#include <18F2525.h>
#device adc=10
#FUSES NOWDT //No Watch Dog Timer
#FUSES WDT128 //Watch Dog Timer uses 1:128 Postscale
#FUSES INTRC //Internal RC Osc
#FUSES FCMEN //Fail-safe clock monitor enabled
#FUSES NOIESO //Internal External Switch Over mode disabled
#FUSES NOPUT //No Power Up Timer
#FUSES NOBROWNOUT //No brownout reset
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC //Timer1 configured for higher power operation
#FUSES MCLR //Master Clear pin enabled
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOXINST //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NODEBUG //No Debug mode for ICD
#FUSES NOPROTECT //Code not protected from reading
#FUSES NOCPB //No Boot Block code protection
#FUSES NOCPD //No EE protection
#FUSES NOWRT //Program memory not write protected
#FUSES NOWRTC //configuration not registers write protected
#FUSES NOWRTB //Boot block not write protected
#FUSES NOWRTD //Data EEPROM not write protected
#FUSES NOEBTR //Memory not protected from table reads
#FUSES NOEBTRB //Boot block not protected from table reads
#use delay(int=4000000)
#define ENABLE_PIN B0
#define RS_PIN B1
#define RW_PIN B2
#define Data4 B4
#define Data5 B5
#define Data6 B6
#define Data7 B7
#define LCD_TYPE 2
#include <lcd.c>
int seguir;
void main()
setup_adc_ports(AN0_TO_AN1|VSS_VDD);
setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_2);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_3(T3_DISABLED|T3_DIV_BY_1);
setup_vref(FALSE);
setup_oscillator(OSC_4MHZ|OSC_INTRC|OSC_PLL_OFF);
set_tris_a(0x03);
lcd_init();
seguir=0;
do
output_low(pin_a2);
delay_ms(300);
output_high(pin_a2);
delay_ms(300);
while (seguir==0);
