Pues bien! a ver si alguien me echa una mano con los Fuse porque me compila pero no me va.
Agradeceria cualquier ayuda
#include <18F2550.h>
#device adc=10
#FUSES WDT4 //Watch Dog Timer uses 1:4 Postscale
#FUSES INTRC_IO //Internal RC Osc, no CLKOUT
#FUSES NOPROTECT //Code not protected from reading
#FUSES BROWNOUT //Reset when brownout detected
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PUT //Power Up Timer
#FUSES NOCPD //No EE protection
#FUSES STVREN //Stack full/underflow will cause reset
#FUSES NODEBUG //No Debug mode for ICD
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT //Program memory not write protected
#FUSES NOWRTD //Data EEPROM not write protected
#FUSES IESO //Internal External Switch Over mode enabled
#FUSES FCMEN //Fail-safe clock monitor enabled
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES NOWRTC //configuration not registers write protected
#FUSES NOWRTB //Boot block not write protected
#FUSES NOEBTR //Memory not protected from table reads
#FUSES NOEBTRB //Boot block not protected from table reads
#FUSES NOCPB //No Boot Block code protection
#FUSES NOMCLR //Master Clear pin disabled
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES NOXINST //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES PLL1 //No PLL PreScaler
#use delay(clock=8000000,restart_wdt)
#byte PORTA= 0xF80
#byte PORTB= 0xF81
#byte PORTC= 0xF82
#byte PORTE= 0xF84
#bit PULS1= PORTC.0 // Pulsador Marrón
#bit PULS2= PORTA.6 // Pulsador verde
#define use_portb_lcd TRUE
#include <LCD.C>
int16 i,j;
setup_adc_ports(AN0_TO_AN4|VSS_VDD);
setup_spi(FALSE);
setup_wdt(WDT_ON);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_4);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_4,255,1);
// Frecuencia = clock / 4 / prescaler / (repeticiones+1) = 8000000/4/4/(255+1)=1953
setup_timer_3(T3_DISABLED|T3_DIV_BY_1);
setup_vref(FALSE);
lcd_init();
enable_interrupts(INT_AD);
enable_interrupts(GLOBAL);
setup_low_volt_detect(FALSE);
i=512; // punto medio del duty de 10 bits
setup_ccp1(CCP_PWM);
set_pwm1_duty(i);
set_adc_channel(0);
while (1) {
if (!PULS1)
i--;
if (!PULS2)
i++;
set_pwm1_duty(i);
j = read_adc();
lcd_gotoxy(1,1);
printf(LCD_PUTC,"Duty%3lu ADC %4lu",i,j);
lcd_gotoxy(1,2);
printf(LCD_PUTC,"PWM%3.0f%% Vin %4.2fV",(float)i*100/1024,(float)j*5.0/1024.0);
delay_ms(10);
