Ola
estou a usar o seguinte codigo para fazer um "blinking" so que tenho a impressao que a função " delay_ms(1000); " não é um atrazo de 1segundo mas sim de 18 segundos ... onde esta o meu problema ?
#include <18F2685.h>
#device adc=8
#FUSES NOWDT //No Watch Dog Timer
#FUSES WDT128 //Watch Dog Timer uses 1:128 Postscale
#FUSES LP //Low power osc < 200 khz
#FUSES NOPROTECT //Code not protected from reading
#FUSES NOBROWNOUT //No brownout reset
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES NOPUT //No Power Up Timer
#FUSES NOCPD //No EE protection
#FUSES STVREN //Stack full/underflow will cause reset
#FUSES NODEBUG //No Debug mode for ICD
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT //Program memory not write protected
#FUSES NOWRTD //Data EEPROM not write protected
#FUSES IESO //Internal External Switch Over mode enabled
#FUSES FCMEN //Fail-safe clock monitor enabled
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES BBSIZ4K //4K words Boot Block size
#FUSES NOWRTC //configuration not registers write protected
#FUSES NOWRTB //Boot block not write protected
#FUSES NOEBTR //Memory not protected from table reads
#FUSES NOEBTRB //Boot block not protected from table reads
#FUSES NOCPB //No Boot Block code protection
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES MCLR //Master Clear pin enabled
#FUSES NOXINST //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(clock=20000000)
#use rs232(baud=9600, parity=N, xmit=PIN_C6, rcv=PIN_C7, STOP=1, BITS=8)// ,TIMEOUT = 1000)
#define LED PIN_A0 //CHANGE PIN_XX TO YOUR LED PIN NUMBER, EX: PIN_A5
void main()
setup_adc_ports(NO_ANALOGS|VSS_VDD);
setup_adc(ADC_CLOCK_DIV_2|ADC_TAD_MUL_0);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_ccp1(CCP_OFF);
setup_vref(FALSE);
//Example blinking LED program
while(input (PIN_A5) ){
printf (" LED APAGADO");
output_low(LED);
delay_ms(1000);
output_high(LED);
printf (" LED ACESSO");
delay_ms(1000);
Cumprimentos
Zé tretas
