fijense que he adaptado un programa para recibir los datos de un control remoto y manejar un pic 16f84 y me funciona bien, ahora que lo quiero correr en un
pic 12f629 al compilarlo me muesta, error: unable to fit variable control,total total1 y total2 el programa es el siguiente:
include "bs2defs.bas"
@ DEVICE pic12F629, INTRC_OSC_NOCLKOUT
' System Clock Options (Internal)
@ DEVICE pic12F629, WDT_Off
' Watchdog Timer
@ DEVICE pic12F629, PWRT_ON
' Power-On Timer
@ DEVICE pic12F629, MCLR_OFF
' Master Clear Options (Internal)
@ DEVICE pic12F629, BOD_ON
' Brown-Out Detect
@ DEVICE pic12F629, CPD_OFF
' Data Memory Code Protect
@ DEVICE pic12F629, PROTECT_OFF
control var byte
almacena var word
entrada var gpio.0
salida1 var gpio.1
salida2 var gpio.2
total1 var byte
total2 var byte
total var byte
inicio:
pulsin entrada,1,almacena 'chequea entrada
serout 0,N2400,[almacena]
if almacena < 350 then inicio
for control = 1 to 7
pulsin entrada,1,b20
next control
pulsin entrada,1,b0
pulsin entrada,1,b1
pulsin entrada,1,b2
pulsin entrada,1,b3
for control = 1 TO 8
pulsin entrada,1,b21
next control
pulsin entrada,1,b4
pulsin entrada,1,b5
pulsin entrada,1,b6
pulsin entrada,1,b7
if b0 < 100 then
b0 = 0
else
b0 = 1
endif
if b1 < 100 then
b1 = 0
else
b1 = 1
endif
if b2 < 100 then
b2 = 0
else
b2 = 1
endif
if b3 < 100 then
b3 = 0
else
b3 = 1
endif
if b4 < 100 then
b4 = 0
else
b4 = 1
endif
if b5 < 100 then
b5 = 0
else
b5 = 1
endif
if b6 < 100 then
b6 = 0
else
b6 = 1
endif
if b7 < 100 then
b7 = 0
else
b7 = 1
endif
total1 =(128*b0)+(64*b1)+(32*b2)+(16*b3)+(8*b4)+(4*b5)
total2 = (2*b2)+(1*b1)
total = total1 + total2
if total = 195 then
toggle salida1
endif
if total = 192 then
toggle salida2
endif
pause 800
goto inicio
end
