GUARDA ESTA MACRO COMO MACROPIC.INC ESTAS MACROS TE AYUDARAN A RESOLVER TUS PROBLEMAS MAS RAPIDOS
; Filename: macropic.inc *
; File Version: 1.0 *
; Author: Manuel Alejandro Rodríguez Infantes *
; Company: UNFV *
; Files required: *
; Notes: *
; Aplicaciones Avanzadas con PIC *
;************************************************************** banco x
banco macro x
if x == 0
bcf STATUS,RP0
bcf STATUS,RP1
endif
if x == 1
bsf STATUS,RP0
bcf STATUS,RP1
endif
if x == 2
bcf STATUS,RP0
bsf STATUS,RP1
endif
if x == 3
bsf STATUS,RP0
bsf STATUS,RP1
endif
endm
;************************************************************** pagina
pagina macro x
if x == 0
bcf PCLATH,3
bcf PCLATH,4
endif
if x == 1
bsf PCLATH,3
bcf PCLATH,4
endif
if x == 2
bcf PCLATH,3
bsf PCLATH,4
endif
if x == 3
bsf PCLATH,3
bsf PCLATH,4
endif
endm
;************************************************************** mov
mov macro registro,literal
movlw literal
movwf registro
endm
;************************************************************** movr
movr macro registro1,registro2
movf registro2,0
movwf registro1
endm
;************************************ compara y salta si no es igual
cjne macro registro,dato,direcc
movlw dato
subwf registro,0
btfss STATUS,Z
goto direcc
endm
cjner macro registro1,registro2,direcc
movf registro2,0
subwf registro1,0
btfss STATUS,Z
goto direcc
endm
;************************************ compara y salta si es igual
cje macro registro,dato,direcc
movlw dato
subwf registro,0
btfsc STATUS,Z
goto direcc
endm
cjer macro registro1,registro2,direcc
movf registro2,0
subwf registro1,0
btfsc STATUS,Z
goto direcc
endm
;*************************** decrementa, compara y salta si no es igual
dcjne macro registro,dato,direcc
decf registro,1
movlw dato
subwf registro,0
btfss STATUS,Z
goto direcc
endm
;*************************** compara y salta si es menor
cjl macro registro,dato,direcc
movlw dato
subwf registro,0 ; W = REGISTRO - W
btfss STATUS,C ; ¿C="1"?
goto direcc
endm
;********************* compara y salta si es menor igual
cjle macro registro,dato,direcc
movlw dato
goto direcc
btfsc STATUS,Z ; ¿Z="0"?
goto direcc
endm
;************************ compara y salta si no es menor
cjnl macro registro,dato,direcc
movlw dato
btfsc STATUS,C ; ¿C="0"?
goto direcc
endm
;********************** compara y salta si es mayor o igual
cjge macro registro,dato,direcc
movlw dato
goto direcc
endm
;************************************************* esuno
esuno MACRO REGISTRO,BIT
local no_es_uno_1
no_es_uno_1
btfss REGISTRO,BIT
goto no_es_uno_1
endm
;************************************************* escero
escero MACRO REGISTRO,BIT
local no_es_cero_1
no_es_cero_1
btfsc REGISTRO,BIT
goto no_es_cero_1
endm
jmp MACRO Direccion
goto Direccion
endm
jz MACRO Direccion
btfsc STATUS,Z
goto Direccion
endm
jnz MACRO Direccion
btfss STATUS,Z
goto Direccion
endm
jc MACRO Direccion
btfsc STATUS,C
goto Direccion
endm
jnc MACRO Direccion
btfss STATUS,C
goto Direccion
endm
jbs MACRO Reg, Bit, Adr ;saltar si bit esta seteado
btfsc Reg, Bit
goto Adr
endm
jbc MACRO Reg, Bit, Adr ;saltar si bit esta aclarado
btfss Reg, Bit
goto Adr
endm
sbs macro Reg, Bit ;obviar si bit esta seteado
btfss Reg, Bit
endm
sbc macro Reg, Bit ;obviar si bit esta aclarado
btfsc Reg, Bit
endm
compara macro reg1, constante
movlw constante
xorwf reg1,W
endm
