les posteo el driver del ds1307
/// DS1307.C ///
/// Driver for Real Time Clock ///
/// modified by Redpic 08/2006 ///
http://picmania.garcia-cuervo.com ///
/// void ds1307_init(val) ///
/// - Enable oscillator without clearing the seconds register ///
/// used when PIC loses power and DS1307 run from 3V BAT ///
/// - Config Control Register with next parameters: ///
/// DS1307_ALL_DISABLED All disabled ///
/// DS1307_OUT_ON_DISABLED_HIHG Out to Hight on Disable Out ///
/// DS1307_OUT_ENABLED Out Enabled ///
/// DS1307_OUT_1_HZ Freq. Out to 1 Hz ///
/// DS1307_OUT_4_KHZ Freq. Out to 4.096 Khz ///
/// DS1307_OUT_8_KHZ Freq. Out to 8.192 Khz ///
/// DS1307_OUT_32_KHZ Freq. Out to 32.768 Khz ///
/// Example init: ///
/// ds1307_init(DS1307_ALL_DISABLED); ///
/// ds1307_init(DS1307_OUT_ENABLED | DS1307_OUT_1_HZ); ///
/// void ds1307_set_date_time(day,mth,year,dow,hour,min,sec) - Set the date/time ///
/// void ds1307_get_date(day,mth,year,dow) - Get the date ///
/// void ds1307_get_time(hr,min,sec) - Get the time ///
/// char ds1307_read_nvram_byte(char addr) - Read byte in address ///
/// void ds1307_write_nvram_byte(char addr, char value) - Write byte in address ///
/// void ds1307_get_day_of_week(char* ptr) - Get string Day Of Week///
/// If defined USE_INTERRUPTS all functions disable Global Interrupts on starts and ///
/// enable Global on ends else usar can do it hiself ///
#ifndef RTC_SDA
#define RTC_SDA PIN_B0
#define RTC_SCL PIN_B1
#endif
#use i2c(master, sda=RTC_SDA, scl=RTC_SCL)
#define DS1307_ALL_DISABLED 0b00000000 // All disabled
#define DS1307_OUT_ON_DISABLED_HIHG 0b10000000 // Out to Hight on Disable Out
#define DS1307_OUT_ENABLED 0b00010000 // Out Enabled
#define DS1307_OUT_1_HZ 0b00000000 // Freq. Out to 1 Hz
#define DS1307_OUT_4_KHZ 0b00000001 // Freq. Out to 4.096 Khz
#define DS1307_OUT_8_KHZ 0b00000010 // Freq. Out to 8.192 Khz
#define DS1307_OUT_32_KHZ 0b00000011 // Freq. Out to 32.768 Khz
#define Start_user_address_nvram 0x08
#define End_user_address_nvram 0x3f
char days_of_week[7][11]={"Lunes\0","Martes\0","Miércoles\0","Jueves\0","Viernes\0","Sábado\0","Domingo\0"};
byte ds1307_bin2bcd(byte binary_value);
byte ds1307_bcd2bin(byte bcd_value);
void ds1307_init(int val){
byte seconds = 0;
#ifndef USE_INTERRUPTS
disable_interrupts(global);
#endif
i2c_start();
i2c_write(0xD0);
i2c_write(0x00);
i2c_start();
i2c_write(0xD1);
seconds = ds1307_bcd2bin(i2c_read(0));
i2c_stop();
seconds &= 0x7F;
delay_us(3);
i2c_start();
i2c_write(0xD0);
i2c_write(0x00);
i2c_write(ds1307_bin2bcd(seconds));
i2c_start();
i2c_write(0xD0);
i2c_write(0x07);
i2c_write(val);
i2c_stop();
enable_interrupts(global);
#endif
void ds1307_set_date_time(byte day, byte mth, byte year, byte dow, byte hr, byte min, byte sec){
#endif
sec &= 0x7F;
hr &= 0x3F;
i2c_start();
i2c_write(0xD0);
i2c_write(0x00);
i2c_write(ds1307_bin2bcd(sec));
i2c_write(ds1307_bin2bcd(min));
i2c_write(ds1307_bin2bcd(hr));
i2c_write(ds1307_bin2bcd(dow));
i2c_write(ds1307_bin2bcd(day));
i2c_write(ds1307_bin2bcd(mth));
i2c_write(ds1307_bin2bcd(year));
i2c_stop();
#endif
void ds1307_get_date(byte &day, byte &mth, byte &year, byte &dow){
#endif
i2c_start();
i2c_write(0xD0);
i2c_write(0x03);
i2c_start();
i2c_write(0xD1);
dow = ds1307_bcd2bin(i2c_read() & 0x7f);
day = ds1307_bcd2bin(i2c_read() & 0x3f);
mth = ds1307_bcd2bin(i2c_read() & 0x1f);
year = ds1307_bcd2bin(i2c_read(0));
i2c_stop();
#endif
void ds1307_get_time(byte &hr, byte &min, byte &sec){
#endif
i2c_start();
i2c_write(0xD0);
i2c_write(0x00);
i2c_start();
i2c_write(0xD1);
sec = ds1307_bcd2bin(i2c_read() & 0x7f);
min = ds1307_bcd2bin(i2c_read() & 0x7f);
hr = ds1307_bcd2bin(i2c_read(0) & 0x3f);
i2c_stop();
#endif
char ds1307_read_nvram_byte(char addr){
char retval;
#endif
i2c_start();
i2c_write(0xD0);
i2c_write(addr);
i2c_start();
i2c_write(0xD1);
retval = i2c_read(0);
i2c_stop();
return(retval);
#endif
void ds1307_write_nvram_byte(char addr, char value){
#endif
i2c_start();
i2c_write(0xD0);
i2c_write(addr);
i2c_write(value);
i2c_stop();
#endif
void ds1307_get_day_of_week(char* ptr){
byte lday;
byte lmonth;
byte lyr;
byte ldow;
ds1307_get_date(lday,lmonth,lyr,ldow);
sprintf(ptr,"%s",days_of_week[ldow]);
byte ds1307_bin2bcd(byte binary_value){
byte temp;
byte retval;
temp = binary_value;
retval = 0;
while(1){
if(temp >= 10){
temp -= 10;
retval += 0x10;
}else{
retval += temp;
break;
return(retval);
byte ds1307_bcd2bin(byte bcd_value){
byte temp;
temp = bcd_value;
temp >>= 1;
temp &= 0x78;
return(temp + (temp >> 2) + (bcd_value & 0x0f));
AGRADECERIA ALGUN OPINION AL RESPECTO
GRACIAS
