hola peña, a ver si alguien pudiera pasarme esto a .hex, ya q no consigo hacerlo.
si alguien tiene la amabilidad de hacerlo, q me lo mande a hammerseim@hotmail.com
un saludo cracks
;ConnectionReset
;TransmissionStart
;SHT_WriteByte
;WaitForData
;SHT_ReadByte
;AddCRC1byte, ReverseByte - used to compute CRC
;SHT_ReadStatus, SHT_WriteStatus - not implemented
;LinearizeHumidity - 3xLinear, my method
;BCD8_100 - used to convert % Humidity
;ComputeAsciiTemp - convert Temperature
;InitLCD, InitTXT, ErrTXT - LCD dispaly
LIST P=16F876A, F=INHX8M ; list directive to define processor
#include "p16f876a.inc" ; processor specific variable definitions
__CONFIG _HS_OSC & _CP_OFF & _WDT_OFF & _BODEN_ON & _PWRTE_ON & _LVP_OFF & _DEBUG_OFF & _CPD_OFF
radix dec
errorlevel -302, -305
xtal EQU 20000000
CBLOCK 0x20
cnt1
cnt2
cnt3 ;cnt1/2/3 for delay
al
ah ;ah/al used in crc compuations
crc ;computed crc so far
byte ;used in send/rcv
info1
info2
infocrc ;info1/2/crc store the values received
contor ;cycle bits
i
thebyte, rwbyte
SHT_reg_image ;image of SHT11 status reg
humip128,humip32
txtTemp:5
t100,t10,t1,tdot,t01
txtHumi:9
bcd100,bcd10,bcd1
txtDewP
hi,lo,shi,slo,digit ; convet temp
negative
ENDC
;pin assignments:
#define DATApin PORTC,4 ;PORTC,4
#define CLKpin PORTC,3 ;PORTC,3
;adr command r/w
#define STATUS_REG_W 0x06 ;000 0011 0
#define STATUS_REG_R 0x07 ;000 0011 1
#define MEASURE_TEMP 0x03 ;000 0001 1
#define MEASURE_HUMI 0x05 ;000 0010 1
#define RESET_SHT 0x1e ;000 1111 0
BANK0_ macro ;BANK1 -> BANK0
bcf STATUS,RP0
endm
BANK1_ macro ;BANK0 -> BANK1
bsf STATUS,RP0
endm
tmic macro
goto $+1
endm
; at high frequency xtals and *very* long wires to the sensor
; you may wish to add a small delay (several instructions)
; at the end of SDAT and SCLK macros
; also the pull-up resistor should be smaller
SDAT macro updown
if updown==0
bcf DATApin
else
bsf DATApin
endif
endm
SCLK macro updown
if updown==0
bcf CLKpin
else
bsf CLKpin
endif
endm
MakeSDATinput macro
BANK1_
bsf DATApin ;TRIS=1
BANK0_
endm
MakeSDAToutput macro
BANK1_
bcf DATApin ;TRIS=0
BANK0_
endm
DelayN macro msx10
movlw msx10
call DelayMs
endm
loadw macro arg1
movlw high(arg1)
movwf hi
movlw low(arg1)
movwf lo
endm
loads macro arg1
movlw high(arg1)
movwf shi
movlw low(arg1)
movwf slo
endm
dodigit macro arg1
loads arg1
call dosub
endm
;ooooooooooooo RESET ooooooooooooooooooooooooo
ORG 0x0000
clrf STATUS
movlw 0x00
movwf PCLATH
goto init
;************ initial *******************
init
clrf PORTA
bsf STATUS,RP0 ; select bank 1
movlw d'10' ; at 20Mhz with 115200 => 10
movwf SPBRG ; at 4Mhz with 19200 => 12
movlw b'00100100' ; TXEN+BRGH
movwf TXSTA
movlw 6
movwf ADCON1
clrf TRISA ;all outputs
movlw B'11111100'
movwf TRISC
bcf CLKpin ;TRIS=0 CLK=output
bcf STATUS,RP0 ; select bank 0
movlw b'10010000'
movwf RCSTA
bcf PORTC,0
bcf PORTC,1
clrf SHT_reg_image ;Status register of SHT11 is initially 0
call InitLCD
call InitTXT
start
movlw 5
call SHT11_acquire
addlw 0 ;check errors
btfss STATUS,Z
goto treatcommerr
call LinearizeHumidity
movwf byte
call BCD8_100
movlw 3
call SHT11_acquire
btfss STATUS,Z
goto treatcommerr
movf info1,w
movwf hi
movf info2,w
movwf lo
loads 4000
clrf negative
call Sub16
bc positive
loads 1 ;take absolute value
call Sub16
comf hi
comf lo
incf negative
positive
call ComputeAsciiTemp
afisLCD
movlw 0x02 ; home
call LCD_Cmd
bsf rwbyte,5
movlw 23
movwf contor
