIN_B0
#define DAC_CLK PIN_B1
#define DAC_DI PIN_B2
#define DAC_LDAC PIN_B4
#endif
void init_dac()
output_high(DAC_CS);
output_high(DAC_LDAC);
output_high(DAC_CLK);
output_high(DAC_DI);
void write_dac(int16 data) {
BYTE cmd[3];
BYTE i;
cmd[0]=data;
cmd[1]=(data>>8);
cmd[2]=0x03;
output_low(DAC_CLK);
output_low(DAC_CS);
for(i=0; i<=23; ++i)
if(i<4 || (i>7 && i<12))
shift_left(cmd,3,0);
else
output_bit(DAC_DI, shift_left(cmd,3,0));
output_low(DAC_LDAC);
delay_us(10);
output_HIGH(DAC_LDAC);
Entiendo que se inicializa con el init_dac y luego con el write_dac ¿cómo convierto un número?
