jaja nadie me dijo que tambien existia el make32...
Extracto de la ayuda de CCS
Syntax:
i32 = MAKE32(var1, var2, var3, var4)
Parameters:
var1-4 are a 8 or 16 bit integers. var2-4 are optional.
Returns:
A 32 bit integer
Function:
Makes a 32 bit number out of any combination of 8 and 16 bit numbers. Note that the number of parameters may be 1 to 4. The msb is first. If the total bits provided is less than 32 then zeros are added at the msb.
Availability:
All devices
Requires:
Nothing
Examples:
int32 x;
int y;
long z;
x = make32(1,2,3,4); // x is 0x01020304
y=0x12;
z=0x4321;
x = make32(y,z); // x is 0x00124321
x = make32(y,y,z); // x is 0x12124321
