Autor Tema: Problemas Pickit2 ... no lo puedo ni instalar .......  (Leído 6203 veces)
Desconectado mbtrx
« en: 01 de Marzo de 2009, 21:31:37 »
Hola gente ...... si como dice el título me compré el Pickit para comenzar en esto de los Pics  y resulata que hoy con todas las ganas lo quiero instalar y me aparece un cartel de error y me dice:
See the setup log file located at 'C:\WINDOWS\Temp\VSD573.tmp\install.log' for more information,  y voy a ver y me dice todo esto:
The following properties have been set:
Property: [AdminUser] = true {boolean}
Property: [ProcessorArchitecture] = Intel {string}
Property: [VersionNT] = 5.1.2 {version}
Running checks for package '.NET Framework 2.0', phase BuildList
Running external check with command line "C:\WINDOWS\Temp\VSD4C9.tmp\dotnetfx\dotnetchk.exe"
Process exited with code 1
Setting value '1 {int}' for property 'DotNetInstalled'
Reading value 'Version' of registry key 'HKLM\Software\Microsoft\Internet Explorer'
Read string value '6.0.2900.2180'
Setting value '6.0.2900.2180 {string}' for property 'IEVersion'
The following properties have been set for package '.NET Framework 2.0':
Property: [DotNetInstalled] = 1 {int}
Property: [IEVersion] = 6.0.2900.2180 {string}
Running checks for command 'dotnetfx\instmsia.exe'
Result of running operator 'ValueExists' on property 'VersionNT': true
Result of checks for command 'dotnetfx\instmsia.exe' is 'Bypass'
Running checks for command 'dotnetfx\WindowsInstaller-KB893803-v2-x86.exe'
Result of running operator 'ValueExists' on property 'Version9x': false
Result of running operator 'VersionLessThan' on property 'VersionNT' and value '5.0.3': false
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsi' and value '3.0': true
Result of checks for command 'dotnetfx\WindowsInstaller-KB893803-v2-x86.exe' is 'Bypass'
Running checks for command 'dotnetfx\dotnetfx.exe'
Result of running operator 'ValueNotEqualTo' on property 'DotNetInstalled' and value '0': true
Result of checks for command 'dotnetfx\dotnetfx.exe' is 'Bypass'
'.NET Framework 2.0' RunCheck result: No Install Needed
Launching Application.
Error: Unable to locate application file 'PICkit2Setup.msi'.
Aclaro que mi computadora no es INTEL (por las dudas) tiene algo que ver que no sea INTEL ¿? . Como puedo solucionar esto ?
Desde ya muchas gracias
Desconectado mbtrx
Re: Problemas Pickit2 ... no lo puedo ni instalar .......
« Respuesta #1 en: 02 de Marzo de 2009, 01:44:40 »
Bueno......después de la desesperación de no poder hacer nada logré instalar el programita  :-/ . La verdad no sé porque no funcionaba el Setup que se abría automaticamente ........
Si quiere algún mod , puede cerrar este post.
Desconectado Dustra
« Respuesta #2 en: 03 de Octubre de 2010, 00:26:10 »
Como hicist para resolver este problema??
Desconectado 8wck9
« Respuesta #3 en: 21 de Junio de 2013, 23:45:01 »
Hola a todos creo que Pic Kit tiene problemas de funcionamiento en computadoras portatiles puesto que tambien lo acabo de instalarlo en mi hp "compaq nc6400" con xp sp3 y al ajecutarlo me dice:
"PICkit2 ha detectado un problema y debe cerrarse. Sentimos los
incovenientes ocasionados"
Cabe mencionar que en mi computadora (XP SP3) de escritorio me funciono sin problemas
:( saludos
« Última modificación: 21 de Junio de 2013, 23:47:34 por 8wck9 »
Desconectado Renatox_
    • máquinas cnc
« Respuesta #4 en: 19 de Septiembre de 2013, 20:52:45 »
Hola, tienes que instalar el mplabc30-v3_31-windows-installer y el Framework 2.0 son requisitos para abrir el pickit2.
control de movimiento
