Autor Tema: Error al simular 68hc11  (Leído 4565 veces)
Desconectado electrowolf
« en: 19 de Marzo de 2008, 16:26:03 »
 :) hola chicos
bien acudo a ustedes por que necesito simular un proyecto en el proteus con el 68hc11, ya tengo todo trazado, checado las conecciones y demas y siempre que lo quiero simular, me sale error falt de simulacion, y me sale un cuadro de texto con lo siguiente:
SIMULATION LOG
Design:   C:\Trabajos de Lobo\proyecto final.DSN
Doc. no.: <NONE>
Revision: <NONE>
Author:   <NONE>
Created:  04/06/07
Modified: 10/07/07
Compiling source files...
Build completed OK.
Compiling netlist...
Linking netlist...
Partition analysis...
Simulating partition 1 [9120B303]...
PROSPICE Release 6.6 SP0 (C) Labcenter Electronics 1993-2002.
SPICE Kernel Version 3f5. (C) Berkeley University ERL.
Reading netlist...
ERROR: [U1] mixed model HC11.DLL failed to authorize - Product Key not found.
Reading SPICE models...
Loading library 'ANALOGD.SML'
Loading library 'APEX.SML'
Loading library 'BURRBROWN.SML'
Loading library 'ELANTEC.SML'
Loading library 'FAIRCHLD.SML'
Loading library 'INTERSIL.SML'
Loading library 'LINTEC.SML'
Loading library 'NATOA.SML'
Loading library 'SUPERTEX.SML'
Loading library 'TECCOR.SML'
Loading library 'TEX101.SML'
Loading library 'TEX301.SML'
Loading library 'TEX3_1.SML'
Loading library 'TEX401.SML'
Loading library 'TEX5_1.SML'
Loading library 'VALVES.SML'
Loading library 'ZETEX.SML'
Building circuit...
Added GEARTH resistor for net #00000.
Added GEARTH resistor for net #00001.
Added GEARTH resistor for net #00002.
Added GEARTH resistor for net #00003.
Added GEARTH resistor for net #00004.
Added GEARTH resistor for net #00005.
Added GEARTH resistor for net #00006.
Added GEARTH resistor for net #00007.
Added GEARTH resistor for net #00008.
Added GEARTH resistor for net #00009.
Added GEARTH resistor for net #00010.
Added GEARTH resistor for net #00011.
Added GEARTH resistor for net #00012.
Added GEARTH resistor for net #00013.
Added GEARTH resistor for net #00014.
Added GEARTH resistor for net #00015.
Added GEARTH resistor for net #00016.
Added GEARTH resistor for net #00017.
Added GEARTH resistor for net #00018.
Added GEARTH resistor for net #00019.
Added GEARTH resistor for net #00020.
Added GEARTH resistor for net #00021.
Added GEARTH resistor for net #00022.
Added GEARTH resistor for net #00023.
Added GEARTH resistor for net #00024.
Added GEARTH resistor for net #00025.
Added GEARTH resistor for net #00026.
Added GEARTH resistor for net #00027.
Added GEARTH resistor for net #00028.
Added GEARTH resistor for net #00029.
Added GEARTH resistor for net #00030.
Added GEARTH resistor for net #00031.
Added GEARTH resistor for net #00032.
Added GEARTH resistor for net #00033.
Added GEARTH resistor for net #00034.
Added GEARTH resistor for net #00035.
Added GEARTH resistor for net #00036.
Added GEARTH resistor for net #00037.
Added GEARTH resistor for net #00038.
Added GEARTH resistor for net #00039.
Added GEARTH resistor for net #00040.
Added GEARTH resistor for net #00041.
Instantiating SPICE models...
Real Time Simulation failed to start
Simulation FAILED due to fatal simulator errors.
probablemente sea que la key que le puse no esta autorizada para simular el 68hc11 pero no estoy seguro...si fuera eso podria alguien darme informacion de donde podria obtener una y como agregarla para que pueda simular mi trabajo?
Desconectado lord_10
    • My Blog
Re: Error al simular 68hc11
« Respuesta #1 en: 19 de Marzo de 2008, 16:32:20 »
Si no mal recuerdo ene ste foro no se fomenta la pirateria unsando keys no validas, si gustas por que no mejor adjuntas los archivos y aqui lo probamos entre todos y/o varios que tenga(mos) uan version diferente a al tuya.
solo es cuestion que subas tus archivos y si gustas aqui los simulo.
..::  3D5F ™ ::..  AHC
"Tan sólo hace falta una pequeña idea, para hacer un gran sueño realidad."
« Respuesta #2 en: 19 de Marzo de 2008, 16:48:10 »
Aqui esta el archivo del circuito
    • My Blog
« Respuesta #3 en: 19 de Marzo de 2008, 21:25:39 »
bueno amigo aun falta un archivo en ese adjunto, pero aun asi lo je probado y no me hamarcado ese error que te salio, lo probe con la version 6.7 SP3 y posteriormente con una versión mas actual y nada, checalo bien de seguro es el programa que tiene limitaciones, perosi gustas adjunta el ,HEX y lo pruebo completo.
De hecho esto muestra el error,no cuentas con la DLL correcta para poder correr la simulacion del HC11
Desconectado jfh900
« Respuesta #4 en: 19 de Marzo de 2008, 21:37:06 »
Te está diciendo que no tienes licencia para simular ese microprocesador.
Desde España Jesús
« Respuesta #5 en: 20 de Marzo de 2008, 01:13:35 »
Ya me habia fijado que la llave que le puse probablemente no me permite simular el 68hc11....aun asi...queza ya sea tiempo de actualizar mi version...apenas tengo la 6.
bueno chicos...me conseguire una nueva version y luego les platico como me fue con la simulacion.
