Hola a todos,
En el siguiente código que encontré al compilar en mikroC me da errores y no consigo encontrarlos:
struct menuStruct;
void mainScreen();
void item2Handle();
//Font for the arrows
const unsigned short Arrows5x6[] = {
0x30, 0x3C, 0x3F, 0x3C, 0x30,
0x03, 0x0F, 0x3F, 0x0F, 0x03
//Menu item structure
typedef struct menuItem
char *itemName; //Name of this item
void (*handler)(void); //Pointer to function, null if not used
struct menuStruct *subMenu; //Pointer to sub menu, null if not used
} menuItem;
//Menu structure
typedef struct menuStruct
char *menuName; //Name of menu
unsigned short numberItems; //Number of menu items
menuItem *items; //Pointer to array of items
} menuStruct;
//Demo menu. Menus are declared in reverse order,
menuItem subItem1ItemList[] = {{"Sub Sub Item 1", 0, 0}, {"Sub Sub Item 2", 0, 0}};
menuStruct subItem1Menu = {"Sub Item 1 Sub Menu", 2, &subItem1ItemList};
menuItem item1ItemList[] = {{"Sub sub menu 1", 0, &subItem1Menu}, {"Sub Item 2", 0, 0}};
menuStruct item1Menu = {"Item 1 Sub Menu", 2, &item1ItemList};
menuItem mainMenuItemList[] = {{"Sub Menu 1", 0, &item1Menu},{"Demo function", &item2Handle, 0},{"Sub sub menu 1", 0, &subItem1Menu},{"Item 4", 0, 0},{"Item 5", 0, 0},
{"Item 6", 0, 0},{"Item 7", 0, 0},{"Item 8", 0, 0},{"Item 9", 0, 0},{"Item 10", 0, 0}};
menuStruct mainMenu = {"Main Menu", 10, &mainMenuItemList};
//Demo item handle function
void item2Handle()
GLCD_Fill(0x00);
GLCD_Write_Text("Press RA4", 0, 0, 1);
while(!Button(&PORTA, 4, 5, 1))
return;
//Draws the actual menu
void drawMenu(menuStruct *menuToShow, short selectedIndex)
unsigned short i;
GLCD_Fill(0x00);
GLCD_Set_Font(FontSystem5x8,5,8,32);
GLCD_Write_Text(menuToShow->menuName, 0, 0, 1);
for(i=0;i < (menuToShow->numberItems > 6 ? 6 : menuToShow->numberItems) ;i++)
if (i > 5 + (selectedIndex > 5 ? selectedIndex - 5 : 0))
break;
else if (selectedIndex < 6)
GLCD_Write_Text(menuToShow->items[i]->itemName, 5, i+1, (selectedIndex == i) ? 0 : 1);
else
GLCD_Write_Text(menuToShow->items[i+(selectedIndex-5)]->itemName, 5, i+1, (selectedIndex == i+(selectedIndex-5)) ? 0 : 1);
Glcd_H_Line(0,127,7,1);
Glcd_H_Line(0,127,55,1);
GLCD_Set_Font(Arrows5x6,5,6,30);
GLCD_Write_Char(30, 5, 7, 1);
GLCD_Write_Char(31, 25, 7, 1);
GLCD_Write_Text("Select", 45, 7, 1);
GLCD_Write_Text("Back", 101, 7, 1);
return;
//Main menu function
void openMenu(menuStruct *menuToShow)
short selectedIndex = 0; //Current selected item
delay_ms(50);
drawMenu(menuToShow, selectedIndex);
do {
if (Button(&PORTA, 0, 5, 1))
selectedIndex--;
if (selectedIndex < 0)
selectedIndex = menuToShow->numberItems - 1;
else if (Button(&PORTA, 1, 5, 1))
selectedIndex++;
if (selectedIndex > (menuToShow->numberItems) - 1)
selectedIndex = 0;
else if (Button(&PORTA, 2, 5, 1))
if (menuToShow->items[selectedIndex]->handler != 0)
menuToShow->items[selectedIndex]->handler();
else if (menuToShow->items[selectedIndex]->subMenu != 0)
openMenu(menuToShow->items[selectedIndex]->subMenu);
else if (Button(&PORTA, 3, 5, 1))
return;
delay_ms(30);
} while (1);
return;
void mainScreen()
GLCD_Fill(0x00);
GLCD_Write_Text("Menu", 0, 7, 1);
return;
void main()
ADPCFG = 0xFFFF;
Glcd_Init_LV_24_33();
mainScreen();
//--- main loop
do
if (Button(&PORTA, 0, 1, 1))
openMenu(&mainMenu);
mainScreen();
Delay_ms(50);
} while (1);
El error me lo da en las siguientes lineas:
menuItem mainMenuItemList[] = {{"Sub Menu 1", 0, &item1Menu},{"Demo function", &item2Handle, 0},{"Sub sub menu 1", 0, &subItem1Menu},{"Item 4", 0, 0},{"Item 5", 0, 0},{"Item 6", 0, 0},{"Item 7", 0, 0},{"Item 8", 0, 0},{"Item 9", 0, 0},{"Item 10", 0, 0}};
Algun idea?.
Jose
