* 7-pins LCD interface code
* Drives an LCD in 4-bit mode, using the three control
* signals. This has the advantage that the code is
* independent of the LCD, since there are no
* timing loops in the code. The code is blocking
* and used the LCD busy signal to determine if the
* display is ready to accept new data.
* (c) Lieven Hollevoet
* most recent version on http://boostc.lika.be
#include "lcd.h"
// Local variable
bit lcd_found = 0;
// Drive a certain nibble on the LCD data pins, the nibble
// is taken from the lsb's of the input char
void lcd_clock_nibble(char nibble){
// Since there seems to be no way to extract a bit from a byte in BoostC -> do it in asm.
// It is replicated 4 times here, since a function cannot return a bit eiter.
// Set the d4 depending on the state of nibble bit 0
asm {
btfss _nibble, 0
goto clear_lcd4
bsf _lcd_d4, F
goto done_lcd4
clear_lcd4:
bcf _lcd_d4, F
done_lcd4:
// Set the d5 depending on the state of nibble bit 1
asm {
btfss _nibble, 1
goto clear_lcd5
bsf _lcd_d5, F
goto done_lcd5
clear_lcd5:
bcf _lcd_d5, F
done_lcd5:
// Set the d6 depending on the state of nibble bit 2
asm {
btfss _nibble, 2
goto clear_lcd6
bsf _lcd_d6, F
goto done_lcd6
clear_lcd6:
bcf _lcd_d6, F
done_lcd6:
// Set the d7 depending on the state of nibble bit 3
asm {
btfss _nibble, 3
goto clear_lcd7
bsf _lcd_d7, F
goto done_lcd7
clear_lcd7:
bcf _lcd_d7, F
done_lcd7:
lcd_toggle_e;
return;
// Read the busy flag of the LCD and wait to return until
// the LCD is ready.
// Skipped when running in debug mode.
void lcd_wait_busy(){
// Skip this function if we are running in debug mode.
#ifdef DEBUG
return;
#endif
// If we have not detected an LCD in a previous call to this function,
// then we just skip it this time, since else the program will hang later
// on in this function.
if (!lcd_found){
return;
// Save the current LCD mode
bit mode = lcd_rs;
// The data lines are inputs
lcd_tris_d4 = 1;
lcd_tris_d5 = 1;
lcd_tris_d6 = 1;
lcd_tris_d7 = 1;
// Enter command mode
lcd_cmd_mode;
lcd_rw = 1;
// Put lcd_e high
lcd_e_hi;
char counter = 0;
// Wait for completion of the operation, with a timeout of ~.5 seconds
// LCD d7 is high if the operation is complete.
while (lcd_d7 && counter < 0xFF){
lcd_e_lo;
lcd_e_hi;
lcd_e_lo;
lcd_e_hi;
delay_ms(2);
counter++;
// Check if the previous loop timed out
if (counter == 0xFF) {
// If it was a timeout -> disable the flag.
lcd_found = 0;
// And put the lcd_lo again
lcd_e_lo;
// Restore the TRIS
lcd_tris_d4 = 0;
lcd_tris_d5 = 0;
lcd_tris_d6 = 0;
lcd_tris_d7 = 0;
// Restore LCD RS mode.
lcd_rs = mode;
lcd_rw = 0;
return;
// Send a byte to the LCD. Don't forget to set the mode
// (data or cmd) before calling this function.
void lcd_send_byte(char data){
char temp = data >> 4;
lcd_rw = 0; // Write mode
// Clock the high nibble
lcd_clock_nibble(temp);
// Clock the low nibble
lcd_clock_nibble(data);
// Wait until the LCD is finished
lcd_wait_busy();
// Initialisation sequence of the LCD
void lcd_init(){
// Wait for internal reset
delay_ms(15);
// Set all pins as output
lcd_tris_rs = 0;
lcd_tris_rw = 0;
lcd_tris_e = 0;
lcd_tris_d4 = 0;
lcd_tris_d5 = 0;
lcd_tris_d6 = 0;
lcd_tris_d7 = 0;
clear_bit(trisa, 1);
clear_bit(porta, 1);
// Clear the control bits
lcd_rw = 0;
lcd_cmd_mode;
// Init sequence (see datasheet)
/// attention (clock 0x03 twice)
lcd_clock_nibble(0x03);
delay_ms(5);
lcd_toggle_e;
delay_10us(15);
/// 4bit mode (clock 0x03 and 0x02)
lcd_toggle_e;
delay_ms(5);
lcd_d4 = 0;
lcd_toggle_e;
delay_10us(15);
// Assume we have an LCD attached
lcd_found = 1;
/// We're in 4 bit mode now, program general settings
lcd_send_byte(FUNCTION_SET);
lcd_send_byte(DISP_OFF);
lcd_send_byte(DISP_ON);
lcd_send_byte(ENTRY_INC);
lcd_send_byte(DISP_CLR);
lcd_send_byte(LINE1);
// Init done, you can start writing characters now
lcd_data_mode;
return;
// Send a command to the LCD
void lcd_send_cmd(char command){
lcd_cmd_mode;
lcd_send_byte(command);
// Send a line to the LCD
void lcd_printf(const char* line){
char i = 0;
lcd_data_mode;
while(line[i] != 0)
lcd_send_byte(line[i++]);
// Print a character to the LCD
void lcd_printf(char value){
lcd_data_mode;
lcd_send_byte(value);
// Print a hex value to the LCD
void lcd_print_hex(char value){
lcd_data_mode;
char hexChar;
char i;
for(i = 0; i < 2; i++)
if(i == 0)
hexChar = value >> 4;
else
hexChar = value & 0x0F;
if(hexChar < 10)
hexChar = hexChar + '0';
else
hexChar = hexChar + ('A' - 10);
lcd_send_byte(hexChar);
// Print a 16-bit hex value to the LCD
void lcd_print_hex(short value){
char value1 = (char)((value >> 8) & 0x00FF);
lcd_print_hex(value1);
char value0 = (char)(value & 0x00FF);
lcd_print_hex(value0);
return;