« Respuesta #6 en: 20 de Marzo de 2008, 13:50:53 »
Hola chicos
Bien...me consegui una nueva version del proteus...la 6.7 sp3, con la que se quito el problema que mencione anteriormente.....pero dicen que los problemas no vienen solos y ahora me salio este problema:
SIMULATION LOG
Doc. no.: <NONE>
Revision: <NONE>
Author:   <NONE>
Created:  04/06/07
Modified: 20/03/08
Processing simulacion del proyecto\Programa Proyecto reloaded.asm...
ASM11 simulacion del proyecto\Programa Proyecto reloaded.asm
Extracting debug data from simulacion del proyecto\Programa Proyecto reloaded.LST...
Processed 57 lines.
Build completed OK.
Linking netlist...
Simulating partition 1 [9A82F5A2]...
Animation started sucessfully...
PROSPICE Release 6.7 SP0 (C) Labcenter Electronics 1993-2005.
Reading netlist...
Building circuit...
[U1] Loaded persistent EEPROM data at B600-B7FF
ERROR: [U1] Must specify file extension for PROGRAM property.
Warning: [U1] No program code loaded.
[DSIM] BOOT Error.
Real Time Simulation FAILED.
ahora si no se ni que ondas con este problema....explico a continuacion como hice para ingresar el codigo del programa.
primero teclee el programa en un archivo TXT y lo guarde con la extension .asm
luego, me fui al menu "source" del proteus, seleccione "add/remove source files"
en la seccion "code generation tool" seleccione "asm11" y en la seccion source code file name, agrege el archivo asm que cree
despues regrese a "source" y seleccione "define code generation tools" y seleccione "asm11" y le di "ok"
despues regrese a "source" y seleccione "biuld all"
hasta aqui no me genero ningun problema, pero tampoco genero un archivo .s19 que se supone debo cargar, en vez de eso me creo uno con extension .sdi
probe con ambos, el .sdi y el .asm pero los dos me causan el error anterior que les platico.
imagino que el error esta en que no cargo un archivo .s19 no? pero el detalle si ese fuera el caso es que no se como generarlo desde proteus.
    • My Blog
« Respuesta #7 en: 20 de Marzo de 2008, 13:59:59 »
exacto ahi esta el error:
Que extension maneja el HC11? me imagino que es un .HEX  :mrgreen: Checa solamente esto y compila bien tu programa y cuando te genere al extension correcta solo cargalo al micro y listo. Prueba el pcbug11m y me dices que tal te va.
« Última modificación: 20 de Marzo de 2008, 14:12:02 por lord_10 »
« Respuesta #8 en: 20 de Marzo de 2008, 14:04:28 »
[DSIM] BOOT Error.
el error es la configuracion del programa, que no le da la ruta donde ir, le falta cargar datos al programa,
Saludo
Desconectado jfh900
« Respuesta #9 en: 20 de Marzo de 2008, 15:57:06 »
El Proteus no reconoce la extensión del fichero ejecutable. Seguramente como te han dicho sea un fichero con extensión .HEX
Desde España Jesús
« Respuesta #10 en: 20 de Marzo de 2008, 16:25:39 »
Bien originalmente el archivo que se descarga a la tarjeta 68HC11 es el s19 pero definitivamente no me lo reconoce el proteus...bueno ahora el detalle es que no se como generar un archivo hex, puesto que no me lo genera directamente del proteus.
con respecto a lo que me dices de la configuracion del proteus, la verdad que no le he movido nada, pero si tienes alguna sugerencia sobre la configuracion...pos te lo agraeceria.
pasando a otras cosas, ahora tampoco me genera el archivo LST que se supone debe generar.....creo que voy de mal en peor....espero me tengan paciencia
    • My Blog
« Respuesta #11 en: 20 de Marzo de 2008, 17:45:11 »
Hola
Unos post anteriores mencione sobre el programa pcbug11m ó el IAR Embedded Workbench for Motorola 68HC11, edita y compila ahi tus programas este se encarga de generar todas las extensiones necesarias y posteriormente solo cargas el archivo necesario al micro. pruebalo y nos cuentas.
« Respuesta #12 en: 20 de Marzo de 2008, 20:50:02 »
Baje el pcbug11m pero no se por que no corre, povoca errores y el otro no lo encontre para descargar, sinembargo, encontre un simulador el THRSim11, que me compila los archivos .ASM y me genera los .LST y los .S19, aunque el micro no funciona solo poniendole ese archivo .s19, el archivo .LST que se genera me ayuda a compilarlo directamente con el proteus y generar un archivo .S19 que funcione directamente en el proteus.
con un poco de alegria les dire que ya logre simular mi proyecto, aunque tengo que revisar alguna conecciones por que creo mal puse algunas jeje.
aunque aun tengo problemas con otros archivos...le sigo intentando a ver que detalles tienen y luego les comento...primero hago el esfuerzo y si no puedo le aviso pa que me hechen la mano sale?
gracias de antemano
« Respuesta #13 en: 21 de Marzo de 2008, 02:41:52 »
Bien chicos parece que mi problema esta solucionado jeje...como les mencion en el post anterior...con la ayuda del THRSim11 genero el .LST y con eso compilo desde proteus despues cargo al micro y simulo sin problemas...weno...casi por que aun no logro que corra bien jeje.....aunque me parece raro que nisiquera funcione un codigo pequeño...pero para eso les pondre otro post pa que me ayuden  :D
    • My Blog
« Respuesta #14 en: 21 de Marzo de 2008, 16:07:06 »
ok ok por aqui andamos y em da gusto que ya pudiste solucionar un problema  :mrgreen: ahora solo ha que ver el siguiente detallito del cual comentas :-)
