/*SPI routines*/
#ifndef SPI_H
#define SPI_H
/* Scheduler include files. */
#include "FreeRTOS.h"
#include "task.h"
#include "semphr.h"
/*Header File*/
#include "..\common\errcode.h"
#include "..\common\osdata.h"
/*Device specific headers*/
#include <AT91SAM7S64.H>
#include <lib_AT91SAM7S64.h>
/*Configurations*/
#define SPI_SENDRCV_DIS_W_SETTING 0 //The SPI PDC is temporarily disabled while configuring to send / receive
/*Definitions*/
#define SPI_MIN_DIVIDER 2
/*IO Ports definition*/
/*CS0 only in PA11*/
#define SPI_IO_CS0A (unsigned int) AT91C_PA11_NPCS0
#define SPI_IO_CS0B 0
/*CS1 in PA31 or in PA9*/
#if SELECT_SPI_IO_CS1 == PA31
#define SPI_IO_CS1A (unsigned int) AT91C_PA31_NPCS1
#define SPI_IO_CS1B 0
#else
#define SPI_IO_CS1A 0
#define SPI_IO_CS1B (unsigned int) AT91C_PA9_NPCS1
#endif
/*CS2 in PA30 or in PA10*/
#if SELECT_SPI_IO_CS2 == PA30
#define SPI_IO_CS2A 0
#define SPI_IO_CS2B (unsigned int) AT91C_PA30_NPCS2
#else
#define SPI_IO_CS2B (unsigned int) AT91C_PA10_NPCS2
#endif
/*CS3 in PA3, PA5 or PA22*/
#define SPI_IO_CS3A 0
#define SPI_IO_CS3B (unsigned int) AT91C_PA3_NPCS3
#elif SELECT_SPI_IO_CS2 == PA5
#define SPI_IO_CS3B (unsigned int) AT91C_PA5_NPCS3
#else
#define SPI_IO_CS3B (unsigned int) AT91C_PA22_NPCS3
#endif
/*enumerations*/
//Error codes for SPI initialization
typedef enum
spiInitSuccess = 0,
spiInitMaxCs
} eSpiInitError;
typedef enum
ChipSelect0 = 0,
ChipSelect1 = 1,
ChipSelect2 = 2,
ChipSelect3 = 3,
ChipSelectMax
} eCSDevice;
/*Types Definition, unions*/
#pragma anon_unions
typedef struct
eCSDevice device;
struct {unsigned portCHAR holdCS:1, :7; };
unsigned portCHAR clockDivider;
unsigned portSHORT sizeR;
unsigned portSHORT sizeW;
unsigned portCHAR *dataR;
const unsigned portCHAR *dataW;
portTickType xBlockTime;
} tSpiRWdata, *pSpiRWdata;
typedef struct
struct {unsigned portCHAR dev_1_Enabled:1, dev_2_Enabled:1, dev_3_Enabled:1, dev_4_Enabled:1, :4; };
tOSData mutex, event;
} tSpiPort;
/*Constants*/
/*Variable Definition*/
extern tSpiPort spiPort;
/*Functionality enabling*/
/*Public Functions and procedures Declaration*/
eSpiInitError eSpiInit(eCSDevice device);
unsigned portCHAR cSpiReadWrite(pSpiRWdata pData);
void vSpiClose(eCSDevice device);
void vSpiISR(void);
extern void vSpiISREntry( void ); //Interrupt entry point written in the assembler file serialISR.s
/*Macro definitions*/
#endif //SPI_H
