Podes colocar Size en 2 en el parámetro de la función si estas usando las librerías de CCS. Otra es crear las fuentes tu mismo y a gusto, pero si cambia el tamaño de los pixeles tienes que realizar la función que la dibuje Saludos!
unsigned const char uno[]={0x08,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x0c,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x0c,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0xfe,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0xfe,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,'$'};unsigned const char dos[]={0x10,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x1c,0x00,0x0c,0x00,0x00,0x00,0x00,0x00,0x0e,0x00,0x0e,0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x0f,0x00,0x00,0x00,0x00,0x00,0x07,0x80,0x0f,0x00,0x00,0x00,0x00,0x00,0x07,0x40,0x0f,0x00,0x00,0x00,0x00,0x00,0x07,0x30,0x0f,0x00,0x00,0x00,0x00,0x00,0x1f,0x1c,0x0f,0x00,0x00,0x00,0x00,0x00,0xff,0x0f,0x0f,0x00,0x00,0x00,0x00,0x00,0xfe,0x07,0x0f,0x00,0x00,0x00,0x00,0x00,0xfe,0x03,0x0f,0x00,0x00,0x00,0x00,0x00,0x78,0x00,0x0f,0x00,0x00,0x00,0x00,0x00,0x00,0xc0,0x01,'$'};unsigned const char tres[]={0x00,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0x08,0x80,0x07,0x00,0x00,0x00,0x00,0x00,0x04,0x80,0x0f,0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x0f,0x00,0x00,0x00,0x00,0x00,0x82,0x00,0x0e,0x00,0x00,0x00,0x00,0x00,0x83,0x03,0x0c,0x00,0x00,0x00,0x00,0x00,0xc3,0x03,0x0c,0x00,0x00,0x00,0x00,0x00,0xe7,0x07,0x0c,0x00,0x00,0x00,0x00,0x00,0xff,0x1f,0x06,0x00,0x00,0x00,0x00,0x00,0xbf,0xff,0x07,0x00,0x00,0x00,0x00,0x00,0x9e,0xff,0x03,0x00,0x00,0x00,0x00,0x00,0x0c,0xff,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x7c,'$'};unsigned const char cuatro[]={0x00,0xfc,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xe7,0x00,0x00,0x00,0x00,0x00,0x00,0xc0,0xe3,0x00,0x00,0x00,0x00,0x00,0x00,0xe0,0xe0,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0xe0,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0xe0,0x00,0x00,0x00,0x00,0x00,0x00,0xfc,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0xfe,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0x00,0xe0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe0,'$'};unsigned const char cinco[]={0x80,0x07,0x07,0x00,0x00,0x00,0x00,0x00,0xf0,0x07,0x0f,0x00,0x00,0x00,0x00,0x00,0xfc,0x07,0x0f,0x00,0x00,0x00,0x00,0x00,0xcf,0x07,0x0e,0x00,0x00,0x00,0x00,0x00,0xcf,0x07,0x0e,0x00,0x00,0x00,0x00,0x00,0xcf,0x07,0x0c,0x00,0x00,0x00,0x00,0x00,0xcf,0x0f,0x0c,0x00,0x00,0x00,0x00,0x00,0x8f,0x0f,0x0c,0x00,0x00,0x00,0x00,0x00,0x8f,0x1f,0x0c,0x00,0x00,0x00,0x00,0x00,0x0f,0x3f,0x06,0x00,0x00,0x00,0x00,0x00,0x0f,0xfc,0x03,0x00,0x00,0x00,0x00,0x00,0x07,0xf8,0x01,'$'};unsigned const char seis[]={0x00,0xff,0x00,0x00,0x00,0x00,0x00,0x00,0xc0,0xff,0x03,0x00,0x00,0x00,0x00,0x00,0xe0,0xff,0x07,0x00,0x00,0x00,0x00,0x00,0xf0,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0xf8,0x03,0x0f,0x00,0x00,0x00,0x00,0x00,0x9c,0x03,0x0c,0x00,0x00,0x00,0x00,0x00,0x8e,0x03,0x0c,0x00,0x00,0x00,0x00,0x00,0x86,0x03,0x0c,0x00,0x00,0x00,0x00,0x00,0x87,0x07,0x0e,0x00,0x00,0x00,0x00,0x00,0x83,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0x03,0xff,0x07,0x00,0x00,0x00,0x00,0x00,0x03,0xff,0x03,0x00,0x00,0x00,0x00,0x00,0x01,0xf8,0x01,'$'};unsigned const char