Autor Tema: Ayuda con button de mikrobasic  (Leído 2290 veces)
Desconectado gally
« en: 13 de Junio de 2010, 23:56:13 »
Hola amigos necesito ayuda con la libreria button; estoy diseñando el soft para mi insoladora y estoy trabajando con el TMR0 que supuestamente es mas dificil de usar que la libreria button de mikrobasic pero siguiendo el datasheet me a quedado bastante claro (aunque no se calcular todavia muy bien los tiempos, para ello utilizo un soft que he encontrado en el foro).
Bueno al caso lo que quiero es que cuando pulse el boton y el timer este parado empieze a andar pero no lo consigo.
este es mi codigo:
program insoladora
dim LCD_RS as sbit at RB4_bit
    LCD_EN as sbit at RB5_bit
    LCD_D4 as sbit at RB0_bit
    LCD_D5 as sbit at RB1_bit
    LCD_D6 as sbit at RB2_bit
    LCD_D7 as sbit at RB3_bit
    LCD_RS_Direction as sbit at TRISB4_bit
    LCD_EN_Direction as sbit at TRISB5_bit
    LCD_D4_Direction as sbit at TRISB0_bit
    LCD_D5_Direction as sbit at TRISB1_bit
    LCD_D6_Direction as sbit at TRISB2_bit
    LCD_D7_Direction as sbit at TRISB3_bit
' End Lcd module connections
dim txt1 as string[16]
    txt2 as string[3]
    txt3 as string[8]
    txt4 as char[7]
    i    as byte
    oldstate as byte
    counter as integer
    segundos as integer
    ts1 as TimeStruct
    tinicial as TimeStruct
sub procedure final()
 sound_play(659.26,125)
 delay_ms(125)
 delay_ms(125)
 sound_play(783.99,250)
end sub
sub procedure formatear(dim byref tiempo as TimeStruct)
dim temp as string[3]
bytetostr(tiempo.mn,temp)
ltrim(temp)
if tiempo.mn < 10 then
txt1 = "0" + temp
else
txt1 = temp
end if
txt1 = txt1 + ":"
bytetostr(tiempo.ss,temp)
ltrim(temp)
if tiempo.ss < 10 then
txt1 = txt1 + "0" + temp
else
txt1 = txt1 + temp
end if
end sub
sub procedure interrupt
  counter = counter + 1
  TMR0L = 8
  INTCON.2 = 0
  if counter = 1000 then
     if ts1.ss = 0 then
     if ts1.mn = 0 then
     T0CON.7 = 0
     final()
     else
     if ts1.ss = 0 then
     ts1.mn = ts1.mn - 1
     ts1.ss = 59
     else
     ts1.ss = ts1.ss - 1
     end if
     end if
      else
     ts1.ss = ts1.ss - 1
     end if
     counter = 0
  end if
end sub
main:
  RCON.7 = 0
  INTCON.7 = 1
  INTCON.5 = 1
  INTCON.2 = 0
   T0CON = %01000010
  TRISB = 0
  PORTB = 0xFF
  TRISB = 0x00
  TRisa.4 = 1
  Portb.6 = 0
 Sound_init(PORTA,5)
 adcon0=0     ' Sin ADC's, Sin Comparadores PORTA Entrada
 adcon1=15
 cmcon=7
  Lcd_Init()                        ' Initialize Lcd
  Lcd_Cmd(_LCD_CLEAR)               ' Clear display
  Lcd_Cmd(_LCD_CURSOR_OFF)          ' Cursor off
  tinicial.mn = EEPROM_read(0)
  Delay_ms(20)
  tinicial.ss = EEPROM_read(1)
  oldstate = 0
  T0CON = %01000010
  while TRUE
  if (Button(PORTA, 4, 50, 0) and T0CON.7 = 0) then
    oldstate = 255
  end if
  if (oldstate and Button(PORTA, 4, 50, 1) and T0CON.7 = 0) then
  ts1 = tinicial
    T0CON.7 = 1
    oldstate = 0
  end if
  If i > ts1.ss then
  'sound_play(698,250)
  i = ts1.ss
  end if
  formatear(ts1)
    lcd_out(1,1,txt1)
    bytetostr(oldstate,txt2)
    bytetostr(T0CON, txt3)
    lcd_out(2,1, txt2)
    lcd_out(2,5,txt3)
  wend
end.
y este mi esquema:
os he resaltado el circuito del boton  ;-)
Desconectado gally
Re: Ayuda con button de mikrobasic
« Respuesta #1 en: 14 de Junio de 2010, 11:40:46 »
ya lo he solucionado, me estaba fallando el T0CON.7 = 0 lo he quitado y funciona de vicio.
Desconectado NORTEÑO
« Respuesta #2 en: 14 de Junio de 2010, 14:23:21 »
Hola:
Me alegro mucho que lo hayas solucionado.
