Hola
Talvez te sirva de poco, pero hay un ejemplo de manejo de SRAM por SPI en C30 con un PIC24. Talvez puedas modificarlo para tu dspic.
Está en la ayuda de C30:
#define USE_AND_OR
#include<p24fxxxx.h>
#include <string.h>
#include <spi.h>
#include <sram.h>
#if defined(__PIC24FJ128GA010__)
/*************** COFIGURATION **************************************
* Watchdog Timer Disabled
* Two Speed Start-up enabled
* Oscillator Selection: HS oscillator ( 8MHz crystal on EXPLORER 16 Board )
* Clock switching and clock monitor both enabled
_CONFIG1( JTAGEN_OFF & GCP_OFF & GWRP_OFF & COE_OFF & FWDTEN_OFF & ICS_PGx2)
_CONFIG2(IESO_OFF & FCKSM_CSDCMD & OSCIOFNC_OFF & POSCMOD_HS & FNOSC_PRIPLL)
#endif
unsigned char ReadVal;
unsigned char SRAMBuf[SRAM_PAGE_SIZE]; //Used to perform read/write operations from/to SRAM
void InitSRAM(void);
#define SRAM_SCK LATFbits.LATF6
#define SRAM_MISO PORTFbits.RF7
#define SRAM_MOSI LATFbits.LATF8
#define SRAM_CS_TRIS TRISFbits.TRISF2
#define SRAM_SCK_TRIS TRISFbits.TRISF6
#define SRAM_MISO_TRIS TRISFbits.TRISF7
#define SRAM_MOSI_TRIS TRISFbits.TRISF8
int main(void)
unsigned char Cnt;
InitSRAM(); //Initialize SRAM
while(1)
//Select Page mode in SRAM
SRAMWriteStatusReg(SRAM_PAGE_MODE);
//Read Status Register
ReadVal = SRAMReadStatusReg();
//Write Byte operation
//Write 0x28 to 0x1000 memory location of SRAM
SRAMWriteByte(0x00,0x10,0x28);
ReadVal = 0x00;
//Read Byte operation
//Read 0x1000 memory location of SRAM
ReadVal = SRAMReadByte(0x00,0x10);
//Page Write operation
//Write 32bytes from SRAMBuf array to first page of SRAM
for(Cnt = 0;Cnt<32;Cnt++)
SRAMBuf[Cnt] = (0xAA - Cnt);
SRAMWritePage(0x00,0x20,SRAMBuf);
//Page Read operation
//Read 32bytes from SRAMBuf array from first page of SRAM
memset(SRAMBuf,0,sizeof(SRAMBuf)); //Reset SRAMBuf location to 0x00 value
SRAMReadPage(0x00,0x20,SRAMBuf);
//Sequential Write operation
//Write 10bytes from SRAMBuf to SRAM starting from 0x1000 memory location
SRAMBuf[Cnt] =(0x55-Cnt);
SRAMWriteSeq(0x10,0x10,SRAMBuf,10);
//Sequential Read operation
//Read 10bytes starting from 0x1010 memory location of SRAM and store it to SRAMBuf array
SRAMReadSeq(0x10,0x10,SRAMBuf,10);
void InitSRAM(void)
SRAM_CS = 1;
SRAM_SCK = 0;
SRAM_CS_TRIS = 0;
SRAM_SCK_TRIS = 0;
SRAM_MISO_TRIS = 1;
SRAM_MOSI_TRIS = 0;
CloseSPI1(); /* Turn off SPI module 1 */
OpenSPI1((SPI_CKE_ON|MASTER_ENABLE_ON|SEC_PRESCAL_1_1|PRI_PRESCAL_4_1),
FRAME_ENABLE_OFF,SPI_ENABLE);