siete[]={0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0f,0x00,0x0c,0x00,0x00,0x00,0x00,0x00,0x0f,0x00,0x0f,0x00,0x00,0x00,0x00,0x00,0x0f,0xe0,0x0f,0x00,0x00,0x00,0x00,0x00,0x0f,0xfc,0x01,0x00,0x00,0x00,0x00,0x00,0xcf,0x3f,0x00,0x00,0x00,0x00,0x00,0x00,0xff,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x7f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,'$'};unsigned const char ocho[]={0x78,0xe0,0x03,0x00,0x00,0x00,0x00,0x00,0xfc,0xf0,0x07,0x00,0x00,0x00,0x00,0x00,0xfe,0xfb,0x0f,0x00,0x00,0x00,0x00,0x00,0xff,0x1f,0x0e,0x00,0x00,0x00,0x00,0x00,0xc3,0x0f,0x0c,0x00,0x00,0x00,0x00,0x00,0x81,0x0f,0x0c,0x00,0x00,0x00,0x00,0x00,0x81,0x1f,0x0c,0x00,0x00,0x00,0x00,0x00,0x81,0x3f,0x0c,0x00,0x00,0x00,0x00,0x00,0xc3,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0xff,0xfc,0x07,0x00,0x00,0x00,0x00,0x00,0x7e,0xf8,0x03,0x00,0x00,0x00,0x00,0x00,0x3c,0xf0,0x01,'$'};unsigned const char nueve[]={0xf8,0x07,0x08,0x00,0x00,0x00,0x00,0x00,0xfc,0x0f,0x0c,0x00,0x00,0x00,0x00,0x00,0xfe,0x1f,0x0c,0x00,0x00,0x00,0x00,0x00,0xff,0x1f,0x0c,0x00,0x00,0x00,0x00,0x00,0x87,0x1f,0x0e,0x00,0x00,0x00,0x00,0x00,0x03,0x18,0x06,0x00,0x00,0x00,0x00,0x00,0x03,0x18,0x07,0x00,0x00,0x00,0x00,0x00,0x03,0xd8,0x03,0x00,0x00,0x00,0x00,0x00,0x3f,0xf8,0x03,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0x01,0x00,0x00,0x00,0x00,0x00,0xfe,0xff,0x00,0x00,0x00,0x00,0x00,0x00,0xfc,0x7f,0x00,0x00,0x00,0x00,0x00,0x00,0xf0,0x1f,'$'};unsigned const char cero[]={0xf0,0xff,0x00,0x00,0x00,0x00,0x00,0x00,0xfc,0xff,0x03,0x00,0x00,0x00,0x00,0x00,0xfe,0xff,0x07,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0x0f,0x00,0x0f,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x07,0x00,0x0e,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0xfe,0xff,0x07,0x00,0x00,0x00,0x00,0x00,0xfc,0xff,0x03,0x00,0x00,0x00,0x00,0x00,0xf0,0xff,'$'};
Si te sirve, va de regalo de Navidad una fuente que hice para numeros grandes Código: [Seleccionar]unsigned const char uno[]={0x08,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x0c,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x0c,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0xfe,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0xfe,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,'$'};unsigned const char dos[]={0x10,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x1c,0x00,0x0c,0x00,0x00,0x00,0x00,0x00,0x0e,0x00,0x0e,0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x0f,0x00,0x00,0x00,0x00,0x00,0x07,0x80,0x0f,0x00,0x00,0x00,0x00,0x00,0x07,0x40,0x0f,0x00,0x00,0x00,0x00,0x00,0x07,0x30,0x0f,0x00,0x00,0x00,0x00,0x00,0x1f,0x1c,0x0f,0x00,0x00,0x00,0x00,0x00,0xff,0x0f,0x0f,0x00,0x00,0x00,0x00,0x00,0xfe,0x07,0x0f,0x00,0x00,0x00,0x00,0x00,0xfe,0x03,0x0f,0x00,0x00,0x00,0x00,0x00,0x78,0x00,0x0f,0x00,0x00,0x00,0x00,0x00,0x00,0xc0,0x01,'$'};unsigned const char tres[]={0x00,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0x08,0x80,0x07,0x00,0x00,0x00,0x00,0x00,0x04,0x80,0x0f,0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x0f,0x00,0x00,0x00,0x00,0x00,0x82,0x00,0x0e,0x00,0x00,0x00,0x00,0x00,0x83,0x03,0x0c,0x00,0x00,0x00,0x00,0x00,0xc3,0x03,0x0c,0x00,0x00,0x00,0x00,0x00,0xe7,0x07,0x0c,0x00,0x00,0x00,0x00,0x00,0xff,0x1f,0x06,0x00,0x00,0x00,0x00,0x00,0xbf,0xff,0x07,0x00,0x00,0x00,0x00,0x00,0x9e,0xff,0x03,0x00,0x00,0x00,0x00,0x00,0x0c,0xff,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x7c,'$'};unsigned const char