movlw txtTemp-1
movwf FSR
incafis
incf FSR
movf INDF,w
call LCD_Cmd
decfsz contor
goto incafis
clrf rwbyte
movlw 0
call DelayMs
movlw 0
call DelayMs
goto start
treatcommerr
call ErrTXT
goto afisLCD
;************** PROCEDURES ****************************************
SHT11_acquire
; expects in W the command to be sent 3/5
movwf byte
MakeSDAToutput
call TransmissionStart
tmic
movf SHT_reg_image,w
movwf crc ;crc is initialised with Status Register = 0
movf byte,w
call AddCRC1byte ;command also enters in crc sum
call SHT_WriteByte
btfsc STATUS,C ; in case of error(ack not received)
goto ErrorNoACK ; Send err
call WaitForData
xorlw 1 ; 1=timeout
btfsc STATUS,Z
goto ErrorTimeout ;W=1
call SHT_ReadByte ;H
movwf info1
call AddCRC1byte
call SHT_ReadByte ;L
movwf info2
call AddCRC1byte
call SHT_ReadByte ;CRC
movf byte,w
movwf infocrc
call ReverseByte
;check CRC
xorwf crc
btfss STATUS,Z
goto ErrorCRCFailed
;Here we do whatever we want with the values: info1,info2
retlw 0 ;OK
ErrorNoACK ;treat errors
movlw 253
goto DoError
ErrorTimeout
movlw 254
goto DoError
ErrorCRCFailed
movlw 255
goto DoError
DoError
;call SendW
call ConnectionReset
retlw 255 ;error
TransmissionStart
SDAT 1
;SCLK 0 ;?default
SCLK 1
SDAT 0
SCLK 0
SCLK 1
SDAT 1
SCLK 0
return
; writes a byte to the sensor
; -> SDAT must be output already (and the line should be in 1) as left from TransmissionStart
; -> At the end the SDAT will be left as input
; -> Carry=1 if no ACK was received
SHT_WriteByte
movlw 8
movwf contor
altbitw
SCLK 0
rlf byte
btfss STATUS,C
SDAT 0
btfsc STATUS,C
SDAT 1
SCLK 1
decfsz contor
goto altbitw
SCLK 0 ; see NOTE(1)
MakeSDATinput ;
SCLK 1
bcf STATUS,C
btfsc DATApin
bsf STATUS,C ; signal error Carry=1
SCLK 0
return
;// reads a byte form the sensor
; -> Data from sensor must be now ready to read
; -> SDAT must be input already (and the line should be in zero)
; -> SCLK=0
; output => reading = byte = W
SHT_ReadByte
movlw 8
movwf contor
altbitr
SCLK 1
bcf STATUS,C
btfsc DATApin ;read line
bsf STATUS,C
rlf byte
SCLK 0
decfsz contor
goto altbitr
MakeSDAToutput
SDAT 0 ;gives ACK
SCLK 1
SCLK 0
MakeSDATinput
movf byte,w
return
WaitForData ; Timeout of 250ms
movlw 4 ; =4 for xtal=20MHz
movwf cnt1
ddc1
clrf cnt2
ddc2
clrf cnt3
ddc3
btfss DATApin ;wait for data to go low
retlw 0
decfsz cnt3
goto ddc3
decfsz cnt2
goto ddc2
decfsz cnt1
goto ddc1
retlw 1 ;Timeout
SendW
btfss PIR1,TXIF ;empty?
goto SendW
movwf TXREG
return
;W=new byte crc = crc # W
AddCRC1byte
movwf al
movlw 8
movwf contor
abitcrc
movf al,w
xorwf crc,w
movwf ah
rlf ah
movlw b'00011000'
btfsc STATUS,C
xorwf crc
rlf crc
rlf al
decfsz contor
goto abitcrc
return
;W -> byte to be inverted
ReverseByte
movwf ah
movlw 8
movwf contor
ivbi
rlf ah
rrf al
decfsz contor
goto ivbi
movf al,w
return
ConnectionReset
SDAT 1
SCLK 0
movlw 9
movwf contor
crac
SCLK 1
SCLK 0
decfsz contor
goto crac
return
;########################################################################3
InitLCD
DelayN 50
clrf rwbyte
movlw 3
call Raw1
DelayN 5
movlw 3
call Raw1
DelayN 1
movlw 3
call Raw1
DelayN 1
movlw 2
call Raw1
DelayN 1
movlw 0x20
call LCD_Cmd
movlw 0x08 ; off
call LCD_Cmd
movlw 0x01 ; clr
call LCD_Cmd
movlw 0x0c ; on: 1 on curs blink
call LCD_Cmd
movlw 0x06 ; mode: 0 1 inc shift
call LCD_Cmd
DelayN 10
return
Raw1
movwf PORTA
bsf PORTA,4
nop
bcf PORTA,4
return
LCD_Cmd
movwf thebyte
swapf thebyte,w
