#include <16F877A.h>
#fuses HS, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock = 20000000)
#use rs232 (baud=9600,xmit=PIN_C6,rcv=PIN_C7)
#priority CCP1, TIMER1
#define BytePtr(var, offset) (char *)((char*)&var + offset)
#byte PIR1 = 0x0C
#bit TMR1IF = PIR1.0
int8 gc_timer1_extension = 0;
int8 gc_capture_flag = FALSE;
int32 g32_ccp_delta;
#int_timer1
void timer1_isr(void)
gc_timer1_extension++;
#int_ccp1
void ccp1_isr(void)
char timer_ext_copy;
int32 current_ccp;
static int32 old_ccp = 0;
gc_capture_flag = TRUE;
current_ccp = (int32)CCP_1;
// Get local copy of the timer ext.
timer_ext_copy = gc_timer1_extension;
if(TMR1IF)
if(*BytePtr(current_ccp, 1) < 2) // Was CCP captured after Timer1 wrapped?
timer_ext_copy++; // If so, inc the copy of the timer ext.
// Since we know a timer interrupt is pending, let's just
// handle it here and now. That saves a little load off
// the processor.
gc_timer1_extension++; // Increment the real timer extension
TMR1IF = 0; // Then clear the Timer1 interrupt
// Insert the timer extension into the proper place in the 32-bit
// CCP value.
// ie., Insert it into location "EE" as follows: 0x00EEnnnn
// (nnnn = the CCP).
*BytePtr(current_ccp, 2) = timer_ext_copy;
g32_ccp_delta = (current_ccp > old_ccp) ? current_ccp - old_ccp : current_ccp + (0x1000000 - old_ccp);
// Save the current ccp value for next time.
old_ccp = current_ccp;
void main()
float frequency;
int32 current_ccp_delta;
set_timer1(0);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
setup_ccp1(CCP_CAPTURE_RE);
// Enable interrupts.
clear_interrupt(INT_TIMER1);
clear_interrupt(INT_CCP1);
enable_interrupts(INT_CCP1);
enable_interrupts(GLOBAL);
while(1) {
if(gc_capture_flag == TRUE)
//disable_interrupts(GLOBAL);
current_ccp_delta = g32_ccp_delta;;
frequency = (5000000L / (float)current_ccp_delta);
printf("%4.2f\n\r", frequency
else
delay_ms(500);
