Buenas gente.
Arme la controladora y 1 driver para probar los motores de 5 Fases.
Lo que me esta matando es la configuracion del Mach.
De la pagina de donde saque la placa el flaco puso esto como configuracion del Kcam
Controller bits setup (LPT I/O port bits) with selected bit function (based on KCAM drawing example) :
1. X-Drive Step Pulse = pin-2 (DP-0), active low
2. X-Drive Direction = pin-3 (DP-1), active low
3. X-Drive Enable = pin-4 (DP-2), active low
4. Y-Drive Step Pulse = pin-5 (DP-3), active low
5. Y-Drive Direction = pin-6 (DP-4), active low
6. Y-Drive Enable = pin-7 (DP-5), active low
7. Z-Drive Step Pulse = pin-8 (DP-6), active low
8. Z-Drive Direction = pin-9 (DP-7), active low
9. Z-Drive Enable = pin-16 (PC-2), active low (I used this since it is not inv.)
10. X-Drive Limit Switch = pin-10 (PS-6), active high (I used this since it is not inv. and I used Normally Closed contact LS (series connection), if you used a Normally Open LS (parallel connection), set this to active low)
11. Y-Drive Limit Switch = pin-12 (PS-5), active high (the same as above)
12. Z-Drive Limit Switch = pin-13 (PS-4), active high (the same as above)
13. Spindle ON Control Relay = pin-1 (PC-0), active low (This is an inv. output)
14. Aux. Control Relay 1 (for coolant or vacuum) = pin-14 (PC-1), active low (This is an inv. output, I plan to run a vacuum next)
15. Aux. Control Relay 2 (for coolant) = pin-17 (PC-3), active low (Also an inv. output)
16. Spare Input Control 1 = pin-15 (PS-3), non inv. input
17. Spare Input Control 2 = pin-11 (PS-7), inv. input
http://www.geocities.com/dsa_projects/handicrafts/cnc/cnc_table.html?200814Alguien me podria dar una mano para trasladar esto al Mach?
Lo raro es que le meto numeros por todos lados al mach y nada y con el programita Motor de R-Luis anda, osea la interface y el driver andan bien.
Este es el programita motor....
Bueno gente no los molesto mas, si alguien tiene un salvavidas por ahi....