andlw 0fh
iorwf rwbyte,w
call Raw1
movf thebyte,w
andlw 0fh
iorwf rwbyte,w
call Raw1
DelayN 5
return
LinearizeHumidity
movf info1,w ;x/128
movwf humip128
rlf info2,w
rlf humip128
swapf info1,w ;x/32
andlw 0f0h
movwf humip32
swapf info2,w
andlw 0fh
iorwf humip32
bcf STATUS,C
rrf humip32
movlw 4
subwf info1,w
btfsc STATUS,C
goto linh_f2
movf humip128,w ; x<1024
addlw -3
addwf humip32
movlw 200 ; do not go below 0
subwf humip32,w
btfsc STATUS,C
clrf humip32
goto linh_fe
linh_f2
movlw 10
subwf info1,w
btfsc STATUS,C
goto linh_f3
movf humip32,w ; 1024<=x<2560
addlw 4
movwf humip32
goto linh_fe
linh_f3
movf humip128,w ; 2560<=x
addlw -24
subwf humip32
linh_fe
movf humip32,w
return
BCD8_100 ;used to convert % Humidity
;input: 8 bit positive number [0..255]
;output: bcd100,bcd10,bcd1 (+leading spaces +saturate on 100)
movwf byte
movlw ' '
movwf bcd100 ; bcd100=' '
clrf bcd10
decf bcd10 ; bcd10 = -1
movlw '0'-1
movwf bcd1 ; bcd1 = '/'
movlw 100
subwf byte,w
btfsc STATUS,C
goto bcd8_big100
movlw 10 ;below 100
bcd8_big10 ;still >10
subwf byte
incf bcd10
btfsc STATUS,C
goto bcd8_big10
movlw '0'
btfsc STATUS,Z ;Z=1 if byte<10
movlw ' '
addwf bcd10
movlw 11
addwf byte
bcd8_big1
incf bcd1
decfsz byte
goto bcd8_big1
return
bcd8_big100
movlw '0'
movwf bcd100
incf bcd100
movwf bcd10
bcd8_end
return
;input: temperature in (hi,lo)
;output: t100,t10,t1,t01 ( +leading spaces +[leading minus])
ComputeAsciiTemp
dodigit 10000
movwf t100
dodigit 1000
movwf t10
dodigit 100
movwf t1
dodigit 10
movwf t01
;"remove" zeroes
BANKISEL 0
movlw t100
movwf FSR
movlw '0'
xorwf INDF,w
skpz
goto ddrzend
movlw ' '
movwf t100
incf FSR
movlw '0'
xorwf INDF,w
skpz
goto ddrztn
movlw ' '
movwf t10
incf FSR
ddrztn ;test negative
decfsz negative
goto ddrzend
decf FSR
movlw '-'
movwf INDF
ddrzend
return ; done
; "dosub" is called by the "dodigit" macro defined above.
; Subtract the number in shi/slo from hi/lo until the result
; is negative, incrementing the ascii equivelent each time.
dosub
movlw '0'-1
movwf digit
moresub
incf digit,F ; increment ASCII character
call Sub16 ; (hi,lo) - (shi,slo)
btfsc STATUS,C ; any carry?
goto moresub ; no, keep subtracting
call Add16 ; reverse the last subtraction
movf digit,W
return
Sub16
movf slo,w ; subtract current power of 10
subwf lo,f ; lo = lo - slo
movf shi,w
btfss STATUS,C
addlw 1
subwf hi,f ; hi = hi - shi - NC
return
Add16
movf slo,w
addwf lo,f
movf shi,w
btfsc STATUS,C
addlw 1
addwf hi,f
return
; prepare the text: Temp:000.0^C__Humi:000%
InitTXT
movlw 'T'
movwf txtTemp
movlw 'e'
movwf txtTemp+1
movlw 'm'
movwf txtTemp+2
movlw 'p'
movwf txtTemp+3
movlw ':'
movwf txtTemp+4
movlw '.'
movwf tdot
movlw 0xdf
movwf txtHumi
movlw 'C'
movwf txtHumi+1
movlw ' '
movwf txtHumi+2
movlw ' '
movwf txtHumi+3
movlw 'H'
movwf txtHumi+4
movlw 'u'
movwf txtHumi+5
movlw 'm'
movwf txtHumi+6
movlw 'i'
movwf txtHumi+7
movlw ':'
movwf txtHumi+8
movlw '%'
movwf txtDewP
return
; text on error: Temp:000.0^C__Humi:000%
ErrTXT
movlw ' '
movwf t100
movwf t10
movwf t01
movwf bcd100
movwf bcd1
movlw '?'
movwf t1
movwf bcd10
return
DelayMs ;ms
;movlw 10 ;in W (sau cnt1) parametru intirzierea 1..255
movwf cnt1 ;incarc pe cnt1 din delval din prog Pp
delaymsjcnt1
movlw d'7'
movwf cnt2
delaymsjcnt2
movlw d'236'
movwf cnt3
delaymsjcnt3
decfsz cnt3
goto delaymsjcnt3
decfsz cnt2
goto delaymsjcnt2
decfsz cnt1
goto delaymsjcnt1
return
END