cuatro[]={0x00,0xfc,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xe7,0x00,0x00,0x00,0x00,0x00,0x00,0xc0,0xe3,0x00,0x00,0x00,0x00,0x00,0x00,0xe0,0xe0,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0xe0,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0xe0,0x00,0x00,0x00,0x00,0x00,0x00,0xfc,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0xfe,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0x00,0xe0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe0,'$'};unsigned const char cinco[]={0x80,0x07,0x07,0x00,0x00,0x00,0x00,0x00,0xf0,0x07,0x0f,0x00,0x00,0x00,0x00,0x00,0xfc,0x07,0x0f,0x00,0x00,0x00,0x00,0x00,0xcf,0x07,0x0e,0x00,0x00,0x00,0x00,0x00,0xcf,0x07,0x0e,0x00,0x00,0x00,0x00,0x00,0xcf,0x07,0x0c,0x00,0x00,0x00,0x00,0x00,0xcf,0x0f,0x0c,0x00,0x00,0x00,0x00,0x00,0x8f,0x0f,0x0c,0x00,0x00,0x00,0x00,0x00,0x8f,0x1f,0x0c,0x00,0x00,0x00,0x00,0x00,0x0f,0x3f,0x06,0x00,0x00,0x00,0x00,0x00,0x0f,0xfc,0x03,0x00,0x00,0x00,0x00,0x00,0x07,0xf8,0x01,'$'};unsigned const char seis[]={0x00,0xff,0x00,0x00,0x00,0x00,0x00,0x00,0xc0,0xff,0x03,0x00,0x00,0x00,0x00,0x00,0xe0,0xff,0x07,0x00,0x00,0x00,0x00,0x00,0xf0,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0xf8,0x03,0x0f,0x00,0x00,0x00,0x00,0x00,0x9c,0x03,0x0c,0x00,0x00,0x00,0x00,0x00,0x8e,0x03,0x0c,0x00,0x00,0x00,0x00,0x00,0x86,0x03,0x0c,0x00,0x00,0x00,0x00,0x00,0x87,0x07,0x0e,0x00,0x00,0x00,0x00,0x00,0x83,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0x03,0xff,0x07,0x00,0x00,0x00,0x00,0x00,0x03,0xff,0x03,0x00,0x00,0x00,0x00,0x00,0x01,0xf8,0x01,'$'};unsigned const char siete[]={0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0f,0x00,0x0c,0x00,0x00,0x00,0x00,0x00,0x0f,0x00,0x0f,0x00,0x00,0x00,0x00,0x00,0x0f,0xe0,0x0f,0x00,0x00,0x00,0x00,0x00,0x0f,0xfc,0x01,0x00,0x00,0x00,0x00,0x00,0xcf,0x3f,0x00,0x00,0x00,0x00,0x00,0x00,0xff,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x7f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,'$'};unsigned const char ocho[]={0x78,0xe0,0x03,0x00,0x00,0x00,0x00,0x00,0xfc,0xf0,0x07,0x00,0x00,0x00,0x00,0x00,0xfe,0xfb,0x0f,0x00,0x00,0x00,0x00,0x00,0xff,0x1f,0x0e,0x00,0x00,0x00,0x00,0x00,0xc3,0x0f,0x0c,0x00,0x00,0x00,0x00,0x00,0x81,0x0f,0x0c,0x00,0x00,0x00,0x00,0x00,0x81,0x1f,0x0c,0x00,0x00,0x00,0x00,0x00,0x81,0x3f,0x0c,0x00,0x00,0x00,0x00,0x00,0xc3,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0xff,0xfc,0x07,0x00,0x00,0x00,0x00,0x00,0x7e,0xf8,0x03,0x00,0x00,0x00,0x00,0x00,0x3c,0xf0,0x01,'$'};unsigned const char nueve[]={0xf8,0x07,0x08,0x00,0x00,0x00,0x00,0x00,0xfc,0x0f,0x0c,0x00,0x00,0x00,0x00,0x00,0xfe,0x1f,0x0c,0x00,0x00,0x00,0x00,0x00,0xff,0x1f,0x0c,0x00,0x00,0x00,0x00,0x00,0x87,0x1f,0x0e,0x00,0x00,0x00,0x00,0x00,0x03,0x18,0x06,0x00,0x00,0x00,0x00,0x00,0x03,0x18,0x07,0x00,0x00,0x00,0x00,0x00,0x03,0xd8,0x03,0x00,0x00,0x00,0x00,0x00,0x3f,0xf8,0x03,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0x01,0x00,0x00,0x00,0x00,0x00,0xfe,0xff,0x00,0x00,0x00,0x00,0x00,0x00,0xfc,0x7f,0x00,0x00,0x00,0x00,0x00,0x00,0xf0,0x1f,'$'};unsigned const char cero[]={0xf0,0xff,0x00,0x00,0x00,0x00,0x00,0x00,0xfc,0xff,0x03,0x00,0x00,0x00,0x00,0x00,0xfe,0xff,0x07,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0x0f,0x00,0x0f,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x07,0x00,0x0e,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0x0f,0x00,0x00,0x00,0x00,0x00,0xfe,0xff,0x07,0x00,0x00,0x00,0x00,0x00,0xfc,0xff,0x03,0x00,0x00,0x00,0x00,0x00,0xf0,0xff,'$'};
