Autor Tema: Ultrasonic range finder Software  (Leído 2298 veces)
Desconectado luarken
« en: 16 de Mayo de 2008, 00:20:37 »
tengo una pregunta
porque cuando compilo este programa no me sali ningun error
pero cuando trato de cargarlo al pic me dice que el oscilador no esta bien configurado o que no esta definido algo asi
lo q se es que si fallo con este pic (pic12c508) no hay otra oportunidad.
es igual si uso un pic12f508 ????
;//   Ultrasonic rangefinder Software
;//   Written by Gerald Coe     -       May 2000
;//   Tidied up for publication - 12th July 2000
;//   Private and Educational use only is permitted
;//   Commercial use of this software is prohibited.
   processor   12c508
   __config   0feeh      ; Internal Osc, WDT Enabled, not code protected
   include   "p12c508.inc"
#define   RAMSTART 07h
   radix   dec
#define trig   GPIO,0      ; trigger input from host
#define   pulse   GPIO,1      ; timing pulse output to host
#define   echo   GPIO,2      ; echo signals from comparitor
#define  nc   GPIO,3      ; Unused - do not connect.
#define   tx2   GPIO,4      ; Tx phase 2
#define   tx1   GPIO,5      ; Tx phase 1
#define _C   STATUS,C
   org   RAMSTART
loop      res   1   ; loop counter
dlyctr      res   1   ; delay counter
tone_cnt   res   1   ; count echo cycles
period      res   1   ; received burst cycle period from tmr0
   org     0          ;start address 0
   movwf   OSCCAL      ; use microchip's calibration value
   movlw   89h
   option         ;assign 1:2 prescaler to watchdog
   movlw   0dh
   tris   GPIO      ;GPIO 1, 4 & 5 are outputs
   movwf   0
   bcf   pulse
; The main loop controls the range finder. In response to a low going trigger
; input, its calls "burst" to send out 8 cycles of 40khz. It then raises the
; pulse line so the host can begin timing.
; There is a choice of two tone detect routines, the simplest is currently set.
; It then clears the output pulse so the host can complete timing, and loops
; around to wait for the next cycle.
; If an echo is not detected then the watchdog timer will reset the PIC after
; about 30mS, and the pulse line will be cleared. Therefore a very long pulse
; should be interpreted as "nothing detected"
main:   clrwdt
   btfss   trig      ; wait for trigger signal from user to go high
   goto   main      ; from previous measurement.
m2:   clrwdt
   btfsc   trig      ; wait for trigger signal from user
   goto   m2
   call   burst      ; send the ultra-sonic burst
   bsf   pulse      ; start the output timing pulse
; OK, here's the cheap-n-easy way to detect the echo, just wait for a transition
; on the echo line. Though not really detecting a tone, it is very effective.
; The transducers provide the selectivity.
m1:   btfsc   echo
   goto   m1      ; wait for low
   bcf   pulse      ; end the output timing pulse
; And here is the "proper" tone detecter. It detects 3 cycles of 40khz to
; give a valid output. It works but is still experimental. It is not as effective
; as just detecting the first edge, particually in the first few cm.
;   call tone      ; validate 3 cycles of 40khz
;   bcf   pulse      ; end the output timing pulse
   goto   main
; The burst routine generates an acurately times 40khz burst of 8 cycles.
; Since a 4Mhz PIC (1uS instruction rate) cannot gerenate timings of less
; than 1uS, the high half cycle is 12uS and the low half cycle 13uS.
; That's good enough.
burst:   clrf   loop
   movlw   8      ; number of cycles in burst
   movwf   loop
burst1:   movlw   0x10      ; 1st half cycle
   movwf   GPIO
   movlw   3      ; (3 * 3inst * 1uS) -1uS = 8uS
   movwf   dlyctr      ; 8uS + (4*1uS) = 12uS
burst2:   decfsz   dlyctr,f
   goto   burst2
   movlw   0x20
   movwf   GPIO
   movlw   2      ; (2 * 3inst * 1uS) -1uS = 5uS
   movwf   dlyctr      ; 5uS + (8*1uS) = 13uS
burst3:   decfsz   dlyctr,f
   goto   burst3
   nop
   decfsz   loop,f
   goto   burst1
   movlw   0x00      ; set both drives low
   movwf   GPIO
   retlw   0
; The timing for this routine is critical. Our little PIC is only chugging
; along at 4Mhz, or 1uS per instruction. The longest path though this code
; is 19uS, out of the 25uS available - thats tight and why I only wait for a
; low on the echo line and not a high as well.
tone:   clrf   TMR0
t1:   btfsc   echo
   goto   t1      ; wait for low
   movfw   TMR0
   clrf   TMR0
   movwf   period      ; store timer0 value
   movlw   21      ; if(period>22 && period<30)
   subwf   period,w
   btfss   _C
   goto   t2
   movlw   30
   subwf   period,f
   btfsc   _C
   goto   t2
   decfsz   tone_cnt,f   ; 25uS period OK, so
   goto   t1      ; if not yet 3 of them, keep looking
   retlw   0      ; else - success - return
t2:   movlw   3      ; failed to detect 25uS period, so reset tone detect
   movwf   tone_cnt   ; to 3 and keep looking
   goto   t1
   end
Re: Ultrasonic range finder Software
« Respuesta #1 en: 16 de Mayo de 2008, 00:30:41 »
estoy utilizando el ic-progr 1.05 para programar y el programador q venden en steren el pic-500
que tengo que hacer para programarlo sin fallas??
Desconectado sandra
« Respuesta #2 en: 16 de Mayo de 2008, 13:24:46 »
Hola que mal que ayas comprado ese programador es una soberana porquería y charrísima  con unos 50 pesos te lo hubieras armado tu mismo.
Con respecto a tu pregunta  el  pic12c508 solo puedes gravarlo una ves el  pic12f508  puede ser gravado  algo así como mil veces si no me equivoco.
Ahora sin que te ofendas por lo que miro apenas empiezas en esto y  el programa que pones nada mas lo copiaste y  pegaste en el compilador pueden ser muchas cosas las que estén mal y no las vas a resolver sino entiendes que estas asiendo lo mas seguro es que sea el seteo de bit de configuración en el programa o tienes parámetros distintos el en ic program
El pesimista se queja del viento
El optimista espera que cambie
El realista ajusta las velas
« Respuesta #3 en: 16 de Mayo de 2008, 16:51:53 »
ah orale gracias
pss el programado me lo regalo una maestra!!!
y si apenas comiento es esto de los pic, ese es un programa que ya estaba hecho, es para hacer el sensor ultrasonico srf04
pero me sale eso del osilador interno.
« Respuesta #4 en: 16 de Mayo de 2008, 19:13:55 »
este error me sale
Desconectado poseidon20
« Respuesta #5 en: 17 de Mayo de 2008, 01:20:04 »
por lo que veo es problema del valor cargado para el oscilador interno, y creo que se encuentra en la ultima posicion de la memoria de programa, y ese valor viene de fabrica. Te recomeido que te leas el datasheet del correpondiente uC y te fijes ahi si poenen algun valor en particular y al momento que cargues tu porgrama al grabador adicionarle ese valor manualamente en la direccion que te espesifique el datasheet. :D pero como es del tipo "c" si ya grabastes ese pic ya no hay vuelta atras, por que no pruebas con uno de tipo "F" ya que  asi podras probar varios programas :D
