Autor Tema: DS1305 RTC con PIC18f4550 usando SPI por hardware  (Leído 5003 veces)
Desconectado pibe
« en: 11 de Febrero de 2009, 13:39:07 »
Aqui os dejo OTRO ejemplo de usar el DS1305 rtc con un 18f4550 , esta vez nada de simulación de módulo SPI por software. Este va con su módulo MSSP por hardware y funciona 10 puntos. Probado.
;Short example assembler code
;Interfacing a DS1305 with a pic16f4550 via SPI hardware master mode
      LIST P=18F4550
      #include <P18F4550.INC>
      CONFIG FOSC = HS       ;Osc por XTAL 20mhz
      CONFIG DEBUG = OFF
      CONFIG PWRT = OFF
      CONFIG BOR  = OFF
      CONFIG WDT = OFF
      CONFIG MCLRE = ON
      CONFIG PBADEN = OFF
      CONFIG LVP = OFF
      CONFIG CP0 = OFF
      CONFIG CP1 = OFF
      CONFIG CP2 = OFF
      CONFIG CP3 = OFF
      CONFIG CPB = OFF
      CONFIG CPD = OFF
#define     CSRTC      LATA,2   ; OUT  RA2 as CE
#define    SDI         LATB,0   ; IN  to SDO of Ds1305
#define    SCK        LATB,1   ; OUT  to SCLK ds1305
#define     SDO         LATC,7   ; OUT to SDI of DS1305
      cblock 0x00
SEC
MIN
HOUR
DAY
DOW
MON
YRS
outbyte
rxdata
      endc
CONTROL      equ 0x8f ;  (INT disabled, OSC on, WP disabled)
WRITESEC   equ 0x80
;ACTUALICE THESE WITH ACTUAL TIME BEFORE BURNING PIC !!
ACTUALYRS       equ    09h  ;years
ACTUALMON       equ    02h  ;month
ACTUALDAY       equ  10h  ;day
ACTUALDOW      equ  03h  ;day of the week
ACTUALHOUR      equ  15h  ;hours
ACTUALMIN       equ    34h  ;minutes
ACTUALSEC       equ  00h  ;seconds
      ORG 00h
      goto Ini
      Ini
      CLRF BSR
      CLRF LATA
      CLRF LATB
      CLRF LATC
      CLRF LATD
      CLRF LATE
      MOVLW  b'00001111' ;
      MOVWF ADCON1      ;
      MOVLW b'11111011' ; TRISA
      MOVWF TRISA      ; RA2 output
      MOVLW b'11111101' ;
      movwf   TRISB     ; PortB
      MOVLW b'00110111' ;
      movwf   TRISC     ; PortC
      movlw  b'00000000'
      movwf   TRISD     ; PortD
      movlw  0x00
      movwf   TRISE     ; Puerto E
      movlw 0x07
      movwf CMCON      ;
      movlw 0
      movwf    INTCON   ; disables all interrupts
      movwf SPPCON
      movwf    SSPCON1  ; clear SSP control register
      movwf   PIE1      ; disable peripheral interrupts
      movwf    SSPSTAT  ; clear SSP status register
      movwf    SPPCFG
      movwf UCON
      movwf ADCON0
      movlw 0x31        ; SPI master, clk/16, ckp=1
      movwf SSPCON1     ; SSPEN enabled
      movlw   0x80                    ; set up spi port, SPI master,
      movwf   SSPSTAT                 ; cke = 0 (mode 1,1)
      bcf  CSRTC
Main
;Write burst of data on the DS1305
      call RTC_brst_wr
;Read burst of data from DS1305
;Data are stored on YRS,MON,DAY, etc variables
stop      call RTC_brst_rd
    ;Example showing YEARS on PORTD
      movf SEC,w
      movwf LATD
      goto stop
;Burst write
RTC_brst_wr
      bsf CSRTC ;
      movlw CONTROL ;
      movwf outbyte
      call output
      movlw 0 ;
      movwf outbyte
      call output
      bcf CSRTC ;
      nop
      nop
        bSf     CSRTC                    ;  chip select active
        movlw  WRITESEC                  ; send seconds register write address
      movwf   outbyte
        call    output                  ; call the SPI output routine
      movlw ACTUALSEC
      movwf   outbyte                 ;
      movlw ACTUALMIN
      movwf   outbyte                 ;
      movlw ACTUALHOUR
      movwf   outbyte                 ;
      movlw ACTUALDOW
      movwf   outbyte                 ;
      movlw ACTUALDAY
      movwf   outbyte                 ;
      movlw ACTUALMON
      movwf   outbyte                 ;
      movlw ACTUALYRS
      movwf   outbyte                 ;
      bcf     CSRTC                   ; clear the chip select
      return
;Burst read
RTC_brst_rd
        bsf     CSRTC                   ; clear the chip select line
        movlw 0h                   ; seconds register read address
      movwf   outbyte                 ; store in RAM location outbyte
      movff rxdata, SEC ; save it
      movff rxdata, MIN
      movff rxdata, HOUR
      movff rxdata, DOW
      movff rxdata, DAY
      movff rxdata, MON
      movff rxdata, YRS
      bcf CSRTC                   ; de-assert CE
      return
;*******************SPI output subroutine***********************
output
        movf    outbyte,W               ; move outbyte into w
        movwf   SSPBUF                  ; place data in send buffer
loop1
        btfss   SSPSTAT,BF              ; has data been received?
        goto    loop1                   ; loop if not received yet
        movf    SSPBUF,W                ; empty the receive buffer
        movwf   rxdata                  ; put received byte into rxdata
        retlw   0                       ; return from subroutine
      end
Desconectado groundman
    • www.ingeniopic.com
Re: DS1305 RTC con PIC18f4550 usando SPI por hardware
« Respuesta #1 en: 09 de Agosto de 2010, 11:15:11 »
hola pibe.he querido usar tu codigo.
pero he visto un par de errores.
 movlw 0
 y
bcf  CSRTC
son un par de lineas que no estan acabadas del todo.
Desconectado jim_17
    • Blog personal
« Respuesta #2 en: 09 de Agosto de 2010, 16:15:43 »
Groundman fijate que CSRTC esta definido arriba como LATA,2 (#DEFINE CSRTC LATA,2) entonces si que esta bien empleado el 'bcf CSRTC'.
Share the world !
Blog's
http://www.area0x33.com
« Respuesta #3 en: 12 de Agosto de 2010, 10:04:19 »
 :tongue: no me habia dado cuenta.
ademas parece que movlw 0  es igual que un movlw 0x00.se ve que el ensamblador coje los valores como exagesimales por defecto.
aunque no se porque las lineas de abajo ubican los registros tan desordenados.
supongo que ha querido dar unos valores a los registros.y en su lugar lo que ha pasado es que los valores han cogido posiciones de la memoria.
