Hola de nuevo Maestros. Si, efectivamente como dice el Maestro Suky, la variable uint8_t es un:
typedef unsigned char uint8_t;
razones del uso?. Basicamente quiero empezar a hacer una programacion mas generica, mas tirada al ANSI, entonces escribi un fichero .h que contiene las definiciones de tipos para usarlas indistintamente del compilador. Ahhhh que va, aqui les comparto el codigo que no es nada del otro mundo por si lo necesitan:
* Copyright (c) 2010 Julian Ramirez "pandemonium"
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* 1. Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* 3. Neither the name of copyright holders nor the names of its
* contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
* TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL COPYRIGHT HOLDERS OR CONTRIBUTORS
* BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
* generic_types.h
* COMENTARIOS: Implementacion de macros y definiciones para estandarizar
* tipos de datos para el uso de fuciones con multiples
* compiladores.
* Programador: Julián Ramirez "pandemonium".
* Compiladores: CCS PCWHD C, HITECH C, C18, C30, MIKROC.
* Dependencias: no.
* Procesadores: PIC12*, PIC16*, PIC18*, PIC24*, dsPIC.
* Cambios Historia:
* Rev Fecha Descripcion
* 1.0 03/01/10 Definicion de tipos de datos genericos y tablas de bits
#ifndef __GENERIC_TYPES_H_
#define __GENERIC_TYPES_H_
#endif
/* obtener los tipos da datos especificos del compilador (NULL, size_t, etc) */
#if !defined(__MIKROC_PRO_FOR_PIC__)
#include <stddef.h>
#endif
#define void VOID
#define PRIVATE static
#if defined(__PICC__) /* HT-PICC10/12/16 */
typedef bit boolean_t;
typedef signed char char_t, int8_t;
typedef signed int int_t, int16_t;
typedef signed short short_t;
typedef signed short long short_long_t, int24_t;
typedef signed long long_t, int32_t;
typedef float float_t;
typedef double double_t;
typedef unsigned char uchar_t, uint8_t;
typedef unsigned int uint_t, uint16_t;
typedef unsigned short ushort_t, d_word;
typedef unsigned short long ushort_long_t, uint24_t;
typedef unsigned long ulong_t, uint32_t, q_word;
#elif defined(__PICC18__) /* HT-PICC18 */
#elif defined(__18CXX) /* Microchip C18 */
typedef signed short long int24_t;
typedef unsigned short long uint24_t;
#elif defined(__C30__) /* Microchip C30 */
typedef signed long long long_long_t, int64_t;
typedef long double double_t;
typedef unsigned long long ulong_long_t, uint64_t;
#elif defined(__PCB__) || defined(__PCM__) || defined(__PCH__) /* CCS para PIC18 o PIC16 */
typedef int1 boolean_t;
typedef signed char char_t;
typedef signed int int8_t;
typedef signed long int_t, int16_t, short_t;
typedef signed long long long_t, int32_t;
typedef unsigned char uchar_t;
typedef unsigned int uint8_t;
typedef unsigned long uint_t, uint16_t, ushort_t, d_word;
typedef unsigned long long ulong_t, uint32_t, q_word;
#elif defined(__PCD__)
typedef signed short int8_t;
typedef signed int int_t, int16_t, short_t;
typedef unsigned short uint8_t;
typedef unsigned int uint_t, uint16_t, ushort_t, d_word;
#elif defined(__MIKROC_PRO_FOR_PIC__)
typedef signed long int long_t, int32_t;
typedef unsigned long int ulong_t, uint32_t, q_word;
//#elif defined(__AVR__)
//#elif defined(__ICCAVR__)
#endif
#if defined(__C18xx) || defined(__C30__) || defined(__PCD__)
#ifdef false
#undef false
#endif
#ifdef true
#undef true
#endif
typedef enum _BOOL{ false=0, true} boolean_t; // Undefined size
typedef enum _BIT{ clear=0, set} bit_t;
#define false 0
#define true 1
#endif
#if defined(__MIKROC_PRO_FOR_PIC__)
typedef enum _BOOL{ false_t=0, true_t} boolean_t; // Undefined size
typedef enum _BIT{ clear_t=0, set_t} bit_t;
#endif
typedef union{
uint8_t data;
struct{
uint8_t b0 :1;
uint8_t b1 :1;
uint8_t b2 :1;
uint8_t b3 :1;
uint8_t b4 :1;
uint8_t b5 :1;
uint8_t b6 :1;
uint8_t b7 :1;
}uint8_bits;
typedef union{
uint16_t dword;
uint8_t a_byte[2];
struct{
uint8_t byte_0;
uint8_t byte_1;
struct{
uint8_t b0 :1;
uint8_t b1 :1;
uint8_t b2 :1;
uint8_t b3 :1;
uint8_t b4 :1;
uint8_t b5 :1;
uint8_t b6 :1;
uint8_t b7 :1;
uint8_t b8 :1;
uint8_t b9 :1;
uint8_t b10 :1;
uint8_t b11 :1;
uint8_t b12 :1;
uint8_t b13 :1;
uint8_t b14 :1;
uint8_t b15 :1;
}uint16_bits;
typedef union{
uint32_t qword;
uint16_t dword[2];
uint8_t a_byte[4];
struct{
uint16_t l_word;
uint16_t h_word;
struct{
uint8_t byte_0;
uint8_t byte_1;
uint8_t byte_2;
uint8_t byte_3;
struct{
uint8_t b0 :1;
uint8_t b1 :1;
uint8_t b2 :1;
uint8_t b3 :1;
uint8_t b4 :1;
uint8_t b5 :1;
uint8_t b6 :1;
uint8_t b7 :1;
uint8_t b8 :1;
uint8_t b9 :1;
uint8_t b10 :1;
uint8_t b11 :1;
uint8_t b12 :1;
uint8_t b13 :1;
uint8_t b14 :1;
uint8_t b15 :1;
uint8_t b16 :1;
uint8_t b17 :1;
uint8_t b18 :1;
uint8_t b19 :1;
uint8_t b20 :1;
uint8_t b21 :1;
uint8_t b22 :1;
uint8_t b23 :1;
uint8_t b24 :1;
uint8_t b25 :1;
uint8_t b26 :1;
uint8_t b27 :1;
uint8_t b28 :1;
uint8_t b29 :1;
uint8_t b30 :1;
uint8_t b31 :1;
}uint32_bits;
Con este codigo podemos acceder los bytes y los bits de las variables que declaremos de una manera mas rápida y sencilla sin tener que estar usando esas funciones incluidas en algunos compiladores que a la larga sólo nos genera dependencia.
Ahora bien, resulta que me surgió la duda inicial del post, pero veo que con el ejemplo del Maestro Angelgris ya está claro que acceder directamente a la union sin el uso del operador .(punto) no sólamente es ilegal sino que a mi parecer es garrafal el hecho de que funcione en ccs
. Cada vez me convenzo mas de usar hitech C o c18. Pero la pega de siempre es su elevado precio
de todas formas gracias por su rápida respuesta, ya me quedó claro.
